fatal error LNK1169 when building forte [message #1798445] |
Mon, 19 November 2018 05:10  |
Hello all!
May you can help me with this error, which occurrs when I want to build forte with visual studio 2010 express:
------ Erstellen gestartet: Projekt: FORTE_LITE, Konfiguration: Release Win32 ------
4> FORTE_LITE.vcxproj -> C:\Users\softworks\Desktop\meoFORTE\FORTE_Sources\bin\meoLogic\src\FORTE_LITE.dir\Release\FORTE_LITE.lib
5>------ Erstellen gestartet: Projekt: forte, Konfiguration: Release Win32 ------
5>forteinit.obj : error LNK2005: "private: static unsigned char const E_RESTART::csmCOLDID" (?csmCOLDID@E_RESTART@@0EB) ist bereits in E_RESTART.obj definiert.
5>forteinit.obj : error LNK2005: "private: static unsigned char const E_RESTART::csmWARMID" (?csmWARMID@E_RESTART@@0EB) ist bereits in E_RESTART.obj definiert.
5>forteinit.obj : error LNK2005: "private: static unsigned char const E_RESTART::csmSTOPID" (?csmSTOPID@E_RESTART@@0EB) ist bereits in E_RESTART.obj definiert.
5>C:\Users\softworks\Desktop\meoFORTE\FORTE_Sources\bin\meoLogic\src\Release\forte.exe : fatal error LNK1169: Mindestens ein mehrfach definiertes Symbol gefunden.
========== Erstellen: 4 erfolgreich, Fehler bei 1, 3 aktuell, 0 übersprungen ==========
I'm using forte 1.10.0.RC2 on 32bit Windows.
Best regards
Re: fatal error LNK1169 when building forte [message #1798529 is a reply to message #1798495] |
Tue, 20 November 2018 03:16  |
Thank you for the answer.
Here is the config:
# This is the CMakeCache file.
# For build in directory: c:/Users/softworks/Desktop/meoFORTE/FORTE_Sources/bin/meoLogic
# It was generated by CMake: C:/Program Files (x86)/CMake/bin/cmake.exe
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUIs for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Semicolon separated list of supported configuration types, only
// supports Debug, Release, MinSizeRel, and RelWithDebInfo, anything
// else will be ignored.
CMAKE_CONFIGURATION_TYPES:STRING=Debug;Release;MinSizeRel;RelWithDebInfo
//Flags used by the compiler during all build types.
CMAKE_CXX_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /GR /EHsc
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
//Flags used by the compiler during release builds for minimum
// size.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
//Flags used by the compiler during release builds.
CMAKE_CXX_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
//Flags used by the compiler during release builds with debug info.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by default with all C++ applications.
CMAKE_CXX_STANDARD_LIBRARIES:STRING=kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib
CMAKE_C_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3
CMAKE_C_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
// size.
CMAKE_C_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
CMAKE_C_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by default with all C applications.
CMAKE_C_STANDARD_LIBRARIES:STRING=kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING= /machine:X86
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=C:/Program Files (x86)/FORTE
//Path to a program.
CMAKE_LINKER:FILEPATH=c:/Program Files (x86)/Microsoft Visual Studio 10.0/VC/bin/link.exe
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING= /machine:X86
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
//Value Computed by CMake
CMAKE_PROJECT_NAME:STATIC=FORTE
//RC compiler
CMAKE_RC_COMPILER:FILEPATH=rc
//Flags for Windows Resource Compiler.
CMAKE_RC_FLAGS:STRING=' '
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING= /machine:X86
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
//If set, runtime paths are not added when installing shared libraries,
// but are added when building.
CMAKE_SKIP_INSTALL_RPATH:BOOL=OFF
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=OFF
//Flags used by the linker during the creation of static libraries.
CMAKE_STATIC_LINKER_FLAGS:STRING=
CMAKE_STATIC_LINKER_FLAGS_DEBUG:STRING=
CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_STATIC_LINKER_FLAGS_RELEASE:STRING=
CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make. This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=OFF
//Additional compile flags appended to CMAKE_CXX_FLAGS.
FORTE_ADDITIONAL_CXX_FLAGS:STRING='/MP '
//Architecture to build FORTE on
FORTE_ARCHITECTURE:STRING=Win32
FORTE_BINARY_DIR:STATIC=C:/Users/softworks/Desktop/meoFORTE/FORTE_Sources/bin/meoLogic
//forte build support directory.
FORTE_BUILDSUPPORT_DIRECTORY:PATH=C:/Users/softworks/Desktop/meoFORTE/FORTE_Sources/buildsupport
//Build FORTE as an executable
FORTE_BUILD_EXECUTABLE:BOOL=ON
//Build FORTE as shared library
FORTE_BUILD_SHARED_LIBRARY:BOOL=OFF
//Build FORTE as static library
FORTE_BUILD_STATIC_LIBRARY:BOOL=OFF
//Path to the bootfile, if same directory as forte executable leave
// empty, include trailing '/'!
FORTE_BootfileLocation:STRING=
//Enable Forte Com Ethernet
FORTE_COM_ETH:BOOL=ON
//Layer for providing and receiving data to EclipseSCADA
FORTE_COM_EclipseSCADA_SFP:BOOL=OFF
//Enable Forte Com FBDK
FORTE_COM_FBDK:BOOL=ON
//Enable an HTTP Com Layer
FORTE_COM_HTTP:BOOL=OFF
//Enable Forte local communication
FORTE_COM_LOCAL:BOOL=ON
//Enable Modbus Com Layer
FORTE_COM_MODBUS:BOOL=OFF
//Path to Modbus library directory (leave empty for installed source
// code)
FORTE_COM_MODBUS_LIB_DIR:PATH=
//Enable OPC communication
FORTE_COM_OPC:BOOL=OFF
//Path to Boost library root directory
FORTE_COM_OPC_BOOST_ROOT:PATH=
//Path to OPC library root directory
FORTE_COM_OPC_LIB_ROOT:PATH=
//Enable OPC UA communication layer
FORTE_COM_OPC_UA:BOOL=OFF
//Enable Paho MQTT Com Layer
FORTE_COM_PAHOMQTT:BOOL=ON
//ABSOLUTE path to Paho MQTT src directory
FORTE_COM_PAHOMQTT_INCLUDE_DIR:PATH=C:/Users/softworks/Desktop/PAHO-MQTT-1.0.3/include
//MQTT Library file in FORTE_COM_PAHOMQTT_LIB_DIR to be linked
// to forte. Static library is not working for windows
FORTE_COM_PAHOMQTT_LIB:STRING=paho-mqtt3a.dll
//ABSOLUTE path to Paho MQTT library
FORTE_COM_PAHOMQTT_LIB_DIR:PATH=C:/Users/softworks/Desktop/PAHO-MQTT-1.0.3/lib
//Enable Forte raw communication
FORTE_COM_RAW:BOOL=OFF
//Enable Forte serial line communication
FORTE_COM_SER:BOOL=ON
//client to send xqueries
FORTE_COM_XqueryClient:BOOL=OFF
//forte Communication interrupt queue size
FORTE_CommunicationInterruptQueueSize:STRING=10
//Path to EclipseSCADA SFP Server library directory (leave empty
// for installed source code)
FORTE_ECLIPSE_SCADA_SFP_SERVER_LIB_DIR:PATH=
//Enable FORTE FMU Export. It generates a shared library
FORTE_ENABLE_FMU:BOOL=OFF
//Exclude Function blocks
FORTE_EXCLUDE_FBS:STRING=
//Path to a directory with FORTE modules located outside of the
// FORTE source code
FORTE_EXTERNAL_MODULES_DIRECTORY:PATH=
//forte eventchain event list size
FORTE_EventChainEventListSize:STRING=32768
//forte eventchain external event list size
FORTE_EventChainExternalEventListSize:STRING=32768
//Enable IO Modules
FORTE_IO:BOOL=OFF
//Support for the modular emBRICK system
FORTE_IO_EMBRICK:BOOL=OFF
//FORTE ip layer recv buffer size
FORTE_IPLayerRecvBufferSize:STRING=1500
//FORTE will resolve references to the stringdict at link-stage
// and not compile-stage. This will reduce compiletime if the stringdict
// changes.
FORTE_LINKED_STRINGDICT:BOOL=OFF
//Loglevel to use
FORTE_LOGLEVEL:STRING=LOGERROR
//forte management command protocol
FORTE_MGMCOMMANDPROTOCOL:STRING=DEV_MGR
//Max supported hierarchy that can be provided in a management
// commands
FORTE_MGM_MAX_SUPPORTED_NAME_HIERACHY:STRING=30
//FORTE change the source-files if includes for the generated includes
// are missing.
FORTE_MODIFY_SOURCES_ON_MISSING_GENERATED_INCLUDES:BOOL=ON
//Interacting with ADS servers
FORTE_MODULE_ADS:BOOL=OFF
//Interacting with the CONMELEON C1 IO board
FORTE_MODULE_CONMELEON_C1:BOOL=OFF
//Convert Function Blocks
FORTE_MODULE_CONVERT:BOOL=ON
//Interacting with GPIOs of Linux-based devices via I2C using i2c-dev
FORTE_MODULE_I2C-Dev:BOOL=OFF
//IEC61131-3 Function blocks
FORTE_MODULE_IEC61131:BOOL=ON
//I/O support for Lego Mindstorms EV3 using the ev3_dev operating
// system
FORTE_MODULE_LMS_EV3:BOOL=OFF
//Process interface using the MLPI functions for Bosch Rexroth
// PLCs
FORTE_MODULE_MLPI:BOOL=OFF
//Interacting with GPIOs and analogue inputs of the Odroid device
FORTE_MODULE_Odroid:BOOL=OFF
//openPOWERLINK Service Interface Function Blocks
FORTE_MODULE_POWERLINK:BOOL=OFF
//PiFace and PiFace like Raspberry PI expansion boards
FORTE_MODULE_PiFace:BOOL=OFF
//FORTE Online Reconfiguration
FORTE_MODULE_RECONFIGURATION:BOOL=OFF
//Function Blocks to communicate with ROS (publish/subscribe)
FORTE_MODULE_ROS:BOOL=OFF
//Real-Time Event Funktion blocks
FORTE_MODULE_RT_Events:BOOL=OFF
//Interacting with GPIOs Raspberry SPS
FORTE_MODULE_Raspberry-SPS:BOOL=OFF
//Interacting with GPIOs of linuxbased devices via the filesystem
// using sysfs
FORTE_MODULE_SysFs:BOOL=OFF
//FORTE UTILITY FBs
FORTE_MODULE_UTILS:BOOL=OFF
//Wago Kbus interface
FORTE_MODULE_WagoKbus:BOOL=OFF
//meo Logic Function Blocks
FORTE_MODULE_meoLogic:BOOL=ON
//Interacting with GPIOs using the umic library for MicroControl
FORTE_MODULE_uMIC:BOOL=OFF
FORTE_SOURCE_DIR:STATIC=C:/Users/softworks/Desktop/meoFORTE/FORTE_Sources
//FORTE string dict will reallocate memory if necessary when this
// flag is turned off
FORTE_STRINGDICTFIXEDMEMORY:BOOL=OFF
//FORTE string dict's initial max nr of strings
FORTE_STRINGDICTINITIALMAXNROFSTRINGS:STRING=300
//FORTE string dict's initial string buffer size
FORTE_STRINGDICTINITIALSTRINGBUFSIZE:STRING=8000
//Enable Forte Array Datatypes
FORTE_SUPPORT_ARRAYS:BOOL=ON
//Enable FORTE boot file loading on FORTE start-up
FORTE_SUPPORT_BOOT_FILE:BOOL=ON
//Enable Forte Custom Serializeable Datatypes
FORTE_SUPPORT_CUSTOM_SERIALIZABLE_DATATYPES:BOOL=ON
//Enable FORTE monitoring functionalities
FORTE_SUPPORT_MONITORING:BOOL=ON
//Enable support for the query management commands
FORTE_SUPPORT_QUERY_CMD:BOOL=ON
//FORTE System Tests
FORTE_SYSTEM_TESTS:BOOL=OFF
//Build Tests
FORTE_TESTS:BOOL=OFF
//Test specific include directories
FORTE_TESTS_INC_DIRS:PATH=
//Test specific library directories
FORTE_TESTS_LINK_DIRS:PATH=
//FORTE will log the events received at and sent from function
// blocks
FORTE_TRACE_EVENTS:BOOL=OFF
//forte sticks per second
FORTE_TicksPerSecond:STRING=1000
//Defines the time base in units per second that will be used in
// the TIME data type, The default value 1000000000 means 1ns
FORTE_TimeBaseUnitsPerSecond:STRING=1000000000
//Enable unicode support for STRING and WSTRING, WSTRING needs
// unicode support enabled!
FORTE_UNICODE_SUPPORT:BOOL=ON
//Enable Forte 64-Bit Datatypes
FORTE_USE_64BIT_DATATYPES:BOOL=ON
//Enable Lua FB types
FORTE_USE_LUATYPES:STRING=None
//Enable Forte Real Datatypes
FORTE_USE_REAL_DATATYPE:BOOL=ON
//Add the test definitions and compiler options to the base forte
FORTE_USE_TEST_CONFIG_IN_FORTE:BOOL=ON
//Enable Forte WSTRING Datatypes
FORTE_USE_WSTRING_DATATYPE:BOOL=ON
//Dependencies for target
forte_stringlist_externals_LIB_DEPENDS:STATIC=
# INTERNAL cache entries
//Stored GUID
ALL_BUILD_GUID_CMAKE:INTERNAL=5D1A58DE-8F52-4E1C-A61C-2C111956D6F7
//This is the directory where this CMakeCache.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=c:/Users/softworks/Desktop/meoFORTE/FORTE_Sources/bin/meoLogic
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=3
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=1
//Patch version of cmake used to create the current loaded cache
CMAKE_CACHE_PATCH_VERSION:INTERNAL=1
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=C:/Program Files (x86)/CMake/bin/cmake.exe
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=C:/Program Files (x86)/CMake/bin/cpack.exe
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=C:/Program Files (x86)/CMake/bin/ctest.exe
//ADVANCED property for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_STANDARD_LIBRARIES
CMAKE_CXX_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_STANDARD_LIBRARIES
CMAKE_C_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//Executable file format
CMAKE_EXECUTABLE_FORMAT:INTERNAL=Unknown
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Name of external makefile project generator.
CMAKE_EXTRA_GENERATOR:INTERNAL=
//Name of generator.
CMAKE_GENERATOR:INTERNAL=Visual Studio 10 2010
//Name of generator platform.
CMAKE_GENERATOR_PLATFORM:INTERNAL=
//Name of generator toolset.
CMAKE_GENERATOR_TOOLSET:INTERNAL=
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=C:/Users/softworks/Desktop/meoFORTE/FORTE_Sources
//ADVANCED property for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=89
//ADVANCED property for variable: CMAKE_RC_COMPILER
CMAKE_RC_COMPILER-ADVANCED:INTERNAL=1
CMAKE_RC_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_RC_FLAGS
CMAKE_RC_FLAGS-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=C:/Program Files (x86)/CMake/share/cmake-3.1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_INSTALL_RPATH
CMAKE_SKIP_INSTALL_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS
CMAKE_STATIC_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_DEBUG
CMAKE_STATIC_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL
CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_RELEASE
CMAKE_STATIC_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Suppress Warnings that are meant for the author of the CMakeLists.txt
// files.
CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE
//ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_ADDITIONAL_CXX_FLAGS
FORTE_ADDITIONAL_CXX_FLAGS-ADVANCED:INTERNAL=1
//STRINGS property for variable: FORTE_ARCHITECTURE
FORTE_ARCHITECTURE-STRINGS:INTERNAL=None;Bachmann M1;FreeRTOSLwIP;MacOs;NetOS 7.4;Nios2;PLCnext;Phycore AT91;PikeOS_Posix;Posix;VxWorks;Win32;rcX
//ADVANCED property for variable: FORTE_BUILDSUPPORT_DIRECTORY
FORTE_BUILDSUPPORT_DIRECTORY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_BUILD_EXECUTABLE
FORTE_BUILD_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_BootfileLocation
FORTE_BootfileLocation-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_CommunicationInterruptQueueSize
FORTE_CommunicationInterruptQueueSize-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_EXCLUDE_FBS
FORTE_EXCLUDE_FBS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_EventChainEventListSize
FORTE_EventChainEventListSize-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_EventChainExternalEventListSize
FORTE_EventChainExternalEventListSize-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_IPLayerRecvBufferSize
FORTE_IPLayerRecvBufferSize-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_LINKED_STRINGDICT
FORTE_LINKED_STRINGDICT-ADVANCED:INTERNAL=1
//Stored GUID
FORTE_LITE_GUID_CMAKE:INTERNAL=8AF36787-294E-49B6-8766-5B907B38F2D1
//STRINGS property for variable: FORTE_LOGLEVEL
FORTE_LOGLEVEL-STRINGS:INTERNAL=LOGDEBUG;LOGERROR;LOGWARNING;LOGINFO;NOLOG
//ADVANCED property for variable: FORTE_MGMCOMMANDPROTOCOL
FORTE_MGMCOMMANDPROTOCOL-ADVANCED:INTERNAL=1
//STRINGS property for variable: FORTE_MGMCOMMANDPROTOCOL
FORTE_MGMCOMMANDPROTOCOL-STRINGS:INTERNAL=DEV_MGR
//ADVANCED property for variable: FORTE_MGM_MAX_SUPPORTED_NAME_HIERACHY
FORTE_MGM_MAX_SUPPORTED_NAME_HIERACHY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_MODIFY_SOURCES_ON_MISSING_GENERATED_INCLUDES
FORTE_MODIFY_SOURCES_ON_MISSING_GENERATED_INCLUDES-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_STRINGDICTFIXEDMEMORY
FORTE_STRINGDICTFIXEDMEMORY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_STRINGDICTINITIALMAXNROFSTRINGS
FORTE_STRINGDICTINITIALMAXNROFSTRINGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_STRINGDICTINITIALSTRINGBUFSIZE
FORTE_STRINGDICTINITIALSTRINGBUFSIZE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_SUPPORT_ARRAYS
FORTE_SUPPORT_ARRAYS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_SUPPORT_BOOT_FILE
FORTE_SUPPORT_BOOT_FILE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_SUPPORT_CUSTOM_SERIALIZABLE_DATATYPES
FORTE_SUPPORT_CUSTOM_SERIALIZABLE_DATATYPES-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_SUPPORT_MONITORING
FORTE_SUPPORT_MONITORING-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_SUPPORT_QUERY_CMD
FORTE_SUPPORT_QUERY_CMD-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_TRACE_EVENTS
FORTE_TRACE_EVENTS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_TicksPerSecond
FORTE_TicksPerSecond-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_TimeBaseUnitsPerSecond
FORTE_TimeBaseUnitsPerSecond-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_UNICODE_SUPPORT
FORTE_UNICODE_SUPPORT-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_USE_64BIT_DATATYPES
FORTE_USE_64BIT_DATATYPES-ADVANCED:INTERNAL=1
FORTE_USE_LREAL_DATATYPE:INTERNAL=ON
//STRINGS property for variable: FORTE_USE_LUATYPES
FORTE_USE_LUATYPES-STRINGS:INTERNAL=None;LuaJIT;Lua
//ADVANCED property for variable: FORTE_USE_REAL_DATATYPE
FORTE_USE_REAL_DATATYPE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_USE_TEST_CONFIG_IN_FORTE
FORTE_USE_TEST_CONFIG_IN_FORTE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: FORTE_USE_WSTRING_DATATYPE
FORTE_USE_WSTRING_DATATYPE-ADVANCED:INTERNAL=1
//Stored GUID
INSTALL_GUID_CMAKE:INTERNAL=800D494E-0BBE-4A13-B342-966A651B4DC9
//Stored GUID
SG_Filter_CMake Rules_GUID_CMAKE:INTERNAL=8E3E350F-5384-4417-8F98-E84F6F1668B9
//Stored GUID
SG_Filter_Header Files_GUID_CMAKE:INTERNAL=771298A6-8753-4BB4-BA0A-86446570F188
//Stored GUID
SG_Filter_Object Files_GUID_CMAKE:INTERNAL=306DA8DF-2B37-4F65-B74D-5B1746E4833D
//Stored GUID
SG_Filter_Object Libraries_GUID_CMAKE:INTERNAL=D43B5517-876E-4EDA-8918-B4AAED4A17F3
//Stored GUID
SG_Filter_Resources_GUID_CMAKE:INTERNAL=89B2A3DA-8C37-4C42-B8D6-02A6FD8B10B5
//Stored GUID
SG_Filter_Source Files_GUID_CMAKE:INTERNAL=6180EC00-F8C8-4763-BE88-32F334AF5889
//Stored GUID
SG_Filter_arch\arch\win32_GUID_CMAKE:INTERNAL=9DFB8C65-8F7A-43E3-8098-F13C4CF95D67
//Stored GUID
SG_Filter_arch\arch_GUID_CMAKE:INTERNAL=783D634C-46AA-46A3-8D45-A452BD03D453
//Stored GUID
SG_Filter_arch_GUID_CMAKE:INTERNAL=92DBF9D4-2C1B-41DD-97AA-299EB99D85AE
//Stored GUID
SG_Filter_core\cominfra_GUID_CMAKE:INTERNAL=12CA7605-02B3-4D9C-9110-ABCA30B98DD8
//Stored GUID
SG_Filter_core\datatypes_GUID_CMAKE:INTERNAL=AD6EB21B-0F51-40C5-AD70-E85D8C18C55D
//Stored GUID
SG_Filter_core\fmi_GUID_CMAKE:INTERNAL=A53BF63B-2A5A-491B-8214-9E55FDC64967
//Stored GUID
SG_Filter_core\utils_GUID_CMAKE:INTERNAL=01646972-EDE0-4890-8813-4EC3AA770F78
//Stored GUID
SG_Filter_core_GUID_CMAKE:INTERNAL=16BC322E-0333-4B5B-8061-92D9546393E6
//Stored GUID
SG_Filter_modules/IEC61131-3\Arithmetic_GUID_CMAKE:INTERNAL=47E354F1-D497-4856-892C-CDEF5AC0A640
//Stored GUID
SG_Filter_modules/IEC61131-3\BistableElements_GUID_CMAKE:INTERNAL=639F6030-C026-4A2A-9F2C-B035C6F2CC63
//Stored GUID
SG_Filter_modules/IEC61131-3\BitwiseOperators_GUID_CMAKE:INTERNAL=5083992C-8DF5-496D-B37F-DFBDAAC91ADB
//Stored GUID
SG_Filter_modules/IEC61131-3\CharacterString_GUID_CMAKE:INTERNAL=CBE653D7-98D2-466E-8ADB-3303A98CB04F
//Stored GUID
SG_Filter_modules/IEC61131-3\Comparison_GUID_CMAKE:INTERNAL=7A7DBC30-3B72-4EC3-910B-A243753707E5
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\BCD_GUID_CMAKE:INTERNAL=E9D5D17A-4617-4A53-9714-8CD548C7D0EA
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\BOOL_GUID_CMAKE:INTERNAL=D741548A-062C-4781-8F33-776445042DDF
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\BYTE_GUID_CMAKE:INTERNAL=411999B8-9145-4A8D-9B1D-A8A23C4B985B
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\DINT_GUID_CMAKE:INTERNAL=534A317B-44BD-4C0C-A155-D89FB71E268F
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\DT_GUID_CMAKE:INTERNAL=0CE50C71-31DA-4228-A7B5-B755BCC80D40
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\DWORD_GUID_CMAKE:INTERNAL=3E498BDF-A1B4-4A80-9433-85DCD09F1B8F
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\INT_GUID_CMAKE:INTERNAL=46453E7B-70E0-4861-8B3A-21FC7864C902
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\LINT_GUID_CMAKE:INTERNAL=C8702A57-DD1E-4A68-B492-CD69F3FF2A87
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\LREAL_GUID_CMAKE:INTERNAL=F72EFB23-674D-41E9-92FA-F0FBF528BC44
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\LWORD_GUID_CMAKE:INTERNAL=A3A00B62-4CFB-406F-89A4-423822015500
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\REAL_GUID_CMAKE:INTERNAL=87CAA3DD-585C-4099-ADF3-580F2DB9F320
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\SINT_GUID_CMAKE:INTERNAL=F27376DC-3327-4FA9-B5DE-18CF41CAAA5D
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\STRING_GUID_CMAKE:INTERNAL=07A700DE-E5B6-47BA-818B-6A9C9243D889
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\TIME_GUID_CMAKE:INTERNAL=2A01C3F6-3FF6-4405-A758-68A0981D4B2D
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\UDINT_GUID_CMAKE:INTERNAL=849E983B-AF97-4F05-BE87-12E9AA615A97
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\UINT_GUID_CMAKE:INTERNAL=3BB3FE19-CA3E-4471-A43C-BAFA8F7523CC
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\ULINT_GUID_CMAKE:INTERNAL=ADA269B5-F324-4D17-8780-32140CBDA81D
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\USINT_GUID_CMAKE:INTERNAL=55DAFD3B-29D7-4C1F-B813-2FC6F1507F96
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\WORD_GUID_CMAKE:INTERNAL=830393DE-0BDC-4350-910B-BD46674DA053
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion\WSTRING_GUID_CMAKE:INTERNAL=7BFEC93B-5BB2-4B6F-B7C9-27ACCBAAB2D3
//Stored GUID
SG_Filter_modules/IEC61131-3\Conversion_GUID_CMAKE:INTERNAL=09E00285-2A53-4299-BF89-5F1E3B117820
//Stored GUID
SG_Filter_modules/IEC61131-3\Counters_GUID_CMAKE:INTERNAL=4EE4C77D-C35A-448F-AC7E-A4443E910F7F
//Stored GUID
SG_Filter_modules/IEC61131-3\EdgeDetection_GUID_CMAKE:INTERNAL=02253F3B-A5CB-4C8E-AD34-A85C2B20F9C5
//Stored GUID
SG_Filter_modules/IEC61131-3\Numerical_GUID_CMAKE:INTERNAL=E99FAD83-3372-4A27-8B01-3C4F97E63F87
//Stored GUID
SG_Filter_modules/IEC61131-3\Selection_GUID_CMAKE:INTERNAL=ED306E23-6145-4741-B89E-8D4186981DDA
//Stored GUID
SG_Filter_modules/IEC61131-3\Timers_GUID_CMAKE:INTERNAL=75923610-3C91-4860-A856-CA933CAECF7B
//Stored GUID
SG_Filter_modules/IEC61131-3_GUID_CMAKE:INTERNAL=94B35995-7966-46D3-9FA3-6A01F9D292DA
//Stored GUID
SG_Filter_modules/convert_GUID_CMAKE:INTERNAL=2DCDA41D-CC84-4D7F-896D-3E3A003B39B2
//Stored GUID
SG_Filter_modules/meo_GUID_CMAKE:INTERNAL=3E5AD121-BA7A-4884-A4ED-00FCE3EC9792
//Stored GUID
SG_Filter_modules/mqtt_paho_GUID_CMAKE:INTERNAL=F4780CC1-8545-48F3-8231-C739CBE7F9DE
//Stored GUID
SG_Filter_stdfblib\fblib\events_GUID_CMAKE:INTERNAL=2BB4420A-CB78-4E11-B1AC-ABF9639107E8
//Stored GUID
SG_Filter_stdfblib\fblib\ita_GUID_CMAKE:INTERNAL=469E39D3-8637-4C8E-B24F-6CD2DBB05FFE
//Stored GUID
SG_Filter_stdfblib\fblib\net_GUID_CMAKE:INTERNAL=7B9DB088-EC94-4C7A-A97F-8B3917430A6C
//Stored GUID
SG_Filter_stdfblib\fblib_GUID_CMAKE:INTERNAL=CA969661-B5F0-41D2-B804-BA69123499D9
//Stored GUID
SG_Filter_stdfblib_GUID_CMAKE:INTERNAL=62751E1D-F4ED-4B0B-8013-8AE3DAC07854
//Stored GUID
ZERO_CHECK_GUID_CMAKE:INTERNAL=D3A42F67-919C-4040-BF9F-AB7E0385579B
//Stored GUID
forte_GUID_CMAKE:INTERNAL=5473CB09-30E3-4C4E-92BB-C5E2DE51B8BF
//Stored GUID
forte_generate_modules_cmake_files_GUID_CMAKE:INTERNAL=8EB59339-54A9-4BD1-B68F-94E0CF81EB7D
//Stored GUID
forte_init_generator_GUID_CMAKE:INTERNAL=3D977CBC-AD01-41A4-931B-F8DD86361BAC
//Stored GUID
forte_stringlist_externals_GUID_CMAKE:INTERNAL=38FC1E85-E3DA-4068-86C7-3C99E27BAFAE
//Stored GUID
forte_stringlist_generator_GUID_CMAKE:INTERNAL=8436BA9C-513C-485A-B99A-2EF783F39DD3
FUDForum. Page generated in 0.31097 seconds
