How to restore default value after setting a css property [message #1796128] |
Fri, 05 October 2018 10:17  |
I need to set and unset CSS property.
To set a property I use the NatTableCSSHandler and it works fine. However, I also need to unset the property, I would like to restore the default theme for one or many property even for all properties if possible.
My first idea was to use the NatTableCSSHandler.applyCSSProperty with a null value but it doesn't works for me since I get back an exception. I try to change the theme (using nattable.setTheme()) but apparently the css override the theme. I don't know how to do that.
Do you have any idea that can help me to do this ?
Pauline
FUDForum. Page generated in 0.19056 seconds
