Home » Eclipse Projects » NatTable » How to configure the borderline of ColumnGroups(Theme Configuration Column Group)
How to configure the borderline of ColumnGroups [message #1796833] Fri, 19 October 2018 11:25 Go to next message
How can the borderline between two column groups be configured?
I tried something similar to what I do for the body layer: Using CustomLineBorderDecorator.LEFT_LINE_BORDER_LABEL in the flag accumulator.
BTW The helpful Debug menu configuration (new DebugMenuConfiguration(natTable)) seems to no be enabled for the header?
Re: How to configure the borderline of ColumnGroups [message #1796839 is a reply to message #1796833] Fri, 19 October 2018 12:05 Go to previous messageGo to next message
Well I would say what you are trying should do what you want. Maybe the painters are not configured correctly?
And IIRC the DebugMenuConfiguration contains a binding that only works for the body region. Maybe you can override the binding to also work in the header region
Re: How to configure the borderline of ColumnGroups [message #1798534 is a reply to message #1796839] Tue, 20 November 2018 04:01 Go to previous message
I have found the problem.
We use a theme configuration and I forgot to set the CustomLineBorderDecorator for the cHeaderCellPainter and for the cGroupHeaderCellPainter.
Thank you again for your help.
Previous Topic:Coloring grid lines with GridLineCellLayerPainter
Next Topic:How to use CellPainterDecorator class
Current Time: Mon Jun 16 22:54:23 EDT 2025
Powered by FUDForum. Page generated in 0.40931 seconds
