Home » Language IDEs » ServerTools (WTP) » eclipse 3.2 tomcat5 server fails to start
eclipse 3.2 tomcat5 server fails to start [message #179344] Mon, 18 September 2006 20:43 Go to next message
I have create a server on eclipse 3.2 (tomcat5) to debug dynamic www
project against.
When a select my server in eclipse and choose "start" ... my server fails
to start and gives me the below error in my console tab:
Bootstrap: Class loader creation threw exception
java.lang.NoClassDefFoundError: org/apache/commons/logging/LogFactory
at org.apache.tomcat.util.compat.JdkCompat.<clinit>(JdkCompat.java:55)
at
org.apache.catalina.startup.ClassLoaderFactory.<clinit>(ClassLoaderFactory.java:63)
at
org.apache.catalina.startup.Bootstrap.initClassLoaders(Boots trap.java:103)
at org.apache.catalina.startup.Bootstrap.init(Bootstrap.java:19 6)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:40 2)
How can i fix this. The more details the better ... i have only really
used CDT.
Jim
Re: eclipse 3.2 tomcat5 server fails to start [message #179392 is a reply to message #179344] Tue, 19 September 2006 08:51 Go to previous messageGo to next message
Yes, "The more details the better...", like operating system, which
version of Tomcat, etc. Otherwise we have to guess.
Here is one guess. I have never encountered this on Windows, but I have
seen this on Linux using a packaged install of Tomcat. Does this match
your use case?
Larry
Jim wrote:
> Hello,
> project against.
> fails to start and gives me the below error in my console tab:
> at
> at
> used CDT.
> Cheers,
> Jim
Re: eclipse 3.2 tomcat5 server fails to start [message #179768 is a reply to message #179392] Sun, 24 September 2006 17:52 Go to previous messageGo to next message
> have
> match your use case?
> Cheers,
> Larry
> Jim wrote:
>> Hello,
>> project against.
>> at
I have this problem with Eclipse 3.2, WTP 1.5.0, tomcat5.0
Tomcat is from Debian Unstable, the remainder I downloaded today. The
setting occurs when I have eclipse create its own workspace for the
webapps (ie CATALINA_BASE in in .metadata/.plugins ... )
Re: eclipse 3.2 tomcat5 server fails to start [message #179775 is a reply to message #179768] Sun, 24 September 2006 18:39 Go to previous messageGo to next message
As an additional datapoint, adding the commons-logging.jar and
commons-logging-api.jar to the java runtime jre/lib/ext directory
caused tomcat5 to fail immediately, with the only message on the
console that it had terminated.
I have tried putting these two jars (or rather symbolic links to them)
in every directory I could think of (CATALINA_BASE/shared/lib.
CATALINA_HOME/server/lib and CATALINA_HOME/common/lib) but without
success.
Re: eclipse 3.2 tomcat5 server fails to start [message #179783 is a reply to message #179775] Mon, 25 September 2006 02:32 Go to previous messageGo to next message
>> The setting occurs when I have eclipse create its own workspace for
>> the webapps (ie CATALINA_BASE in in .metadata/.plugins ... )
> success.
And as a further datapoint, I worked my way through catalina.sh in the
CATALINA_HOME/bin directory (which is what Debian uses to start tomcat
itself) and saw that it was adding commons-logging-api.jar to an
initial CLASSPATH variable. So I editted the eclipse server
configuration under the Classpath tab to include it.
I now longer crashes out with the class not found error, but instead,
depending on how you edit the classpath either terminates with no error
message (add the jar to the user entry) or fails like this (adding the
jar to the bootstrap entry)
java.lang.ExceptionInInitializerError
at
at
Caused by: org.apache.commons.logging.LogConfigurationException:
java.lang.NullPointerException (Caused by
java.lang.NullPointerException) (Caused by
java.lang.NullPointerException))
at
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:543)
at
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:235)
at
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:209)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java :351)
... 4 more
at
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:397)
at
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:529)
... 8 more
at
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:374)
... 9 more
Re: eclipse 3.2 tomcat5 server fails to start [message #179818 is a reply to message #179783] Mon, 25 September 2006 10:36 Go to previous messageGo to next message
Hi Alan,
You have found the basic problem. In a normal Tomcat binary, the
bootstrap.jar includes a classpath in the MANIFEST.MF file it contains.
Packaged Tomcat installations for Linux tend to delete this
classpath in favor of using packaged installs of the dependencies, such
a commons-logging. You have also discovered that you have to modify the
classpath in the launch configuration within Eclipse to duplicate what
the catalina.sh was doing with respect to controlling the classpath.
Assuming this still isn't working, I would recommend undoing any
previous experiments. Then add commons-logging-api.jar to the classpath
as a User Entry in the Eclipse launch configuration. In the absence of
attempting anything with JDBC, this should get Tomcat starting normally.
Next, an appropriate location for the JDBC driver class should be found.
Since this is working in the production environment, where is it found
there? Is it in the webapp, or someplace else?
Larry
>> success.
> at
> at
> at
> at
> at
> ... 4 more
> at
> at
> ... 8 more
> at
> ... 9 more
Re: eclipse 3.2 tomcat5 server fails to start [message #179840 is a reply to message #179818] Mon, 25 September 2006 12:11 Go to previous messageGo to next message
Originally posted by: alan.chandler.logicacmg.com
On Mon, 25 Sep 2006 10:36:40 -0400, Larry Isaacs
This is what I did try doing - and in the console, I got a message
that tomcat had terminated - but NO other logging message See ...
>> message (add the jar to the user entry) ...
Maybe I am being a little unclear.
I have two computers - one a server, which is my "production"
(grandiose term for my home network:-) ) environment, running this
application from for a standard debian etch install, with a manually
edited server.xml file (in actual fact my whole web site is both
apache and tomcat - with apache frontending things and handling
security)
The other is a workstation, running debian unstable on which I have
also installed my eclipse environment (NOT debian packaged) and
another copy of tomcat (debian packaged) just for debugging.
My production environment is not involved in any issues now, but is a
working reference. Its just I found a bug in the application
"akcmoney" and want to return to my workstation and debug it.
On both systems the postgresql jdbc jar file is stored in
/usr/share/tomcat5/common/lib
After much trial and error, on my workstation, I have now manually
loaded up a war file in /var/lib/tomcat5/webapps, manually setup
/usr/share/tomcat5/conf/Catalina/localhost/akcmoney.xml and started
tomcat manually. In that case, I can now access the application and
see that it has successfully read the database. So my key issue seems
to be how to get tomcat5 to see the context.
So apart from the problem that I cannot get eclipse to start a tomcat
instance (as explained in my previous message and refered to the very
top of this message), I am then puzzled as to how to get eclipse to
create a context in subdirectory of conf. (theoretically I should be
able to put it into server.xml - but that hasn't worked for reasons I
don't really understand - but it might be that was when I had a
freshly downloaded - not debian - copy of tomcat 5.5, and there seems
to have been a change in 5.5.12 that stopped server.xml working
correctly)
Re: eclipse 3.2 tomcat5 server fails to start [message #179873 is a reply to message #179840] Mon, 25 September 2006 12:56 Go to previous messageGo to next message
In spite of this, I think this is the best approach. Other approaches,
though they may have more log output, may introduce other problems, like
adding commons-logging-api.jar to the Bootstrap Entry. We may have to
dig a bit for clues.
> security)
> correctly)
Thanks for the extra detail. The Tomcat support in Web Tools only uses
Context declarations in server.xml. For all the versions that it
supports, which includes Tomcat 3.2, this is the only way that works in
all of them. I'm not yet sure what can be done in Web Tools 2.0 to
change this. The behavior of these other approaches, such as files in
"conf/Catalina/localhost", has changed over time and would complicate
writing and maintaining such code.
I'll be glad to try to explain why things are behaving the way they are
and how to fix, but the more I have to assume and infer, the less likely
I'll be on target. I have been assuming that "Run modules directly..."
is checked in the Tomcat server editor and that your Tomcat runtime and
server are tied to a version of Tomcat 5.0.x. This last fact was based
the syntax of your datasource declaration which is Tomcat 5.0.x'sh, i.e.
uses child elements for parameters. This has changed in Tomcat 5.5.x
where datasource declarations use attributes to specify parameters. The
next thing to confirm, which may have done already, is to confirm which
version of Tomcat is being used in Eclipse environment.
Larry
Re: eclipse 3.2 tomcat5 server fails to start [message #179881 is a reply to message #179873] Mon, 25 September 2006 14:22 Go to previous messageGo to next message
>>> classpath
>>> of attempting anything with JDBC, this should get Tomcat starting
>>> normally.
> approaches, though they may have more log output, may introduce other
> problems, like
Slight delay whilst I travelled from work to home - in the UK round the
M25 solid traffic jams :-(
OK, so I have changed the server classpath to include
commons-logging-api.jar in the user entry
> are and how to fix, but the more I have to assume and infer, the less
> likely
> directly..." is checked in the Tomcat server editor and that your
Correct
> Tomcat runtime and
> based the syntax of your datasource declaration which is Tomcat
> 5.0.x'sh, i.e.
Yes - its tomcat 5.0.30
I think that is another reason why I had no success with 5.5 - I hadn't
picked up the change. Anyway, my 5.5 configuration is GONE.
> The next thing to confirm, which may have done already, is to confirm
> which version of Tomcat is being used in Eclipse environment.
As above, its 5.0.30
Re: eclipse 3.2 tomcat5 server fails to start [message #179896 is a reply to message #179881] Mon, 25 September 2006 15:30 Go to previous messageGo to next message
At this point, I would recommend removing all added projects from the
server and see if it will start and stop without problems. If you have
your datasource(s), or other context configuration, declared in the
server.xml, save a copy of this configuration somewhere (a commented
copy in server.xml would be fine) so this configuration isn't lost when
the projects are removed.
Larry
P.S. I have a Laptop running SUSE 10 that I may be able to attempt
something similar tonight, and see what I run into.
>>>> classpath
>>>> normally.
>> problems, like
>> likely
> Correct
>> Tomcat runtime and
>> 5.0.x'sh, i.e.
Re: eclipse 3.2 tomcat5 server fails to start [message #179904 is a reply to message #179896] Mon, 25 September 2006 16:13 Go to previous messageGo to next message
> have your datasource(s), or other context configuration, declared in
> the server.xml, save a copy of this configuration somewhere (a
> commented copy in server.xml would be fine) so this configuration
> isn't lost when the projects are removed.
Unfortunately when I do that it still doesn't work.
But don't spend to much urgent time on it - I am away on business for
the rest of the week from tomorrow morning, so can't do anything about
anything until next Saturday.
Worse comes to worse, I will use a fresh tomcat install rather than the
debian package.
Re: eclipse 3.2 tomcat5 server fails to start [message #179912 is a reply to message #179904] Mon, 25 September 2006 16:41 Go to previous messageGo to next message
I'll wait to hear from you again. A regular Tomcat binary shouldn't have
problems. There could be oddities with the debian package that are
causing issues with Web Tools. It isn't one I've looked into.
> debian package.
Re: eclipse 3.2 tomcat5 server fails to start [message #179920 is a reply to message #179912] Mon, 25 September 2006 17:27 Go to previous messageGo to next message
> have
Just one thought I have been having is whether its a file permissions
problem. I just tried the same thing with the sysdeo tomcat plugin,
and it too needed commons-logging-api.jar to be specified as an
additional element for tomcat's classpath. When it tried to start
tomcat it failed with lots of permission denied writing
to /usr/share/tomcat5/work/... directories.
Re: eclipse 3.2 tomcat5 server fails to start [message #179936 is a reply to message #179920] Mon, 25 September 2006 18:53 Go to previous messageGo to next message
>> have
This is one of the advantages of the separate instance approach. The
Tomcat server in Web Tools doesn't need permission for this "work"
directory, and others. I don't recall having permission issues with
SUSE 10 and its packaged Tomcat if "Run modules directly..." was
checked. Only if it was unchecked did I run into this issue.
Re: eclipse 3.2 tomcat5 server fails to start [message #181754 is a reply to message #179936] Fri, 20 October 2006 01:08 Go to previous messageGo to next message
Originally posted by: jaguar_fender.yahoo.com
>>> have
I experience the same problem as Alan Chandler. Does that means there's
no viable solution for using Debian Tomcat5 package and start it in Eclipse?
PS. i use Eclipse 3.2 (download) + Tomcat5 package on Ubuntu
any suggestions?
Thx in advance.
Re: eclipse 3.2 tomcat5 server fails to start [message #181756 is a reply to message #181754] Fri, 20 October 2006 08:30 Go to previous message
Hi Gilbert,
I'd first suggest that you start a new thread since inferring specifics
about your situation from the prior posts could be misleading. I'd be
curious to know which version of Ubuntu and whether you are trying to
run with "Run modules directly..." checked or unchecked.
Larry
Gilbert wrote:
>>>> have
> Eclipse?
> any suggestions?
> Thx in advance.
Previous Topic:struts and WTP
Next Topic:provisionaldefinition
Current Time: Wed Jul 23 08:16:49 EDT 2025
Powered by FUDForum. Page generated in 0.09901 seconds
