Project Structure matching Filesystem Structure [message #1797511] |
Wed, 31 October 2018 21:09  |
I've been working with Eclipse for a few years now but only recently have started to work on very large projects with eclipse (with hundreds of subprojects / pom.xml). But, I just can't seem to get Eclipse to organize my workspace in a way that makes any kind of sense at all. Why is it so hard?
So, with these big projects I am working on, they are broken up into lots of subprojects. So for example, the structure on my filesystem is as follows:
Project
-Subproject1
-Subproject1.1
src/java/foo/bar/...
pom.xml
-Subproject1.2
pom.xml
-Subproject1.3
src/java/foo/oof/...
pom.xml
pom.xml
-Subproject2
-Subproject2.1
src/java/com/test/...
pom.xml
-Subproject2.2
pom.xml
-Subproject2.3
pom.xml
pom.xml
pom.xml
This is great. It makes perfect sense to me and I can understand the flow perfectly. However, Eclipse just for whatever reason refuses to organize the projects like this. Instead, it wants to do this....
Project
Subproject1
Subproject2
Subproject1.1
Subproject1.2
Subproject1.3
Subproject2.1
Subproject2.2
Subproject2.3
It doesn't look too bad when there is only this small amount, but you must keep in mind that when I have ~400 projects/subprojects like this, all sorted alphabetically, it becomes impossible to keep track of what code is where.
I've been able to get the workspace layout to mirror the file system, by only importing the root level pom.xml. However, whenever I do that I lose all actual eclipse functionality - whenever I try to do anything I'm told "The resource is not on the build path of an eclipse project".
Why? That just makes things extremely confusing for me. Why can't eclipse just mirror what's on my file system? Is there any way to get eclipse to do this without losing any eclipse functionality or duplicating projects in the workspace?
HELP!
[Updated on: Wed, 31 October 2018 22:01] by Moderator
FUDForum. Page generated in 0.12800 seconds
