| The problems occurs when I follow the Acceleo Getting Started guidance in the wiki to generate java  [message #1797083] |
Wed, 24 October 2018 23:31   |
Eclipse User  |
Hello, I spend several days to follow the Getting Started guidance in the wiki to generate java code from uml. I found some problems during the steps and failed to generate code. This is the link of the guidance I followed: https://wiki.eclipse.org/Acceleo/Getting_Started.
The first question is: when I Right-click on the Acceleo module file (that is, the generate.mtl file) and select Run As > Launch Acceleo Application. I can't find the uml model imformation, and also with the Target.
The second question is the problem shown in the acceleo when I finished all the step in the getting start guidance.
1). Description	Resource	Path	Location	Type
Cannot find operation (generate()) for the type (Class)	uml2beans.mtl	/org.eclipse.acceleo.module.sample/src	line 9	Acceleo Problem
2).Description	Resource	Path	Location	Type
Module org::eclipse::acceleo::module::sample::files::generate not found.	uml2beans.mtl	/org.eclipse.acceleo.module.sample/src	line 4	Acceleo Problem
3)Description	Resource	Path	Location	Type
The method Uml2beans(EObject, File, List<capture#4-of ? extends Object>) is undefined for the type GenerateAll	GenerateAll.java	/org.eclipse.acceleo.module.sample.ui/src/org/eclipse/acceleo/module/sample/ui/common	line 89	Java Problem
 In case you can recurrent the problems, I'll show you the version of eclipse and acceleo I use.
 Eclipse IDE: 2018-9(4.9.0)
Acceleo:3.7.6201810050
Could you show me how to operate correctly to avoid these problems or is there any problems in my installation?
Thankyou!
FUDForum. Page generated in 0.06433 seconds
