Home » Modeling » GMF (Graphical Modeling Framework) » How to configure the loocation, name ... of a new created element with GMF
How to configure the loocation, name ... of a new created element with GMF [message #179554] Fri, 28 March 2008 05:32 Go to next message
My diagram is partioned (A --> B). When the new diagram is opened, I
want to initialize it with a new created object. So, I have overwritten
the method initializeGraphicalViewerContents like this :
protected void initializeGraphicalViewerContents() {
super.initializeGraphicalViewerContents();
EObject rootElement = getDiagram().getElement();
com.clearsy.eventB.Machine machine = null;
if (rootElement instanceof com.clearsy.eventB.Machine) {
machine = (com.clearsy.eventB.Machine) rootElement;
} else {
MessageDialog.openError(getSite().getShell(), "Root element is not a
Machine", "The root of your model is not an event B Machine.");
if (machine.getContainsM() == null){
ICommandProxy icmd = new ICommandProxy(
new MachineContentCreateCommand(
new CreateElementRequest(
rootElement, EventBElementTypes.MachineContent_2001)));
icmd.execute();
My method calls a GMF CreateElementCommand (MachineContentCreateCommand
which is generated by GMF) with w CreateElementRequest.
My object is correctly created. But I would like to change its location,
set some of its labels... I manage to change its labels overwritting
the doDefaultElementCreation() method of MachineContentCreateCommand.
But I failed to change its location. I know I can change its location
with a GEF CreateElement command and a GEF CreateElementRequest request,
but I would like to do this with a GMF command.
Any ideas ?
Thanks for your help.
Philippe
Re: How to configure the loocation, name ... of a new created element with GMF [message #179960 is a reply to message #179554] Mon, 31 March 2008 10:24 Go to previous messageGo to next message
Any ideas ?
Philippe BLANC a écrit :
> } else {
> not a Machine", "The root of your model is not an event B Machine.");
> rootElement,
> icmd.execute();
> Any ideas ?
> Regards,
> Philippe
Re: How to configure the loocation, name ... of a new created element with GMF [message #180041 is a reply to message #179960] Tue, 01 April 2008 04:47 Go to previous messageGo to next message
Originally posted by: ijerez2001.msn.com
Try with SetBoundsCommnad to set the location (and optionally the size).
"Philippe BLANC" <blanc.philippe83@gmail.com> escribió en el mensaje de
noticias:fsqs6m$41c$1@build.eclipse.org...
> Any ideas ?
>> Hi,
>> My diagram is partioned (A --> B). When the new diagram is opened, I want
>> to initialize it with a new created object. So, I have overwritten the
>> } else {
>> rootElement,
>> icmd.execute();
>> set some of its labels... I manage to change its labels overwritting the
>> doDefaultElementCreation() method of MachineContentCreateCommand. But I
>> failed to change its location. I know I can change its location with a
>> GEF CreateElement command and a GEF CreateElementRequest request, but I
>> Any ideas ?
>> Regards,
>> Philippe
Re: How to configure the loocation, name ... of a new created element with GMF [message #180110 is a reply to message #180041] Tue, 01 April 2008 08:52 Go to previous message
Finally, I found my answer using a CreateViewRequest.
Here is my source code :
if (rootElement instanceof Machine) {
machine = (Machine) rootElement;
} else {
Machine",
CreateViewRequest request =
CreateViewRequestFactory.getCreateShapeRequest(EventBElement Types.MachineContent_2001,
getPreferencesHint());
Point p = new Point(100,100);
Dimension d = new Dimension(400,600);
request.setLocation(p);
request.setSize(d);
Map map = new HashMap();
map.put("machineId",machine.getId());
request.setExtendedData(map);
Command createMachineContentCmd = (Command)
getDiagramEditPart().getCommand(request);
createMachineContentCmd.execute();
>> Any ideas ?
>>> Hi,
>>> overwritten the method initializeGraphicalViewerContents like this :
>>> } else {
>>> is not a Machine", "The root of your model is not an event B Machine.");
>>> rootElement,
>>> icmd.execute();
>>> (MachineContentCreateCommand which is generated by GMF) with w
>>> location, set some of its labels... I manage to change its labels
>>> overwritting the doDefaultElementCreation() method of
>>> MachineContentCreateCommand. But I failed to change its location. I
>>> know I can change its location with a GEF CreateElement command and a
>>> GEF CreateElementRequest request, but I would like to do this with a
>>> GMF command.
>>> Any ideas ?
>>> Regards,
>>> Philippe
Previous Topic:Removing "Save All" etc.
Next Topic:emf tree in outline view
Current Time: Sun Jul 27 04:06:30 EDT 2025
Powered by FUDForum. Page generated in 0.10119 seconds
