Home » Modeling » EMF » [EcoreGen] State-of-the-art way to generate code from Ecore in Maven?
[EcoreGen] State-of-the-art way to generate code from Ecore in Maven? [message #1796398] Fri, 12 October 2018 07:29 Go to next message
Hi all,
I'm working on a product with several projects, each containing one ecore model. These models depend on one another (without circles). Within Eclipse, I can generate the code by manually running the generator on each genModel.
However, automating this using Maven has proven to be a challenge.
I've found multiple posts that are closely related to my problem, such as:
https://www.eclipse.org/forums/index.php/t/202345/, a post describing to use an Ant task.
I've also come across mentions of running a headless eclipse version to generate the required code, but no clear documentation on how to get started with that.
Since the posts I found are from ~2010 or earlier, my question is as follows: is that Ant task (or the headless eclipse solution) still the preferred solution, or is there something newer that I've missed? Might an MWE2 workflow be helpful?
Thanks a lot.
Re: [EcoreGen] State-of-the-art way to generate code from Ecore in Maven? [message #1796400 is a reply to message #1796398] Fri, 12 October 2018 08:13 Go to previous messageGo to next message
Yes. I use an MWE2 workflow for all (nearly 20) OCL and QVTd models. MWE2 is good. Don't use Ant.
See http://git.eclipse.org/c/ocl/org.eclipse.ocl.git/tree/examples/org.eclipse.ocl.examples.build/src/org/eclipse/ocl/examples/build/GenerateCGModels.mwe2 for a comparatively simple script.
NB. I keep all the scripts in a separate build plugin to avoid polluting production plugins with redundant build dependencies that can contribute to build cycles and consequently long build times.
I prefer to invoke scripts manually from launches since I want generated Java to be committed to GIT for ease of use by simple checkout. Also I am dubious of the benefits of uncontrolled regeneration whenever tools evolve. e.g. first milestones of a next Xtext quite often throw up a compatibility issue. Xtext does not provide the required forward AND backward compatibility necessary to guarantee compatibility of newly generated editors by old platforms. EMF does, provided you select a low runtime compatibility.
Ed Willink
Re: [EcoreGen] State-of-the-art way to generate code from Ecore in Maven? [message #1796487 is a reply to message #1796400] Mon, 15 October 2018 04:25 Go to previous messageGo to next message
Hi Ed,
Thank you for your thorough answer!
If I read and understand the script correctly, I'd have to write my own variant of the EcoreGenModelSetup/GenerateModel classes as necessary for the project(s)?
Jan
Edit:
I've actually got it working with the following workflow:
Workflow {
    bean = org.eclipse.xtext.ecore.EcoreSupport {}
    bean = ResourceSetImpl : resourceSet {}
    bean = StandaloneSetup { resourceSet = resourceSet
    	platformUri = "${rootPath}"
    	scanClassPath = true
    component = org.eclipse.emf.mwe2.ecore.EcoreGenerator {
		genModel = "platform:/resource/${projectName}/model/ModelName.genmodel"
		srcPath = "platform:/resource/${projectName}/emf-gen"
Thanks again Ed!
[Updated on: Mon, 15 October 2018 05:07] by Moderator
Re: [EcoreGen] State-of-the-art way to generate code from Ecore in Maven? [message #1796727 is a reply to message #1796487] Thu, 18 October 2018 03:48 Go to previous message
Thanks for bringing the 'new' MWE2 classes to my attention. I've raised
https://bugs.eclipse.org/bugs/show_bug.cgi?id=540239
to try and bring the best of both worlds together.
Ed Willink
Previous Topic:Modern automated code generation from ecore model
Next Topic:[CDO] How does CDOResourceNode.setFolder(...) work?
Current Time: Sun May 11 14:38:26 EDT 2025
Powered by FUDForum. Page generated in 0.05131 seconds
