Changes in forte_sync.cpp [message #1798440] |
Mon, 19 November 2018 04:01  |
As I was getting errors when I build the forte, I have to change this line in the forte_sync.cpp
CPCSyncObject::CPCSyncObject() {
InitializeSRWLock(&mLock);
Can you please add this to Release 1.10.?
Best,
Wolfgang
Re: Changes in forte_sync.cpp [message #1798441 is a reply to message #1798440] |
Mon, 19 November 2018 04:09   |
In order to be safe from the legal perspective, please create an Eclipse Account and sign an Eclipse Contributors Agreement.
After you have done this, you can push your change to the Gerrit code review system. For this you can either use the git review command, if you have installed it, or stick to the documentation found at https://www.eclipse.org/4diac/en_help.php "Developmen Documentation"->"FORTE"->"Contributing to FORTE"
If you want to use git review, install it, then in the FORTE repository type the command "git review -s" to load the setup from the repository. After that do your changes, add and commit them, and at last, if you want to push them to the 1.10.x code review, type "git review 1.10.x".
Please also create a bug and explain your issue, as each platform has its own forte_sync.cpp
Martin
FUDForum. Page generated in 0.04696 seconds
