Home » Language IDEs » ServerTools (WTP) » Error executing JSP page from Eclipse 3.2 WTP
Error executing JSP page from Eclipse 3.2 WTP [message #179944] |
Tue, 26 September 2006 03:10  |
Originally posted by: dolpheen.gmail.com
I have installed Eclipse by downloading and extracting the file:
wtp-all-in-one-sdk-R-1.5.0-200606281455-win32.zip
on my PC.
I am using JDK 1.5 as a JVM.
After that I have created a Sample Project containing a very simple
index.jsp
located at
C:\eclipse\workspace\SampleProject\WebContent\index.jsp
the relative path being
/SampleProject/WebContent/index.jsp
I have configured Tomcat 5.5 as the application server.
When I run this jsp file using 'Run on Server' option , I get the error:
Server Error: No launchable artifact could be found in the selection
What may be the problem?
Then I decided to run it independently.
I started my Apache server, it is listening on port 12769
The console info says that Server is running.
So i just tried the following url's on the server:
http://localhost:12769
http://localhost:12769/SampleProject/WebContent/index.jsp
But not able to run any one.
May I say that Tomcat is running as I am not getting the Tomcat welcome
page.
Is this the correct location of file?
I am also having Tomcat Sysdeo plug-in and I have decided not to install
it.
Please help.
-Sameer
Re: Error executing JSP page from Eclipse 3.2 WTP [message #179969 is a reply to message #179961] |
Tue, 26 September 2006 10:15   |
To change the port, you can double-click on the server in the Servers
view to open the server editor for the Tomcat server. Then change the
port(s) in the Ports section of the Overview page and save the
configuration. You can also modify server.xml directly, but it should
be the one under the Servers project in your workspace.
Also, what is the state of the "Run modules directly..." checkbox on
this Overview page of the server editor?
Larry
Sameer wrote:
> Dear Sir,
> Thanks for responding.
> I have created a dynamic web project.
> As posted previously the properties of index.jsp shows:
> Path: /SampleProject/WebContent/index.jsp
> Location: C:\eclipse\workspace\SampleProject\WebContent\index.jsp
> I am trying to run this page using Run... option.
> I have created a Launch configuration (referring Tomcat) for the same.
> Upon running it starts the Tomcat server, but nowhere Oputput is displayed.
> So, the server being in running condition,
> I have tried the following in IE as suggested by you.
> http://localhost:12769/SampleProject/index.jsp
> It won't work.
> description: The requested resource (/SampleProject/index.jsp) is not
> available.
> One another thing I have noticed that, though I have changed the server
> port to 12769 by using server.xml from conf folder, still the console
> run of Tomcat shows that it is running on port 80.
> INFO: Starting Coyote HTTP/1.1 on http-80
> Sep 26, 2006 7:39:34 PM org.apache.jk.common.ChannelSocket init
> INFO: JK2: ajp13 listening on /0.0.0.0:8009
> Sep 26, 2006 7:39:34 PM org.apache.jk.server.JkMain start
> I am getting directory listing by typing http://localhost:80
> Why this may happen?
> May I use Eclipse for formatting purpose only and let the jsp pages run
> by copying them to appropriate webapps folder?
> Please help.
> -Sameer
Re: Error executing JSP page from Eclipse 3.2 WTP [message #179973 is a reply to message #179961] |
Tue, 26 September 2006 10:27   |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Sameer,
the problem with the port comes from Eclipse copying the config files to your
workspace and starting the server from there. Take a look at a folder "Servers"
in your workspace, there you should find the tomcat configuration in a subfolder.
You can change this behaviour if you doubleclick the tomcat server in the
"Servers" view. There is an option "Run modules directly from the workspace". If
you uncheck this option your full tomcat will be started up, thus showing the
welcome page and using your modified port.
Nevertheless, the index.jsp should be opened if you pick "run on server".
Is there a chance you could post your sample project ? Best way is to export it
as a WAR file. You could also try to export and reimport it yourself, this way
you will get a clean new project (avoids running into errors which result from a
broken project).
Hope this helps
Wolfgang
Re: Error executing JSP page from Eclipse 3.2 WTP [message #180069 is a reply to message #180030] |
Wed, 27 September 2006 09:49   |
To add the project to the server, you can right-click on the Tomcat
server in the Servers view and select "Add and Remove Projects...".
Select the project and click the Add button to move it to the
"Configured projects" column on the right. Then click Finish.
Starting the Tomcat server will first publish the project's webapp to
the server (i.e. put a copy under the "webapps" directory), then start
the server. Once started, the URL you give below should work.
If the project was already added to the server prior to unchecking the
"Run modules directly..." option, you may need to remove and re-add the
project in separate sessions with the "Add and Remove Projects..."
dialog. The publishing code isn't aware of this option and doesn't
"fix" projects that have already been added to the server when this
option is switched.
As Nitin suggests in a separate e-mail, you may be encountering a bug
that's causing your web project not to be recognized as a valid web
project, leading to the "No launchable artifact" error. I can't be sure
if this is your cause, but I have seen this happen due to startup order
of the Web Tools plug-ins. If the "static web project" type appeared in
a list prior to the "dynamic web project" type, the project would be
mistakenly identified as a "static web project" and you would get this
behavior. Some work was done to fix this in WTP 1.5.1, but as noted in
the bug it seems it can still happen.
Larry
Sameer wrote:
> Hello,
> I have unchecked the option "Run modules directly from the workspace"
> from the Tomcat server in the "Servers" view and also changed the port
> 8080 using the same.
> Now I can get Tomcat welcome page at
> http://localhost:8080
> Still how to run my index.jsp using this tomcat instance?
> (The SampleProject must be in webapps directory of tomcat to ensue such
> event, I do not know how eclipse is going to map my SampleProject
> directory into webapps)
> I was not able to run using,
> http://localhost:8080/SampleProject/index.jsp
> What I have to do to run the index.jsp directly from Eclipse?
> How to avoid the error,
> Please help.
> -Sameer
Re: Error executing JSP page from Eclipse 3.2 WTP [message #180143 is a reply to message #180135] |
Thu, 28 September 2006 10:12  |
You need the dependencies too, i.e. emf-sdo-xsd, gef, and jem. You can
use the links found on
http://download.eclipse.org/webtools/downloads/drops/R1.5/M- 1.5.1-200609221939/
In addition, you should be using Eclipse 3.2.1 with WTP 1.5.1. A link
for this is also provided on the page given above. Note that these
aren't quite "final" releases. The release of "final" versions is
targeted to occur 09/29.
Larry
Sameer wrote:
> Hello,
> I am already having eclipse: eclipse-SDK-3.2-win32.zip
> As per your suggestion, I have downloaded the file:
> wtp-M-1.5.1-200609221939.zip (29.72 MB)
> from the download link:
> http://ftp.jaist.ac.jp/pub/eclipse/webtools/downloads/drops/ R1.5/M-1.5.1-200609221939/wtp-M-1.5.1-200609221939.zip
> I extracted eclipse-SDK-3.2-win32.zip, Eclipse folder got created.
> Then I extracted and overrighted the Eclipse folder with files from
> wtp-M-1.5.1-200609221939.zip.
> Giving path of JDK1.5 by the vm switch I started Eclipse.
> To my surprise I am not getting any options related to J2EE in Customize
> Perspective.
> I also tried eclipse -clean command.
> I noticed that after extracting wtp-M-1.5.1-200609221939.zip, I am not
> getting any org.eclipse.wst.* packages in the plug-ins folder which do
> exists in
> How do this come? Have I downloaded a wrong file?
> Please comment.
> -Sameer
Current Time: Sat Jul 26 10:42:03 EDT 2025
Powered by FUDForum. Page generated in 0.09342 seconds
