Home » Newcomers » Newcomers » newbie eclipse + cvs question
newbie eclipse + cvs question [message #179532] Sat, 11 November 2006 02:29 Go to next message
I am a newbie to both eclipse and CVS. How do I release a milestone of a
project to CVS using Eclipse?
The most current code base has all been committed into the HEAD already, but
before more changes are made to it, I would like to have then entire code
base frozen into a milestone. How do I do that using Eclipse? Thanks.
- Jim
Re: newbie eclipse + cvs question [message #179599 is a reply to message #179532] Sat, 11 November 2006 19:59 Go to previous messageGo to next message
Are you working alone, or are you constrained (condemned) to CVS? If you
have a choice and are early in the process, I suggest (at risk of being
flamed alive) that you consider Subversion. It is conceptually easier than
CVS and can easily be integrated with Eclipse with the Subclipse plugins.
On 11/11/06 12:29 AM, in article ej3u3t$i4j$1@utils.eclipse.org, "Jim Bear"
> - Jim
Re: newbie eclipse + cvs question [message #179645 is a reply to message #179532] Sat, 11 November 2006 21:39 Go to previous messageGo to next message
It sounds like you want to create a Tag (aka, label). In Eclipse,
right-click the project(s) and choose Team > Tag As Version.
You should read up on Tags and Revisions at the CVS Wiki:
http://ximbiot.com/cvs/wiki
Hope this helps,
Eric
Re: newbie eclipse + cvs question [message #179694 is a reply to message #179599] Sun, 12 November 2006 14:04 Go to previous messageGo to next message
Unfortunately I am not working alone. The project was inherited from some
one (not my rich uncle, because I ain't got one), and CVS is what we use :(
"J Michael Dean" <mdean77@comcast.net> wrote in message
news:C17BC01F.18FAB%mdean77@comcast.net...
> than
> Bear"
>> but
>> - Jim
Re: newbie eclipse + cvs question [message #179702 is a reply to message #179645] Sun, 12 November 2006 14:07 Go to previous message
Hi Eric,
Thank you for tirelessly answering my newbie questions. I will read up on
CVS :)
-- Jim
"Eric Rizzo" <eclipse4@rizzoweb.com> wrote in message
news:ej61he$nqr$1@utils.eclipse.org...
>> but before more changes are made to it, I would like to have then entire
>> code base frozen into a milestone. How do I do that using Eclipse?
>> Thanks.
> Hope this helps,
> Eric
Previous Topic:Setting the webserver in eclipse
Next Topic:SWT Deployment
Current Time: Fri Nov 21 07:18:05 EST 2025
Powered by FUDForum. Page generated in 0.09464 seconds
