Home » Eclipse Projects » Oomph » http://download.eclipse.org/releases/neon/ site is not stable.(http://download.eclipse.org/releases/neon/ and oxygen sites are not stable and sometimes it is giving This site can’t be reached. )
http://download.eclipse.org/releases/neon/ site is not stable. [message #1796552] Tue, 16 October 2018 00:35 Go to next message
Eclipse mirror site URLs
http://download.eclipse.org/releases/oxygen/
are not stable from 16/10/2018 onwards.
Re: http://download.eclipse.org/releases/neon/ site is not stable. [message #1796641 is a reply to message #1796552] Tue, 16 October 2018 15:44 Go to previous messageGo to next message
We have resolved the issue.
Re: http://download.eclipse.org/releases/neon/ site is not stable. [message #1799081 is a reply to message #1796641] Thu, 29 November 2018 10:18 Go to previous messageGo to next message
Strange. We're using http://download.eclipse.org/releases/oxygen/ as a location for our target platform. In a build that is run on a Hudson build slave on an AWS EC2 instance, in two consecutive runs we see the first access to the p2 repository succeeding:
[INFO] Fetching p2.index from http://download.eclipse.org/releases/oxygen/
[INFO] Adding repository http://download.eclipse.org/releases/oxygen
[INFO] Fetching compositeContent.jar from http://download.eclipse.org/releases/oxygen/ (502B)
[INFO] Fetching p2.index from http://download.eclipse.org/technology/epp/packages/oxygen/
[INFO] Fetching content.xml.xz from http://download.eclipse.org/technology/epp/packages/oxygen/
[INFO] Fetching p2.index from http://download.eclipse.org/releases/oxygen/201804111000/
[INFO] Fetching content.xml.xz from http://download.eclipse.org/releases/oxygen/201804111000/ (863.03kB)
Then in a second part of the build job we keep getting:
[ERROR] Failed to resolve target definition /home/hudson/workspace/SAPSailingAnalytics-docker/java/com.sap.sse.common/../com.sap.sailing.targetplatform/definitions/race-analysis-p2-local.target: Failed to load p2 metadata repository from location http://download.eclipse.org/releases/oxygen: Unable to read repository at http://download.eclipse.org/releases/oxygen. Unable to read repository at http://download.eclipse.org/technology/epp/packages/oxygen/content.xml.xz. connect timed out -> [Help 1]
When the instance was in this state, also a wget for http://download.eclipse.org/technology/epp/packages/oxygen/content.xml.xz would time out whereas the same wget from some other network worked.
Are there any rules in place that could lead to subsequent accesses to the p2 update site coming from the same IP address being blocked? This would really be a problem...
Re: http://download.eclipse.org/releases/neon/ site is not stable. [message #1799100 is a reply to message #1799081] Thu, 29 November 2018 12:20 Go to previous message
This isn't really an Oomph question. In any case, part of such problem is that the download.eclipse.org server transparently redirects requests for repository metadata to mirrors. You can't control this because it's simply server behavior. Depending on where you are located (mostly the time zone) and perhaps on other non-deterministic factors of where the server redirects, you may be redirected to a mirror server that's having problems, or has stale content as in this bug that I still have open:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=539316
The stale content issue is highly reproducible. In any case, mostly transparent mirror redirection is good to help keep download.eclipse.org from being overwhelmed, but it can and does also cause problems because the mirror to which the server redirects can have problems too...
Previous Topic:How do I develop/debug an oomph setup Task
Next Topic:Getting Install location after install is finished from cmd file
Current Time: Sat Jul 26 23:17:33 EDT 2025
Powered by FUDForum. Page generated in 0.03948 seconds
