Home » Modeling » TMF (Xtext) » Building a map collection
Building a map collection [message #1799901] Mon, 17 December 2018 03:52 Go to next message
I have a grammar where I can store MoClasses in a map collection, see momDsl.xtext attached.
It works, but current syntax looks as follows:
Class: MyTopClass
Attributes:
MyAttribute1 "test"
Class: MySubClass
Attributes:
I would like to change it to this:
Class: MyTopClass
Attributes:
MyAttribute1 "test"
Class: MySubClass
Attributes:
How would I do that?
Br Johan
  • Attachment: momDsl.xtext
    (Size: 0.55KB, Downloaded 98 times)
Re: Building a map collection [message #1799903 is a reply to message #1799901] Mon, 17 December 2018 04:03 Go to previous messageGo to next message
hi am not sure if i understand your problem.
dont see if this is a problem about the map part or the definition part.
do you want to have innerClasses? if yes how shall that look like syntax wise?
how do you distinguish a inner class from a new outer class?
Re: Building a map collection [message #1799906 is a reply to message #1799903] Mon, 17 December 2018 04:37 Go to previous messageGo to next message
EMF has a form of support for Map features using an EMap, which is actually a list. Using it is quite tricky and not nearly as efficient as a traditional Map.
I'm pretty sure that Xtext has no autosynthesis of an EMF EMap, so you will need to use a manual definition, possibly using an EStringToStringMapEntry-like intermediate to facilitate the Xtext parsing. Populating an efficient Map is something you will have to orchestrate in a later stage.
Ed Willink
Re: Building a map collection [message #1799921 is a reply to message #1799906] Mon, 17 December 2018 08:47 Go to previous messageGo to next message
Thanks for quick reply. Yes I want to have inner classes. Since Xtext does not support left recursion I was looking for how to deal with it and found this:
https://stackoverflow.com/questions/18006833/xtext-dealing-with-left-recursion-grammar
I don't need sets so I removed that. And now I simplifed the grammar by removing Term, so the gammar looks as below.
But as you say Christian I am not sure how to handle the references with this grammar.
Br Johan
grammar org.xtext.mom.MomDsl with org.eclipse.xtext.common.Terminals
generate momDsl "http://www.xtext.org/mom/MomDsl"
Model:
collection += Collection*
moInstances+=Mo*
Collection: ( => Map );
Map: '{' {Map} ( entries += MapEntry ( ',' entries += MapEntry )* )? '}';
MapEntry: key=Mo value=MapValue;
MapValue: ( {MapValue} | Collection );
Mo:
'MoId:' name=ID
'Class:' class=STRING
'Attributes:' moAttributes+=MoAttribute*
MoAttribute:
name=ID
value=AttributeValue
AttributeValue:
(value=STRING | 'MoRef:' moRef=[Mo])
Re: Building a map collection [message #1799927 is a reply to message #1799921] Mon, 17 December 2018 09:51 Go to previous messageGo to next message
no i mean:
if you have a
Class X
Class Y
Class Z
and Y and Z both children of X or is Z and child of Y
Re: Building a map collection [message #1799929 is a reply to message #1799927] Mon, 17 December 2018 10:22 Go to previous messageGo to next message
What I am after is this:
Class A
Class B // Child of A
Class C // Child of B
Class D // Child of A
Then each class should have attibutes.
Attributes can either contain a value or a reference to another class object.
An attribute in Class D should shall be able to refer to Class A, B or C.
The reference must be relative so reference from Class D to C should be "B.C".
Re: Building a map collection [message #1799931 is a reply to message #1799929] Mon, 17 December 2018 10:34 Go to previous messageGo to next message
i still dont understand what your example models/asts are for. your grammar has no "{" in syntax.
besides what: what references point to is ususally a matter of scoping
[Updated on: Mon, 17 December 2018 10:35] by Moderator
Re: Building a map collection [message #1799967 is a reply to message #1799931] Tue, 18 December 2018 03:05 Go to previous messageGo to next message
Ok I reworked the grammar a bit and just added a parentGroup reference instead.
I think this will work for my case. I understand I need to add scoping also, will look at that next.
Model:
moInstances+=Mo*
Mo:
'MoId:' name=ID
'ParentMo:' belongTo=[Mo]
MoAttribute:
name=ID
value=Choice
Choice: (AttributeValue | MoRef);
AttributeValue:
value=STRING
MoRef:
'MoRef:' moRef=[Mo]
Re: Building a map collection [message #1800148 is a reply to message #1799967] Thu, 20 December 2018 08:32 Go to previous messageGo to next message
I reworked the grammar based on an Xtext example so now I use abstract Classes and abstract Instances. New grammar:
grammar org.xtext.mom2.MomDsl with org.eclipse.xtext.common.Terminals
generate momDsl "http://www.xtext.org/mom2/MomDsl"
Domainmodel:
(classElements+=AbstractMoClass)*
(instanceElements+=AbstractMoInstance)*
ClassDeclaration:
'Class' name=QualifiedName '{'
(elements+=AbstractMoClass)*
AbstractMoClass:
ClassDeclaration | AbstractAttributes | Import;
InstanceDeclaration:
'Instance' name=QualifiedName 'Class' class=[ClassDeclaration|QualifiedName] '{'
(elements+=AbstractMoInstance)*
AbstractMoInstance:
InstanceDeclaration | InstanceAttributes; //| Import;
QualifiedName:
ID ('.' ID)*;
Import:
'import' importedNamespace=QualifiedNameWithWildcard;
QualifiedNameWithWildcard:
QualifiedName '.*'?;
AbstractAttributes:
Attributes
Attributes:
name=QualifiedName
attributes+=Attribute*
Attribute:
name=ID ':'
type=STRING
InstanceAttributes:
'Attributes' attributes=[AbstractAttributes|QualifiedName]
Based on this I am able to first create the MO Classes and then create instances for those MO Classes as follows:
Class my.mom
Class ManagedElement
Class Equipment
Class FieldReplaceableUnit
attributes
fruId : 'test'
Class RiPort
attributes
riPortRef1 : ''
riPortRef2 : ''
Class RiLink
Instance my.instance Class my.mom
Instance ME1 Class my.mom.ManagedElement
Instance Eqm1 Class my.mom.ManagedElement.Equipment
Instance FRU1 Class my.mom.ManagedElement.Equipment.FieldReplaceableUnit
Instance Ri_A Class my.mom.ManagedElement.Equipment.FieldReplaceableUnit.RiPort {}
Instance Ri_B Class my.mom.ManagedElement.Equipment.FieldReplaceableUnit.RiPort {}
Instance Ri_C Class my.mom.ManagedElement.Equipment.FieldReplaceableUnit.RiPort {}
Instance FRU2 Class my.mom.ManagedElement.Equipment.FieldReplaceableUnit
Attributes my.mom.ManagedElement.Equipment.FieldReplaceableUnit.attributes
Instance CPRI1 Class my.mom.ManagedElement.Equipment.RiLink
Attributes my.mom.ManagedElement.Equipment.FieldReplaceableUnit.RiPort.attributes
But now I am struggeling with the attributes. I want to be able to define a set of attributes for each class that should then be inherited for each instance of that class.
I found this related topic but cannot quite figure out how to solve it:
https://www.eclipse.org/forums/index.php/t/1086056/
Br Johan
Re: Building a map collection [message #1800151 is a reply to message #1800148] Thu, 20 December 2018 08:42 Go to previous message
implement scoping for
InstanceAttributes:
Previous Topic:Standalone setup parsing threadsafety
Next Topic:Builds with xtend-maven-plugin started failing
Current Time: Fri Nov 07 22:12:19 EST 2025
Powered by FUDForum. Page generated in 0.04589 seconds
