Builtin LFS problem [message #1797354] |
Tue, 30 October 2018 04:42  |
I have a problem when i run the first Obeo designer community, In the console, it writes a java.lang.ClassNotFoundException.
I have started my project with the version 10.1 of obeo designer community. Now, i use the 11.0 version and in the console, it writes this :
!ENTRY org.eclipse.egit.core 2 0 2018-10-30 08:43:43.044
!MESSAGE Builtin LFS support not present/detected
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.jgit.lfs.BuiltinLFS cannot be found by org.eclipse.egit.core_5.0.0.201806131550-r
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:508)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:419)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:411)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.eclipse.egit.core.Activator.registerBuiltinLFS(Activator.java:279)
at org.eclipse.egit.core.Activator.start(Activator.java:212)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1002)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:354)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:114)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:505)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:392)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:454)
at org.eclipse.egit.ui.Activator$RepositoryChangeScanner.<init>(Activator.java:921)
at org.eclipse.egit.ui.Activator.setupRepoChangeScanner(Activator.java:1034)
at org.eclipse.egit.ui.Activator.start(Activator.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:470)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:609)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:177)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:931)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:60)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:174)
at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:104)
at org.eclipse.ui.internal.Workbench$34.runWithException(Workbench.java:2378)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4567)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:95)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:2373)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1654)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2859)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
at org.eclipse.equinox.launcher.Main.main(Main.java:1471)
Someone have an idea for my problem ?
I thank you in advance,
Romain Launay
Re: Builtin LFS problem [message #1797358 is a reply to message #1797354] |
Tue, 30 October 2018 06:09  |
This is an issue in EGit itself, the graphical integration for working with Git in Eclipse, that we install by default in Obeo Designer. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=535954.
It has no actual impact on how the product works, even on EGit itself. It is just a "noisy" way for EGit to tell the user that some of its optional functionality is not installed.
In the recently released Obeo Designer CE 11.1.0 (which includes Sirius 6.1.0), we've included EGit 5.0.3 (instead of 5.0.0 which was released with Photon and has the bug) to avoid this message.
If you really need to stay on Obeo Designer 11.0 for some reason, you can try to explicitly install the JGit LFS support from http://download.eclipse.org/releases/photon/ to silence the warning.
FUDForum. Page generated in 0.03718 seconds
