Home » Eclipse Projects » Eclipse Scout » Form Field in Menu(How to add a Form Field Menu Datepicker to a tablepage?)
Form Field in Menu [message #1798467] Mon, 19 November 2018 10:26 Go to next message
as i explored the widgets, i stumbled accross this https://scout.bsi-software.com/widgets/?dl=widget-menubar nice piece of menu.
Now i was wondering if i could put it on my tablepage. As said in the release notes of 7.1, one should be ablte to add this menu in any menu supporting environment.
I tried it like in the github linked to the widget with
@Order(50)
    public class MyMenuMenu extends AbstractFormFieldMenu {
      @Order(10)
      public class MenuDateField extends AbstractDateField {
        private final SimpleDateFormat m_dateFormatter = new SimpleDateFormat("MM-dd-yyyy hh:mm");
        protected String getConfiguredLabel() {
          return "DateField in MenuBar";
        protected byte getConfiguredLabelPosition() {
          return LABEL_POSITION_ON_FIELD;
        protected boolean getConfiguredLabelVisible() {
          return false;
        protected boolean getConfiguredStatusVisible() {
          return true;
        protected void execChangedValue() {
          getDateFieldValueField().setValue(Optional.ofNullable(getValue()).map(v -> m_dateFormatter.format(v)).orElse(null));
          System.out.println("Date changed to: " + getValue());
I put it inside my table on a tablepage. My other menus on this page work just fine and i wonder what i need to specify to make it work too.
Because i think its a great tool for loading data for a user specified period of time (e.g. in my case the chosen month)
So what part of the implementation did i mess up in the first place?
Thank you in advance!
Re: Form Field in Menu [message #1798517 is a reply to message #1798467] Tue, 20 November 2018 01:17 Go to previous messageGo to next message
Hi TheMaddes
First: Which version of Scout are you using?
FormFields in Menus have been release officially as part of Scout 8 (Eclipse "Photon" Release Train).
The 7.1 version you're referencing is a preview of the Scout 8 release: It does not contain all features that made it into Scout 8 and is not intended for production usage.
There's bit of a trap with TablePages:
You need to add the field to the inner table, not the table page itself, meaning at the same level you'd put a menu on the table.
After falling into this trap and moving the filed to the correct location, it worked for my Scout 8 project on a TablePage.
Patrick
Re: Form Field in Menu [message #1798532 is a reply to message #1798517] Tue, 20 November 2018 03:48 Go to previous messageGo to next message
Hey Patrick,
thank you for the answer. Im using Scout 8.0.0.021_Simrel_2018_09 at the moment.
I thought i did that, maybe i have to investigate further, the codesnippet i poseted is inside the table, just like other menus like a new or edit menu (those are showing without any problem). But the datepicker is not.
So to simplify the snippet:
 public class Table extends AbstractTable {
 @Order(10)
    public class EditMenu extends AbstractMenu {...}
@Order(20)
    public class NewMenu extends AbstractMenu {...}
 @Order(50)
      @Order(10)
      public class MenuDateField extends AbstractDateField {...}
...all the columns etc
So i think i already placed it as you said or did i get you wrong?
UPDATE:
It seems the behaviour is like the behaviour of a edit menu, It shows up now, but only on selection of sth in the table. I dont get why though, and i need it to show like a new menu so i can use it to filter data for a specific month/day chosen by the user.
EDIT:
Ok nevermind, i figured it out, forgot to set it as a tablemenutype, shame on me :) But thank you so far :)
[Updated on: Tue, 20 November 2018 05:08] by Moderator
Re: Form Field in Menu [message #1798615 is a reply to message #1798532] Wed, 21 November 2018 03:26 Go to previous message
Great that it works now - I was already wondering since I copied your snippet and it worked great :)
Previous Topic:java.lang.SecurityException: access denied (code 3a).
Next Topic:Login with Database connection
Current Time: Wed Jul 23 17:39:13 EDT 2025
Powered by FUDForum. Page generated in 1.56691 seconds
