Home » Eclipse Projects » Sirius » How to show property views on the feature columns of sirius edition tables
How to show property views on the feature columns of sirius edition tables [message #1798690] Thu, 22 November 2018 16:02 Go to next message
Hello , i wanted to ask is this possible with the sirius table editors that we can get the property view on the feature column of the sirius table editors. We get the property view on the line elements, but on selecting the entity in the feature column we can.t see its properties. Any help or guidance will be highly appreciated.
https://imgur.com/a/JWccX11
Re: How to show property views on the feature columns of sirius edition tables [message #1798716 is a reply to message #1798690] Fri, 23 November 2018 03:34 Go to previous message
It is not possible at the moment. The way Sirius tables work, each line represents a single selement (the semantic element behind the Line Mapping instance), however many features and columns there are. I just tested to confirm, and when you have a given line selected, selecting different columns on the same line does not change the overall Eclipse selection (it's still the same DLine model element), so does not retrigger any update/refresh computation that you could plug into to make your properties views "column-sensitive" (even if you had easy access to the currently selected column).
It seems that it could be an interesting enhancement though, so do not hesitate to open a feature request on the bugzilla (though I can not guarantee if/when we will work on it, unless of course you want to contribute yourself or sponsor the feature).
Pierre-Charles
Previous Topic:left menu
Next Topic:Min Mac OS for 11.1?
Current Time: Mon Jul 21 00:04:31 EDT 2025
Powered by FUDForum. Page generated in 0.04416 seconds
