Home » Eclipse Projects » Kura » Connect to WiFi with hidden SSID
Connect to WiFi with hidden SSID [message #1799582] Mon, 10 December 2018 09:43 Go to next message
Does anyone know how to connect Kura to a Wifi wich is not broadcasting its SSID (hidden SSID)?
Re: Connect to WiFi with hidden SSID [message #1799972 is a reply to message #1799582] Tue, 18 December 2018 04:10 Go to previous messageGo to next message
putting the network name and password and then confirming is not sufficient?
Matteo
Re: Connect to WiFi with hidden SSID [message #1799980 is a reply to message #1799972] Tue, 18 December 2018 05:10 Go to previous messageGo to next message
unfortunately it is not. as soon as disabling the SSID broadcast on router side, Kura is not able to connect anymore.
Re: Connect to WiFi with hidden SSID [message #1800034 is a reply to message #1799980] Wed, 19 December 2018 04:07 Go to previous messageGo to next message
Could you please file an issue here: https://github.com/eclipse/kura/issues
It should be definitely a bug.
Re: Connect to WiFi with hidden SSID [message #1800744 is a reply to message #1799582] Mon, 07 January 2019 11:13 Go to previous messageGo to next message
The Ignore Broadcast SSID option in the Wireless tab can enable the access to networks with hidden SSIDs.
From the Kura documentation [1]:
Ignore Broadcast SSID - operates as follows if set to true:
In Access Point mode, sends an empty SSID in beacons and ignores probe request frames that do not specify full SSID.
In Station mode, does not scan for the SSID before attempting to associate.
So, when set to true in Access point mode, the SSID will not be broadcasted, creating a hidden SSID network. When in Station mode, Kura will not check or search for the SSID, enabling the connection to hidden SSIDs.
Could you give a try on your setup?
Best,
Pierantonio
[1] https://eclipse.github.io/kura/config/wi-fi-configuration.html
Re: Connect to WiFi with hidden SSID [message #1800873 is a reply to message #1800744] Wed, 09 January 2019 05:23 Go to previous message
@Matteo
Thank you for your reply.... I tried it with Kura 3.2.0 Version... I will first try 4.0.0 and if it is also not working then I will definitely file an issue
@Pierantonio
Thank you for your reply... I found that option, but unfortunately it only has an impact in AccessPoint Mode..creates Wireless AP with hidden SSID.... But does not lead to connection with Hidden SSID Wifi in Station Mode (still tried with 3.2.0)
Previous Topic:Update to 4.0.0
Next Topic:Questions about application deployment on kura
Current Time: Mon Nov 03 20:37:10 EST 2025
Powered by FUDForum. Page generated in 1.07132 seconds
