Home » Modeling » TMF (Xtext) » Element Rename in XText 2.14(Rename problem)
Element Rename in XText 2.14 [message #1798297] Thu, 15 November 2018 00:41 Go to next message
Please refer the uploaded files. On press of enter button it is not coming out.
Could you please let me know that what can be the problem ?
mwe2 file:
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "org.xtext.example.test"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "windows-1252"
				lineDelimiter = "\r\n"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "org.xtext.example.TestDsl"
			fileExtensions = "lex"
			serializer = {
				generateStub = false
			renameRefactoring = {
        		useChangeSerializer = true
Thanks and regards,
Virag Purnam
  • Attachment: 1.png
    (Size: 9.47KB, Downloaded 84 times)
  • Attachment: 2.png
    (Size: 12.20KB, Downloaded 58 times)
  • Attachment: 3.png
    (Size: 10.90KB, Downloaded 80 times)
Re: Element Rename in XText 2.14 [message #1798298 is a reply to message #1798297] Thu, 15 November 2018 00:43 Go to previous messageGo to next message
Do you mean enter key?
Re: Element Rename in XText 2.14 [message #1798301 is a reply to message #1798298] Thu, 15 November 2018 01:52 Go to previous messageGo to next message
Yes. But I found the problem.
There was small problem in overridden class from RenameRefactoringController.
I have another question, related to rename.
Can we customize org.eclipse.ltk.core.refactoring.TextChange class?
also org.eclipse.text.edits.TextEditProcessor class ?
And how to do that?
Is binding required ?
Thanks and regards,
Virag Purnam
[Updated on: Thu, 15 November 2018 01:54] by Moderator
Re: Element Rename in XText 2.14 [message #1798303 is a reply to message #1798301] Thu, 15 November 2018 02:22 Go to previous message
what is the background behind your wish to change. see org.eclipse.xtext.ui.refactoring2.ChangeConverter
Previous Topic:Xtend generator fails- attributes are not resolved
Next Topic:Implementing dates clashes with simple equations
Current Time: Mon Jul 21 12:45:50 EDT 2025
Powered by FUDForum. Page generated in 0.07793 seconds
