Eclipse Maven Project exporting as Maven Project [message #1800525] |
Tue, 01 January 2019 07:00  |
Greetings community and a happy new year,
I would like to know if it is possible to export an Eclipse - Maven - project as pure Maven project (XText Projects)?
(removing all Eclipse dependencies, project setting files whatever overhead Eclipse creates)
=> Intentions
This weird git plugin Eclipse uses is confusing me and when I am able to automatically remove all the project dependencies I am able to use git from command line manually.
So I plan to do sth. in my eclipse workspace on the project - export it as pure Maven project, so that builds, tests, clean ups can also be run just using Maven via command line. Afterwards, I can add it to git and later pull a new version created maybe by somebody else. This pulled version can afterwards imported as maven project into my eclipse workspace and after changing sth. I am able to export it again to the git branch.
Rather complicated expedition but I couldn't imagine a better way without getting annoyed by weird IDE dependencies I don't understand. Also this graphical git interface is just awkward...
Thank you very much in advance.
Re: Eclipse Maven Project exporting as Maven Project [message #1800592 is a reply to message #1800567] |
Thu, 03 January 2019 00:30  |
Yes, Xtext generates a lot of code, much of which you can avoid tracking. But if you don't track them, something in your Maven build will still need to generate them; you'd be best off using the Xtext forum to ask about such things:
https://www.eclipse.org/forums/index.php/f/27/
No, I didn't say that all the files are tracked by the MANIFEST.MF, I suggested that dependencies are tracked in this way.
In my projects that use Xtext, e.g., Xcore, these are the files I ignored:
https://git.eclipse.org/c/emf/org.eclipse.emf.git/tree/plugins/org.eclipse.emf.ecore.xcore/.gitignore
So I mostly track all files (e.g., *.java files derived from *.xtend files, and also src-gen files) so that I don't have to generate them as part of my Maven build. And my Maven build uses Tycho so I can resolve dependencies directly from p2 repositories.
https://ci.eclipse.org/emf/
I found Git overall horribly complicated when I started, but its grown to seem intuitive. That's always the way things are. So I rarely use the command line, except when I want to script something. E.g., this script to "clean" a git repository#!/bin/sh
CWD=$PWD
for i in $(echo .git */.git); do
if [ -d $i ]; then
cd $i
cd ..
pwd
git reset --hard
git clean -xdf
git status
git pull
cd $CWD
fi
done
I'd suggest learning the Git UI and when something isn't comfortable, then use the command line. You don't need to use one or the other exclusively.
FUDForum. Page generated in 0.20208 seconds
