Home » Modeling » TMF (Xtext) » How to Customize output directory of code generation(Xtext src-gen path customization)
How to Customize output directory of code generation [message #1797112] Thu, 25 October 2018 08:28 Go to next message
Hi ,
I have use case where i need to generate the code generation files from the xtext model at outside the src-gen folder of the project, is it possible to generate the code generation files outside the src-gen folder.
I configured my generator class inside the runtime module and when i do clean build project, it always create the src-gen folder and generate the code inside it.
How to customize it.
Thank you
Re: How to Customize output directory of code generation [message #1797113 is a reply to message #1797112] Thu, 25 October 2018 08:33 Go to previous message
Hi please look for the terms outlet (second param of the 3 param generateFile method )
And IOutputConfiguration(Provider)
Previous Topic:New file/project wizard name validation
Next Topic:I need to invoke full_build or incremental build using project.build() function in new thread
Current Time: Wed Sep 24 02:02:59 EDT 2025
Powered by FUDForum. Page generated in 0.04793 seconds
