Home » Language IDEs » ServerTools (WTP) » how to read a WSDL file without using internal classes?
how to read a WSDL file without using internal classes? [message #179529] Thu, 21 September 2006 07:49 Go to next message
I want to use WST to analyse WSDL files. The only way I found to read a WSDL file was adding
org.eclipse.wst.wsdl.internal.util.WSDLResourceFactoryImpl to the ResourceSet's Resource.Factory.Registry.
Since this is an internal package name I was wondering if there are other ways to get it done.
Michael
Re: how to read a WSDL file without using internal classes? [message #179536 is a reply to message #179529] Thu, 21 September 2006 07:57 Go to previous messageGo to next message
Michael,
I assume you are running standalone, because I'm pretty sure this
factory is registered to handle *.wsdl via a plugin.xml registration. If
you are running standalone, you need to do such registrations
explicitly, since plugin.xml registration won't take place. In that
case, there might not be any other way than to use this directly. It
seems odd to make something like this internal; I didn't make the
XSDResourceFactoryImpl internal for the XSD model and you'll likely need
that too if your WSDLs imports schemas.
Michael Haeberlen wrote:
> Hello,
> Michael
newbie: where default Tomcat web page gone? [message #179654 is a reply to message #179536] Fri, 22 September 2006 05:30 Go to previous messageGo to next message
I started developing Web services (Eclipse 3.2/Tomcat 5.0) using wst
plugin. Problem:
When I start Tomcat from windows startup menu, I can admin Tomcat using
browser on:
http://localhost:8080/
But, if I start server from "servers view" in eclipse, web services I
created work fine, but browser pointed to http://localhost:8080/ shows
only "Directory Listing For /" page. Where is Tomcat admin page?
Mirza
Re: newbie: where default Tomcat web page gone? [message #179664 is a reply to message #179654] Fri, 22 September 2006 07:57 Go to previous messageGo to next message
I believe the following recent post ("Re: problem loading localhost:8080
in eclipse" on 9/20) would answer your question:
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg12 103.html
Larry
mirza wrote:
> Hello,
> plugin. Problem:
> browser on:
> Regards,
> Mirza
Re: newbie: where default Tomcat web page gone? [message #179688 is a reply to message #179664] Fri, 22 September 2006 10:23 Go to previous messageGo to next message
Yeah that solved it, thanks! perhaps default web page of Eclipse local
Tomcat instance should be text explaining the fact that it is separate
instance and what to un-check if you want to work with main Tomcat instance.
Mirza
> Cheers,
> Larry
> mirza wrote:
>> Hello,
>> plugin. Problem:
>> using browser on:
>> Regards,
>> Mirza
Re: how to read a WSDL file without using internal classes? [message #182209 is a reply to message #179536] Sat, 04 November 2006 03:17 Go to previous messageGo to next message
Hi Ed,
I also needed to load the WSDL file using WTP plugins, but my plugin works
within eclipse environment. I don't want to use Internal
WSDLResoruceFactoryImpl class directly, so is there any way to use this
class by using any kind of plugin.xml registration. Where can I find more
details for this registraion part. Any help in this regards will be much
appreciated.
Re: how to read a WSDL file without using internal classes? [message #182214 is a reply to message #182209] Sat, 04 November 2006 07:49 Go to previous message
Saurabh,
Looking at the plugin.xml for org.eclipse.wst.wsdl I can see that it
already registered a parser for *.wsdl files:
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser
type="wsdl"
class="org.eclipse.wst.wsdl.internal.util.WSDLResourceFactoryImpl ">
</parser>
</extension>
So loading a *.wsdl resource should use that registered factory
automatically and you can just use EMF's generic resource APIs to access
it once loaded, i.e., using resource.getContents().get(0) to access to
root object in the resource.
Saurabh Dravid wrote:
> Hi Ed,
> works within eclipse environment. I don't want to use Internal
> this class by using any kind of plugin.xml registration. Where can I
> find more details for this registraion part. Any help in this regards
> will be much appreciated.
> Thanks
Previous Topic:Restart Tomcat when change tag in JSP
Next Topic:update site for WTP 2.0 milestones and dev builds
Current Time: Wed Jul 16 11:53:16 EDT 2025
Powered by FUDForum. Page generated in 0.07900 seconds
