Home » Modeling » EMF » How to generate code with specific EMap implementation(Make genmodel generate specific implementation of EMap for all features of map type)
How to generate code with specific EMap implementation [message #1796103] Fri, 05 October 2018 03:30 Go to next message
I have a .xcore model with feature declared as
contains MyEntry < K , V >[] map
where
class MyEntry<K , V> wraps java.util.Map.Entry
So feature called "map" generates into new EcoreEMap in getMap() method. I want it to generate code with specific implementation of EMap. While inspecting the code i found that it is generated through GenClassImpl#getListConstructor(). Is there any way to override this method and how to "pull" in my solution? Overriding get method for each feature of map type is not the solution i want.
Re: How to generate code with specific EMap implementation [message #1796437 is a reply to message #1796103] Fri, 12 October 2018 18:59 Go to previous message
No, for all multi-valued features, including EMaps, the built-in implementations are always used.
Previous Topic:[Xcore/Maven] Xcore code generation with maven
Next Topic:Modern automated code generation from ecore model
Current Time: Mon Jul 21 07:36:37 EDT 2025
Powered by FUDForum. Page generated in 0.06577 seconds
