Home » Newcomers » Newcomers » Force.com IDE login in to Salesforce(Eclipse does nothing when I click "next" and try to login to a Sandbox)
Force.com IDE login in to Salesforce [message #1798205] Wed, 14 November 2018 03:22 Go to next message
Hello
Can anyone help I am a new comer to Eclipse. I am trying to use Eclipse to login to a Salesforce Sandbox.
I have a Mac running Mojave 10.14.1 , I have installed Eclispe:
Version: 2018-09 (4.9.0)
Build id: 20180917-1800
I have installed JDK 11.0.1 64 bit from the Oracle Website
I have followed the instructions on force.com and installed the Force.com IDE plugin for Eclispe.
All of this seems to be working fine. I have opened Eclipse and then opened a new perspective for force. com.
Next I have tried to create a new Force.com project. When I right click and select New > Force.com project, nothing happens, no errors just nothing.
So I use the Project option instead, this works. From the Wizard I select Force.com > Force.com Project. I click the "Next" button once, nothing happens, I click it a second time and the Project Name / Login screen appears. I enter the mandatory details (Project Name, Username, password etc.). When I click the "Next" button nothing happens? No error messages no spinning wheels, just nothing. Can anyone help? Have I missed something in the install? Or is there another setting on my Mac I need to adjust. If anyone has anyone else has had this issue please let me know how you resolve it.
Re: Force.com IDE login in to Salesforce [message #1798242 is a reply to message #1798205] Wed, 14 November 2018 10:51 Go to previous messageGo to next message
You'll have to contact the developer of the Force.com IDE plugin.
Re: Force.com IDE login in to Salesforce [message #1798318 is a reply to message #1798242] Thu, 15 November 2018 04:56 Go to previous messageGo to next message
Thanks for the reply Nitin. I will follow this up on the force.com site.
Re: Force.com IDE login in to Salesforce [message #1798493 is a reply to message #1798318] Mon, 19 November 2018 15:00 Go to previous messageGo to next message
Did you ever get a response from force.com? I am having the same issue, but when I open it through the Project wizard it does nothing after I enter all my info and try to connect to our Salesforce build.
Re: Force.com IDE login in to Salesforce [message #1798891 is a reply to message #1798493] Tue, 27 November 2018 00:14 Go to previous messageGo to next message
hello, good night could solve the problem, I have the same situation?
regards
Re: Force.com IDE login in to Salesforce [message #1798938 is a reply to message #1798205] Tue, 27 November 2018 11:13 Go to previous messageGo to next message
Hey guys,
Same situation here. Reached same stage as @Richard Blackman - nothing happens after pressed "Next".
I have an SF org with custom domain and I'm using:
macOS Mojave 10.14.1
Eclipse IDE for Java Developers: Version: 2018-09 (4.9.0) | Build id: 20180917-1800.
Java version: 11.0.1
Lakis
Re: Force.com IDE login in to Salesforce [message #1798955 is a reply to message #1798938] Tue, 27 November 2018 18:41 Go to previous messageGo to next message
I am having the same issue. Start a new Force.com Project, enter my salesforce credentials and token, nothing happens. No error message or anything.
Re: Force.com IDE login in to Salesforce [message #1800613 is a reply to message #1798205] Thu, 03 January 2019 11:58 Go to previous messageGo to next message
I am also experiencing the EXACT same issue on the MacBook 2018 Mojave. Has anyone found the solution?
Maven's Mate was a great alternative to Force.com IDE now that is gone. What else is a good IDE (Visual Studio Code only works with scratch orgs I think).
Re: Force.com IDE login in to Salesforce [message #1800661 is a reply to message #1798205] Fri, 04 January 2019 11:52 Go to previous messageGo to next message
Exactly same issue. Any help will be very much appreciated. Thanks.
Re: Force.com IDE login in to Salesforce [message #1802267 is a reply to message #1800661] Tue, 05 February 2019 09:51 Go to previous messageGo to next message
I have exactly same issue. Has anyone found the solution?
Re: Force.com IDE login in to Salesforce [message #1805998 is a reply to message #1802267] Tue, 30 April 2019 05:50 Go to previous messageGo to next message
Same issue over here... can someone post a solution?
Re: Force.com IDE login in to Salesforce [message #1808270 is a reply to message #1798205] Thu, 20 June 2019 16:27 Go to previous message
Same issue here
I created a blank project and then added the force.com nature and put in credentials. This worked and it proceeded to download all the metadata from the org but there is no package.xml. If I try and change the contents of the project I get the following error
Unable to create the selected property page.
javax/xml/bind/JAXBException
Previous Topic:update of maven multi module project failed loaded from git
Next Topic:Unable to install updates in Eclipse Jee 2019-03
Current Time: Mon Jul 21 07:25:21 EDT 2025
Powered by FUDForum. Page generated in 0.10943 seconds
