Home » Newcomers » Newcomers » Repaint View
| Repaint View [message #178951] |
Wed, 08 November 2006 05:53  |
Originally posted by: dmarfil.citic.es
Hi everybody, I'm a newbie about RCP and I'm trying to do something that
I'm not sure about how can be done. First I've searched about it here but
didn't found anything...
I've got a view where I add widgets in createPartControl in an simple way.
I add a button too which must process the user's input, and then I want to
re-use the same view to load new widgets in it, but I have to remove the
old widgets from it before (I hope you understand my english). That is, I
need to repaint (re-init, reset) the view before I add more widgets.
I suppose it's not a difficult thing to do, but I don't know how to do
it...
Any help would be great!
Thanks in advance!
| Re: Repaint View [message #178975 is a reply to message #178959] |
Wed, 08 November 2006 09:22   |
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Danny Marfil wrote:
> Ouch, sorry, I've discovered this is not the right place to post my
> question.
> But anyway, if anybody knows about it, I will appreciate the help ;-)
> "Danny Marfil" <dmarfil@citic.es> escribió en el mensaje
> news:97a8591db230bf7ccafcb75854a940c2$1@www.eclipse.org...
>>it...
>>Thanks in advance!
Take a look at SWT Snippet98
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet98. java
Wayne
| Re: Repaint View [message #178983 is a reply to message #178975] |
Wed, 08 November 2006 11:04   |
Thanks Wayne, but I'm trying to find a way to re-initialize a view, if that
is possible (I don't know).
Does not exist a way to tell eclipse "dispose every widget in the view and
start drawing again since now"?
Indeed, I'm using a form as container this way:
toolkit = new FormToolkit(parent.getDisplay());
form = toolkit.createScrolledForm(parent);
Then I use form.getBody() as every widget's container, for example:
Button btnExample = toolkit.createButton(form.getBody(), "", SWT.PUSH);
If the user clicks on the button (for example), I would like to reset the
view and start loading other widgets in it. I got the button's listener, but
what must I include there to reset the view?
Maybe if I could "reset" the form, that would be sufficient...
Anyway thanks very much for your help!
DANNY
"Wayne Beaton" <wayne.beaton@_NOSPAM_eclipse.org> escribi
| Re: Repaint View [message #178997 is a reply to message #178983] |
Wed, 08 November 2006 12:01   |
> DANNY
> "Wayne Beaton" <wayne.beaton@_NOSPAM_eclipse.org> escribió en el mensaje
> news:4551E82C.4070704@_NOSPAM_eclipse.org...
>>>question.
>>>>way. I add a button too which must process the user's input, and then I
>>>>want to re-use the same view to load new widgets in it, but I have to
>>>>remove the old widgets from it before (I hope you understand my english).
>>>>That is, I need to repaint (re-init, reset) the view before I add more
>>>>widgets.
>>>>it...
>>>>Thanks in advance!
>>Wayne
Look harder at the snippet.
To clear your view, dispose the widgets you want to get rid of. In the
snippet, they put the widgets on a composite and dispose the composite.
Then create a new composite.
Here's an example:
public class SampleView extends ViewPart {
private Composite contents;
public void createPartControl(final Composite parent) {
contents = new Composite(parent, SWT.NONE);
contents.setLayout(new GridLayout());
new Label(contents, SWT.NONE).setText("Some label");
Button button = new Button(contents, SWT.NONE);
button.setText("Hello");
button.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
contents.dispose();
new Label(contents, SWT.NONE).setText("A different label");
new Text(contents, SWT.BORDER).setText("World!");
parent.layout();
public void setFocus() {
contents.setFocus();
This will work with the form toolkit as well.
| Re: Repaint View [message #179801 is a reply to message #179226] |
Mon, 13 November 2006 03:51  |
Hi Wayne,
since I'm quite newbie with Eclipse + RCP and my english is not so good, I
think it would be a hard work for me, but I would like to help in some way.
I offer my code and anything that could be useful for that, I would even try
to write something.
Anyway I think I haven't got the sufficient knowledge and experience about
this to write an article... I wish I could ;-)
Danny
Current Time: Wed Nov 12 14:37:56 EST 2025
Powered by FUDForum. Page generated in 0.09915 seconds
