Home » Language IDEs » C / C++ IDE (CDT) » No source file named main.cpp((compared with NetBeans))
No source file named main.cpp [message #792881] Tue, 07 February 2012 09:24 Go to next message
Dear All,
Recently I experienced very common problem with
"No source file named /home/.../main.cpp."
With "Stop on startup at: main", gdb stops in main, but if I now try to add a breakpoinst there, I get this error.
If I have any breakpoints set up anywhere else (even in main.cpp) and I hit "Resume" - gdb does not stop there.
That's what I see in gdb traces:
193,524 23-break-insert --thread-group i1 -f /home/.../src/main.cpp:29
193,544 &"No source file named /home/.../src/main.cpp.\n"
193,545 23^done,bkpt={number="3",type="breakpoint",disp="keep",enabled="y",addr="<PENDING>",pending=\
"/home/.../src/main.cpp:29",times="0",original-location="/home/.../src/main.cpp:29"}
193,545 (gdb)
My project is made from existing sources and is compiled with "-g" option from a Makefile.
In "Debug Configurations->Source" I tried different configurations, as well as including just a FileSystem Dirrectory. Nothing helps.
The program runs from a folder other than one it is compiled in, if that matters.
In order to be sure that it does not depend on my Makefile or external libs compiled with/withot "-g", I installed NetBeans and compiled it with the same Makefile and run with a same command in the same folder. And it does indeed work there, no errors from dgb when I add breakpoints.
So I can conclude that it must have something to do with settings in Eclipse. Or maybe a bug?
Could you please advise where to look at and what to check?
Another thing is when I open a main.cpp from the "Project Explorer" it shows the file as "my_project/main.cpp", whereas if I debug it, I see "/home/.../main.cpp".
Thank you in advance for your help.
p/s/ Eclipse version is:
Version: Indigo Service Release 1
Build id: 20110916-0149
p/p/s/ I can access GDB logs from both NetBeans and Eclipse, but I have absolutely no experience with GDB...
[Updated on: Tue, 07 February 2012 09:39] by Moderator
Re: No source file named main.cpp [message #792900 is a reply to message #792881] Tue, 07 February 2012 09:50 Go to previous messageGo to next message
> matters.
It does matter.
Re: No source file named main.cpp [message #792977 is a reply to message #792900] Tue, 07 February 2012 11:23 Go to previous messageGo to next message
Hagen wrote on Tue, 07 February 2012 09:50
> matters.
It does matter.
Well, that is the case for both NetBeans and Eclipse.
So, which settings do I need to check in order to make Eclipse work as expected?
[Updated on: Tue, 07 February 2012 11:23] by Moderator
Re: No source file named main.cpp [message #793478 is a reply to message #792977] Wed, 08 February 2012 02:23 Go to previous messageGo to next message
> expected?
In order to find the correct sources, debugger and debug IDE (gdb? and
Eclipse) BOTH must have the same understanding about where they are.
The debugger gets the info from the binary file.
Eclipse gets the info from the local project settings.
As I see it, you will have either to compile from a path within an
Eclipse project, or convince Eclipse to work with a different path.
[With the information you supplied nobody can answer your question.
No offense, but personally, I'd recommend to read, understand, and
follow the advice Eric Steven Raymond gives in "How To Ask Questions The
Smart Way". You get answers much faster. And useful ones.]
Re: No source file named main.cpp [message #793501 is a reply to message #793478] Wed, 08 February 2012 03:08 Go to previous messageGo to next message
Hagen wrote on Wed, 08 February 2012 02:23
> expected?
Probably I did not make it clear before, but I compile from the path WITHIN the eclipse project. And I don't move binary file afterwards, I just specify Debug settings "Working directory" as something external. That's it.
So, judging from the Eclipse GUI that functionality should already be there.
[thank you for your advice. No offense, but the last time I asked a similar question with regards to another C++ IDE led to a bug filling and an update in the IDE. Actually another question of mine already led to a bug fix in PTP Eclipse, so it's not the first time I ask questions on-line...]
[Updated on: Wed, 08 February 2012 03:28] by Moderator
Re: No source file named main.cpp [message #793554 is a reply to message #793501] Wed, 08 February 2012 04:30 Go to previous messageGo to next message
Do you use the DSF debugger interface in Eclipse ?(see http://wiki.eclipse.org/CDT/User/FAQ#How_can_I_choose_another_debugger_integration_for_CDT.3F )
I would advise to do so if not.
What are your settings in Debug Configuration->Source tab for the Source lookup path? I usually use here "Absolute File Path" only.
Re: No source file named main.cpp [message #793574 is a reply to message #793554] Wed, 08 February 2012 04:56 Go to previous messageGo to next message
Axel Mueller wrote on Wed, 08 February 2012 04:30
Thank you for your advices.
Yes, I do have DSF interface used ("Using GDB(DSF) Create Process Launcher").
In Configuration->Source tab I had several options: a) Default b) path to the src's (only). If I use only "Absolute File Path" I have another error:
Can't find a source file at "main.cpp"
Locate the file or edit the source lookup path to include its location.
If I do "Locate File" and point to "main.cpp" the screen flickers but nothing changes, nothing in logs.
I don't see any errors in GDB traces.
Re: No source file named main.cpp [message #793681 is a reply to message #793574] Wed, 08 February 2012 07:34 Go to previous messageGo to next message
Hm, that is weird. OK, then try to add "Compilation directory".
Re: No source file named main.cpp [message #793704 is a reply to message #793681] Wed, 08 February 2012 08:04 Go to previous messageGo to next message
Axel Mueller wrote on Wed, 08 February 2012 07:34
Thank you for your help, it works now.
Somehow Default inclusion of project folder with its sub-folders didn't work.
Sub-folders have some duplicated files which are not used in compilation, but it is definitely not the reason since I tried adding "Compilation directory" with sub-folders and it also works with no problems.
[Updated on: Wed, 08 February 2012 08:04] by Moderator
Re: No source file named main.cpp [message #1057869 is a reply to message #792881] Thu, 09 May 2013 08:51 Go to previous messageGo to next message
Another hint, why you can get message "No source file named yourname.c.".
Imagine, the project consists of many source files and only some of them are linked together into resulting executable file.
If your yourname.c is not the one, that is linked to the resulting executable, then when you start a debugging and put a breakpoint into such file, it will result in the message "No source file named yourname.c.".
Re: No source file named main.cpp [message #1737567 is a reply to message #792881] Sun, 10 July 2016 05:15 Go to previous messageGo to next message
HI I had encountered a similar problem with db . I just deleted .metadata folder and imported the particular project again and that solved it . could be a bug with eclipse. i had multiple projects in workspace and the main.c that it was looking was for a different project.
Re: No source file named main.cpp [message #1747529 is a reply to message #1737567] Tue, 15 November 2016 11:31 Go to previous messageGo to next message
This can happen if you have both cygwin and mingw (or some other variant). If gcc from cygwin is used to compile the source you'll have cygwin path in executable. Then, if the debugger is from mingw, gdb will not be able to interpret the cygwin path. The easiest way to solve this is to go to Run -> Debug Configurations -> Debugger and set full path to cygwin gdb (C:\cygwin64\bin\gdb.exe). That solved the problem for me.
Re: No source file named main.cpp [message #1797692 is a reply to message #792881] Mon, 05 November 2018 04:40 Go to previous message
I just had a similar problem in Eclipse Oxygen CDT: I'm trying to debug code from a shared library built from outside Eclipse and CDT kept telling me that it could not find source files, even if I imported them inside an Eclipse project that is the only open one in the current workspace.
The library source code is split in several directories: "/src", "/lib" and "/include".
I was able to resolve the issue by specifying several "Path mappings" from the paths in the debug info of the library files (these were paths under "/tmp/", which is were the compilation took place) to the actual source paths.
Previous Topic:Synchronized C/C++ Project
Next Topic:Eclipse, CDT, clang, Windows - Need help for install/configure
Current Time: Sat Jul 26 03:43:41 EDT 2025
Powered by FUDForum. Page generated in 0.05789 seconds
