Usability of Editor for Information Models, Function Blocks [message #1796514] |
Mon, 15 October 2018 11:21  |
We have seen that the Usability of the DSL Editor (e.g. code completion) would be very important to us (since non-programmers would use it for modeling the information models and they need as much support from the editor as possible).
We generally see a benefit of using a Web-based editor compared to an Eclipse-Plugin since nothing has to be installed locally and it can be integrated nicely with workflows and persistence.
In our context, the following features would be useful for the Web-Editor that are currently missing:
- DSL Web-Editor with auto code completion and related features (similar features that were available in the Vorto Eclipse Plug-In)
- Drag and drop of existing artifacts such that non-programmers just could take the existing function blocks and drag&drop them to a new device information model without having to care much for the DSL. --> Similar to what was available in the Vorto Eclipse Plug-In.
- Functionality to define templates of information models and function blocks that then can be customized by other persons.
The Vorto Project plans to make use of an LSP protocol enabled web-editor (such as Monarch editor or similar).
What is the Vorto Project's timeline on adding an LSP based editor to the Web-application and has the Vorto project already evaluated LSP based editors?
Are ther any plans on adding drag and drop functionality or template support to the Web-Application?
Thanks and best regards, Andri
Re: Usability of Editor for Information Models, Function Blocks [message #1796728 is a reply to message #1796685] |
Thu, 18 October 2018 03:59  |
Hi Andri,
interesting idea and it sounds quite useful. We currently support new versions of an existing model, which basically creates the model and dumps the content of the referenced model in there but the only variable here is the version number. But I guess what you want (correct me if I am wrong), is that you create new model with a selected model as its base , and giving it a complete new name , namespace and version , right ? Then the user can start off from a model with some content and just modify it. I agree, for FBs , the behaviour would be different whereby the template would create a new model and extends the base model instead of dumping the content of the base model. I hope i am getting this right :)
FUDForum. Page generated in 0.05746 seconds
