Home » Modeling » TMF (Xtext) » Error in creating fragment for STRING(Related with 'fragment STRING' definition in Xtext)
Error in creating fragment for STRING [message #1799725] Wed, 12 December 2018 22:09 Go to next message
I have the below code for a DSL that I'm building using Xtext in Eclipse (I'm converting a .g4 file to Xetxt: -
Domainmodel:
	elements+=projection_name elements+=projection_component elements+=layer_specification
	elements+=description
projection_name
   : keywords+=KEYWORD_projection model_name+=projection_name_model_name punctuations+=SEMICOLON
   : identifiers+=identifier2
   : keywords+=KEYWORD_component component_name+=projection_component_component_name punctuations+=SEMICOLON
   : identifier+=identifier2
layer_specification
   : keywords+=KEYWORD_layer layer_name+=layer_specification_layer_name punctuations+=SEMICOLON
description
   : keywords+=KEYWORD_description string+=STRING punctuations+=SEMICOLON
KEYWORD_component
   : ( key='component' )
KEYWORD_description
   : ( key='description' )
KEYWORD_layer
   : ( key='layer' )
KEYWORD_projection
   : ( key='projection' )
fragment STRING
SEMICOLON
   : symbol=';'
identifier2
   : IDENTIFIER
projectionmainidentifier
   : IDENTIFIER
offlineexpressionidentifier
   : IDENTIFIER
   | KEYWORD_description
   | KEYWORD_projection
IDENTIFIER
   : name=ID
Everything is fine except for the 'fragment STRING' definition. The word 'STRING' gets underlined in red and states "A datatype rule cannot override a terminal rule."
Could you please tell me how this should be corrected?
Regards.
[Updated on: Wed, 12 December 2018 22:30] by Moderator
Re: Error in creating fragment for STRING [message #1799728 is a reply to message #1799725] Wed, 12 December 2018 23:04 Go to previous messageGo to next message
terminal STRING
Re: Error in creating fragment for STRING [message #1799735 is a reply to message #1799728] Thu, 13 December 2018 03:12 Go to previous messageGo to next message
Thank you Karsten. After implementing the syntax you suggested, the artifacts are generated without errors. But when I try to type the syntax 'description' in runtime, I get the error that I have attached with this reply.
Could you kindly help me overcome this error?
Re: Error in creating fragment for STRING [message #1799738 is a reply to message #1799735] Thu, 13 December 2018 03:17 Go to previous messageGo to next message
the fragment misses a NOT i think (have a look at the string rule in the superclass)
(i dont understand what your intention with that rule is)
[Updated on: Thu, 13 December 2018 03:19] by Moderator
Re: Error in creating fragment for STRING [message #1799740 is a reply to message #1799735] Thu, 13 December 2018 03:24 Go to previous messageGo to next message
terminal STRING
Re: Error in creating fragment for STRING [message #1799744 is a reply to message #1799740] Thu, 13 December 2018 03:58 Go to previous messageGo to next message
Thank you Karsten and Christian! It is working fine now.
Re: Error in creating fragment for STRING [message #1799745 is a reply to message #1799744] Thu, 13 December 2018 04:00 Go to previous messageGo to next message
How can I find the definitions provided by Default in Xtext. e.g: the default definition given for STRING ?
Re: Error in creating fragment for STRING [message #1799746 is a reply to message #1799745] Thu, 13 December 2018 04:03 Go to previous messageGo to next message
simply klick on the default terminal grammar name in the top
Re: Error in creating fragment for STRING [message #1799747 is a reply to message #1799746] Thu, 13 December 2018 04:11 Go to previous messageGo to next message
I tried this. But when I click on 'terminal STRING', what I get is:
TerminalRule STRING
ALERT_LINE_COMMENT : ( '//!' ('\r'|'\n')* ) ; QUESTION_LINE_COMMENT : ( '//?' ('\r'|'\n')* ) ; GOOD_LINE_COMMENT : ( '//=' ('\r'|'\n')* ) ; CHARACTER : ('\'') ('\'') ('\'') ; terminal TIME : ( ('0'..'9')+ ':' ('0'..'9')+ ) ;
This is, surprisingly, the syntax definitions (that are commented) I have mentioned above the terminal STRING rule!
The other thing I realized was that, when I removed the comments from the above said definitions, the default STRING is given just as 'TerminalRule STRING'. So I guess the definition I'm getting must be wrong, because whatever I put as comments above the terminal rule, will be displayed as its definition. Could you please help me with this problem?
[Updated on: Thu, 13 December 2018 04:21] by Moderator
Re: Error in creating fragment for STRING [message #1799753 is a reply to message #1799747] Thu, 13 December 2018 04:42 Go to previous messageGo to next message
noooooooooo
i means this line:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
Re: Error in creating fragment for STRING [message #1799759 is a reply to message #1799753] Thu, 13 December 2018 05:17 Go to previous messageGo to next message
Do you mean the Rules listed down in the outline tab, as in the attached pictire below?
  • Attachment: xtext.png
    (Size: 93.77KB, Downloaded 119 times)
Re: Error in creating fragment for STRING [message #1799763 is a reply to message #1799759] Thu, 13 December 2018 05:36 Go to previous messageGo to next message
no just move the cursor on the "org.eclipse.xtext.common.Terminals"
and F3 or crtl+click
Re: Error in creating fragment for STRING [message #1799765 is a reply to message #1799763] Thu, 13 December 2018 05:42 Go to previous message
Thank you Christian. Ctrl+click worked.
Previous Topic:Creating two xtext grammar files within one project
Next Topic:Adding Content Assist to Xtext Gradle Project
Current Time: Fri Nov 07 23:39:40 EST 2025
Powered by FUDForum. Page generated in 0.09507 seconds
