"dataSetRow" is not defined [message #368633] |
Tue, 16 June 2009 12:00  |
Originally posted by: hoe.zurich.ibm.com
I'm running into the following error (with BIRT 2.3.0 engine). Who knows
how to resolve this? (BTW, I'm using a report design that has an EMF
Data Source/Set with a Row Mapping, and a Column Mapping "name" defined).
Many thanks,
Christian
-- SNIP
org.eclipse.birt.report.engine.api.EngineException: There are errors
evaluating script "dataSetRow["name"]": ReferenceError: "dataSetRow" is
not defined. (<inline>#1)
at
org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1121)
at
org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1085)
at
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:88)
at
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
at
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
at
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
at
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
at
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:64)
at
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:157)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:70)
-- SNIP
Re: "dataSetRow" is not defined [message #368899 is a reply to message #368646] |
Fri, 03 July 2009 11:53   |
Jason and Dear All,
I was busy with other things, but have now returned to this problem.
If I do a simple report with an EMF data source that's based on the
example library model (from org.eclipse.emf.examples.library) this works
fine.
I now suspect that the problem here might have to do with one of these
two causes:
(1) My meta-model, since its application-specific, does not reside in
an Eclipse plug-in (such as org.eclipse.emf.examples.library), but in a
plug-in project in the Eclipse workspace. There it defines extensions
org.eclipse.emf.ecore.generated_package as usual for EMF models, but
perhaps BIRT does not pick up these package registrations.
I've tried report generation also in a PDE environment (i.e. after Run
As / Eclipse Application), but that does not seem to make a difference.
(2) My model is currently split across two XMI files, again using
normal EMF conventions. I specify both as instance models in the EMF
data source.
I've tried to combine them into one, but that does not seem to make a
difference either.
Does (1) or (2) ring any further bells?
Christian
Jason Weathersby wrote:
> I have seen a similar error when the system has conflicting versions of
> Rhino.jar. Does the simple test report work in your environment? How
> are you deploying it?
>>>> knows how to resolve this? (BTW, I'm using a report design that has
>>>> an EMF Data Source/Set with a Row Mapping, and a Column Mapping
>>>> "name" defined).
>>>> -- SNIP
>>>> is not defined. (<inline>#1)
>>>> at
Re: "dataSetRow" is not defined [message #1798595 is a reply to message #368913] |
Tue, 20 November 2018 14:02  |
The answer is simple.
You have a redundant data_binding somewhere.
1. Look for the indicated ID in the error message then switch to XML_Source tab to find the element it's using.
2. Return back to the Layout and click Binding TAB under the Property Editor.
3. Remove redundant binding.
FUDForum. Page generated in 0.05659 seconds
