Authentication in Scout 8 [message #1797704] |
Mon, 05 November 2018 07:56  |
I need help how to implement an authentication regarding a database table in scout 8, I created a table User and now I would like to enable authentication of users regarding to theire login and password stored in the table.
Kind Regards
Anis
Re: Authentication in Scout 8 [message #1805911 is a reply to message #1798106] |
Sat, 27 April 2019 14:34   |
I have the same case as in this thread: I would like to implement the authentication of users logging in to my application (using the Scout 9 version), with the participation of a dedicated table in the database.
Using all the tips given here, I made the following changes:
1. In the "shared" module I added a new authorization interface, as follows:
@TunnelToServer
public interface ISqlAuthService {
public int verify(String username, char[] password);
2. In the "server" module, I added the implementation of this interface, which verifies the user in the database.
3. In the "client" module I added the implementation of the ICredentialVerifier interface, which calls the above-mentioned service, as follows:
public class DataSourceCredentialVerifier implements ICredentialVerifier {
public int verify(String username, char[] password) throws IOException {
Subject subject = new Subject();
subject.getPrincipals().add(new SimplePrincipal("system"));
subject.setReadOnly();
RunContext runContext = RunContexts.empty();
return runContext.call(new Callable<Integer>() {
public Integer call() throws Exception {
return BEANS.get(ISqlAuthService.class).verify(username, password);
4. In the "ui.html" module in the existing UiServletFilter class I have added a reference to the above mentioned DataSourceCredentialVerifier.
When I run my application in development mode (ie through modules * .app.dev) and then submit login form, I get this exception:
org.eclipse.scout.rt.platform.exception.ExceptionHandler.handleThrowable(ExceptionHandler.java:135) - SecurityException:service registry does not contain a service of type pl.myapps.helloword.shared.security.ISqlAuthService - MDC[principal=KL, cid=937b2ab9-76bb-4751-8b4c-0907daec1b39]
java.lang.SecurityException: service registry does not contain a service of type pl.myapps.helloword.shared.security.ISqlAuthService
What else do I need to do to make it work?
[Updated on: Sat, 27 April 2019 14:51] by Moderator
FUDForum. Page generated in 0.05792 seconds
