.FileNotFoundException: [message #1798584] |
Tue, 20 November 2018 11:10 |
I am getting this error - two copies - on normally working project running on Raspberry Pi 3B
When I switch to the Raspberry Pi Zero the Eclipse goes crazy with close to 100 errors - mostly same as the two I get on 3B.
My project which runs as expected on 3B NEVER starts on Zero and appears to time out before these errors are posted / generated.
Everything compiles without any errors on Zero - but the processor is different. BCM 2835
Could that be an issue?
java.io.FileNotFoundException: /media/jim/DEV/Eclipse OXYGEN 3/OXYGEN3/workspace/eclipse-workspace/VNA_1103 (Is a directory)
at java.io.RandomAccessFile.open0(Native Method)
at java.io.RandomAccessFile.open(RandomAccessFile.java:316)
at java.io.RandomAccessFile.<init>(RandomAccessFile.java:243)
at java.io.RandomAccessFile.<init>(RandomAccessFile.java:124)
at org.eclipse.cdt.utils.ERandomAccessFile.<init>(ERandomAccessFile.java:28)
at org.eclipse.cdt.utils.elf.Elf.commonSetup(Elf.java:664)
at org.eclipse.cdt.utils.elf.Elf.<init>(Elf.java:684)
at org.eclipse.cdt.utils.elf.Elf.getAttributes(Elf.java:929)
at org.eclipse.cdt.utils.elf.parser.ElfParser.getBinary(ElfParser.java:60)
at org.eclipse.cdt.utils.elf.parser.ElfParser.getBinary(ElfParser.java:34)
at org.eclipse.cdt.launch.LaunchUtils.getBinary(LaunchUtils.java:120)
at org.eclipse.tcf.internal.cdt.ui.TCFLaunchContext.isBinary(TCFLaunchContext.java:272)
at org.eclipse.tcf.internal.debug.ui.launch.TCFPropertyTester.testIsExecutable(TCFPropertyTester.java:43)
at org.eclipse.tcf.internal.debug.ui.launch.TCFPropertyTester.test(TCFPropertyTester.java:25)
at org.eclipse.core.internal.expressions.Property.test(Property.java:58)
at org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:100)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:51)
at org.eclipse.core.internal.expressions.IterateExpression.evaluate(IterateExpression.java:160)
at org.eclipse.core.internal.expressions.WithExpression.evaluate(WithExpression.java:75)
at org.eclipse.core.internal.expressions.EnablementExpression.evaluate(EnablementExpression.java:55)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchShortcutExtension.evalEnablementExpression(LaunchShortcutExtension.java:281)
at org.eclipse.debug.ui.actions.ContextualLaunchAction.isApplicable(ContextualLaunchAction.java:287)
at org.eclipse.debug.ui.actions.ContextualLaunchAction.fillMenu(ContextualLaunchAction.java:218)
at org.eclipse.debug.ui.actions.ContextualLaunchAction$1.menuShown(ContextualLaunchAction.java:141)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:256)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5348)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1348)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1374)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1357)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1142)
at org.eclipse.jface.action.ActionContributionItem.copyMenu(ActionContributionItem.java:1242)
at org.eclipse.jface.action.ActionContributionItem.handleShowProxy(ActionContributionItem.java:1222)
at org.eclipse.jface.action.ActionContributionItem.lambda$7(ActionContributionItem.java:1185)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1353)
at org.eclipse.swt.widgets.Menu.gtk_show(Menu.java:711)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1926)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5602)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2116)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4181)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
FUDForum. Page generated in 0.07087 seconds
