Home » Modeling » TMF (Xtext) » Error creating Xtext artefacts(Errors with DSL)
Error creating Xtext artefacts [message #1797003] Tue, 23 October 2018 15:56 Go to next message
I made the following DSL (attached file) with Xtext. My problem is the error message. This message names a couple of unreachable options concerning the definitions of datatypes. I need all of them.
I've read a lot here in the forum. But I couldn't find the right solution.
Cheers
  • Attachment: DSL.txt
    (Size: 4.01KB, Downloaded 111 times)
Re: Error creating Xtext artefacts [message #1797290 is a reply to message #1797003] Mon, 29 October 2018 11:16 Go to previous messageGo to next message
Please read the advice in this blog post:
https://blogs.itemis.com/en/debugging-xtext-grammars-what-to-do-when-your-language-is-ambiguous
In general, you are trying to do too much by terminal rules and should use datatype parser rules to avoid ambiguity of terminal symbols.
Re: Error creating Xtext artefacts [message #1797362 is a reply to message #1797290] Tue, 30 October 2018 06:22 Go to previous messageGo to next message
Hello Karsten,
Thanks for your reply!
I tried to solve the problems with datarules. But I had the same problem.
Do you have an advice, which part I can cover with datarules?
Cheers
Re: Error creating Xtext artefacts [message #1797370 is a reply to message #1797362] Tue, 30 October 2018 08:00 Go to previous messageGo to next message
You can combine tokens to datatype rules. See QualifiedName rule from Xtype.xtext for example.
Re: Error creating Xtext artefacts [message #1797372 is a reply to message #1797370] Tue, 30 October 2018 08:23 Go to previous message
see https://blogs.itemis.com/en/xtext-hint-identifiers-conflicting-with-keywords as well
Previous Topic:Code generator conditional behaviour
Next Topic:Code Completion / Content Assist not working for second grammer
Current Time: Fri Sep 26 16:36:25 EDT 2025
Powered by FUDForum. Page generated in 0.08865 seconds
