Home » Modeling » TMF (Xtext) » How to implement the type validation test for my grammar
How to implement the type validation test for my grammar [message #1796405] Fri, 12 October 2018 09:08 Go to next message
Hi, all.
I have written the test for my grammar(please, see it below) and the method
@Test def void stringConstant() { "'foo'".assertStringType }
Fails with the following error
at org.blockchain.rell.tests.ExpressionsTypeProviderTest.assertType(ExpressionsTypeProviderTest.java:78)
at org.blockchain.rell.tests.ExpressionsTypeProviderTest.assertStringType(ExpressionsTypeProviderTest.java:58)
at org.blockchain.rell.tests.ExpressionsTypeProviderTest.stringConstant(ExpressionsTypeProviderTest.java:39)
I understand why it's happened - because of strings what we have tested are not valid with my grammar. But how to test part of the grammar. In the ANTLR I can check only one rule. But how to do something like it with XText?
Vladimir
My grammar
grammar org.blockchain.rell.Rell with org.eclipse.xtext.common.Terminals
generate rell "http://www.blockchain.org/rell/Rell"
Model:
	entities+=TheClass*
	operations+=Operation*;
TheClass:
	'class' name=ID ('extends' superType=[TheClass])? '{'
	attributes+=Attribute*
Operation:
	"operation" name=ID "(" parameters=RelAttrubutesList? ")" "{" statements+=Statement* "}";
Statement:
	(Relational | Variable) ';';
Variable:
	declaration=VariableDeclaration '=' expression=Expression;
Relational:
	Update | Delete | Create;
Update:
	'update' entity=ID '(' expressions=ExpressionsModel? ')' '{' variableList+=VariableInit
	(',' variableList+=VariableInit*)? '}';
Delete:
	'delete' entity=ID '(' expressions=ExpressionsModel? ')';
Create:
	'create' entity=ID '(' expressions=ExpressionsModel? ')';
ExpressionsModel:
	elements+=ConditionElements (',' elements+=ConditionElements*)?;
ConditionElements:
	compareName=ID ('==' | '!=' | '>' | '<' | '>=' | '<=') expr=Expression;
VariableInit:
	name=ID '=' expression=Expression;
Expression:
	Or;
Or returns Expression:
	And ({Or.left=current} "or" right=And)*;
And returns Expression:
	Equality ({And.left=current} "and" right=Equality)*;
Equality returns Expression:
	Comparison ({Equality.left=current} op=("==" | "!=")
	right=Comparison)*;
Comparison returns Expression:
	PlusOrMinus ({Comparison.left=current} op=(">=" | "<=" | ">" | "<")
	right=PlusOrMinus)*;
PlusOrMinus returns Expression:
	MulOrDiv (({Plus.left=current} '+' | {Minus.left=current} '-')
	right=MulOrDiv)*;
Atomic returns Expression:
	{IntConstant} value=INT |
	{StringConstant} value=STRING |
	{BoolConstant} value=('true' | 'false') |
	{VariableRef} variable=[VariableDeclaration];
MulOrDiv returns Expression:
	Primary ({MulOrDiv.left=current} op=('*' | '/')
	right=Primary)*;
Primary returns Expression:
	'(' Expression ')' |
	{Not} "not" expression=Primary |
	Atomic;
RelAttrubutesList:
	value+=VariableDeclaration (',' value+=VariableDeclaration)*;
Attribute:
	modificator=Prefix? variable=VariableDeclaration ';';
VariableDeclaration:
	name=ID ':' type=TypeReference;
TypeReference:
	primitive=PrimitiveType | entity=EntityType;
PrimitiveType:
	Text | Integer | Json | ByteArray;
EntityType:
	entity=[TheClass];
Json:
	'json';
Integer:
	'integer' | 'timestamp';
Text:
	'text' | 'tuid' | 'name';
ByteArray:
	'byte_array' | 'signer' | 'guid' | 'pubkey';
Prefix:
	'key' | 'index';
My test
Model:
	entities+=TheClass*
TheClass:
Operation:
Statement:
Variable:
Relational:
Update:
Delete:
Create:
ExpressionsModel:
ConditionElements:
VariableInit:
Expression:
	Or;
	right=Comparison)*;
	right=MulOrDiv)*;
	right=Primary)*;
	Atomic;
RelAttrubutesList:
Attribute:
TypeReference:
PrimitiveType:
EntityType:
	entity=[TheClass];
Json:
	'json';
Integer:
Text:
ByteArray:
Prefix:
	'key' | 'index';
Re: How to implement the type validation test for my grammar [message #1796406 is a reply to message #1796405] Fri, 12 October 2018 09:11 Go to previous messageGo to next message
you can use ParseHelper and ValidationtestHelper to test parsing and validation.
a parser test is pregenerated by the wizard
Re: How to implement the type validation test for my grammar [message #1796412 is a reply to message #1796406] Fri, 12 October 2018 10:03 Go to previous messageGo to next message
Hmm, may I ask you to tell me something more details
Re: How to implement the type validation test for my grammar [message #1796416 is a reply to message #1796412] Fri, 12 October 2018 10:36 Go to previous messageGo to next message
here is a simple example for a unit test
import com.google.inject.Inject
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.extensions.InjectionExtension
import org.eclipse.xtext.testing.util.ParseHelper
import org.junit.jupiter.api.Assertions
import org.junit.jupiter.api.Test
import org.junit.jupiter.api.^extension.ExtendWith
import org.xtext.example.mydsl2.myDsl.Model
import org.eclipse.xtext.testing.validation.ValidationTestHelper
import org.xtext.example.mydsl2.myDsl.MyDslPackage
import org.xtext.example.mydsl2.validation.MyDslValidator
@ExtendWith(InjectionExtension)
@InjectWith(MyDslInjectorProvider)
class MyDslParsingTest {
	@Inject
	ParseHelper<Model> parseHelper
	@Inject extension ValidationTestHelper
	@Test
	def void loadModel() {
		val result = parseHelper.parse('''
			Hello Xtext!
		Assertions.assertNotNull(result)
		val errors = result.eResource.errors
		Assertions.assertTrue(errors.isEmpty, '''Unexpected errors: «errors.join(", ")»''')
		val result2 = parseHelper.parse('''
			Hello xtext!
		Assertions.assertNotNull(result2)
		val errors2 = result2.eResource.errors
		Assertions.assertTrue(errors2.isEmpty, '''Unexpected errors: «errors2.join(", ")»''')
		result2.assertWarning(MyDslPackage.Literals.GREETING, MyDslValidator.INVALID_NAME, "Name should start with a capital")
Re: How to implement the type validation test for my grammar [message #1796540 is a reply to message #1796416] Mon, 15 October 2018 18:33 Go to previous messageGo to next message
Oh, look like I have posted the grammar twice instead of showing the test.
Please, see my test below
package org.blockchain.rell.tests
import org.blockchain.rell.rell.ExpressionsModel
import org.blockchain.rell.typing.ExpressionsType
import org.blockchain.rell.typing.ExpressionsTypeProvider
import org.eclipse.xtext.testing.XtextRunner
import org.junit.Test
import org.junit.runner.RunWith
import static extension org.junit.Assert.*
@RunWith(typeof(XtextRunner))
@InjectWith(typeof(RellInjectorProvider))
class ExpressionsTypeProviderTest {
	@Inject extension ParseHelper<ExpressionsModel>
	@Inject extension ExpressionsTypeProvider
	@Test def void intConstant() { "10".assertIntType }
	@Test def void testIsInt() {
		(ExpressionsTypeProvider::intType).isInt.assertTrue
	@Test def void testIsString() {
		(ExpressionsTypeProvider::stringType).isString.assertTrue
	@Test def void testIsBool() {
		(ExpressionsTypeProvider::boolType).isBoolean.assertTrue
	def assertStringType(CharSequence input) {
		input.assertType(ExpressionsTypeProvider::stringType)
	def assertIntType(CharSequence input) {
		input.assertType(ExpressionsTypeProvider::intType)
	def assertBoolType(CharSequence input) {
		input.assertType(ExpressionsTypeProvider::boolType)
	def assertUnknownType(CharSequence input) {
		input.assertType(null)
	def assertType(CharSequence input, ExpressionsType expectedType) {
		println("expectedType:"+expectedType+", input:"+input+", input.parse:"+input.parse)
		expectedType.assertSame
			(input.parse.elements.last.typeFor)
Tests stringConstant and intConstant fails with null pointer exception. Look like it's because of sentences "10" and "'foo'" is not valid with my grammar. But how to fix it?
Re: How to implement the type validation test for my grammar [message #1796541 is a reply to message #1796540] Mon, 15 October 2018 18:54 Go to previous messageGo to next message
I.e. problem is that method
ParseHelper<ExpressionsModel>.parse return null on the following strings "10", "'foo'". How to solve this problem?
Re: How to implement the type validation test for my grammar [message #1796557 is a reply to message #1796541] Tue, 16 October 2018 01:15 Go to previous messageGo to next message
You can't.
(Using a debugger might help in such cases)
You need to do manual parsing instead. // pseudo code
@Inject
Provider<ResourceSet> rsp
ResourceSet rs = rsp.get()
Resource r = rs.createResource(URI.createUri("dummy.yourdsl"))
R.load(new StringInputStream(modeltext),null)
r.getErrors // test if empty
Model= r.getContents.get(0)
Re: How to implement the type validation test for my grammar [message #1796558 is a reply to message #1796557] Tue, 16 October 2018 01:16 Go to previous messageGo to next message
P.s. your grammar does not sllow expressions only
So you have to stick together a valid model
Or you use XtextResource.setEntryPoint + grammarAccess to set the parsers entry rule
[Updated on: Tue, 16 October 2018 01:22] by Moderator
Re: How to implement the type validation test for my grammar [message #1796587 is a reply to message #1796558] Tue, 16 October 2018 07:08 Go to previous messageGo to next message
Unfortunately it's not working
Method r.getContents return empty list. Also, there is no method createURI in my version of the URI. Please, see my test below. May I ask you to correct me?
import com.google.inject.Provider
import org.eclipse.emf.common.util.URI
import org.eclipse.emf.ecore.resource.ResourceSet
import org.eclipse.xtext.util.StringInputStream
	@Inject Provider<ResourceSet> rsp
		var rs = rsp.get()
		var r = rs.createResource(URI.createDeviceURI("test.rell"));
		r.load(new StringInputStream(input.toString()),null)
		var  model = r.getContents.get(0)
		model.assertSame(expectedType)
Re: How to implement the type validation test for my grammar [message #1796591 is a reply to message #1796587] Tue, 16 October 2018 07:28 Go to previous messageGo to next message
Should be URI.createURI
And you still should either set the parser rule
Or create a compile model
Like modelStubBeforExpression + expression + modelStubafterExpression
Re: How to implement the type validation test for my grammar [message #1796606 is a reply to message #1796591] Tue, 16 October 2018 09:11 Go to previous messageGo to next message
But, I haven't this method.
Maybe you can to show me an example?
Re: How to implement the type validation test for my grammar [message #1796610 is a reply to message #1796606] Tue, 16 October 2018 09:34 Go to previous messageGo to next message
http://download.eclipse.org/modeling/emf/emf/javadoc/2.4.3/org/eclipse/emf/common/util/URI.html#createURI(java.lang.String)
Consider a grammar with
var x = 1;
Then it could be
„var x = „ + expression + „;"
Re: How to implement the type validation test for my grammar [message #1796635 is a reply to message #1796610] Tue, 16 October 2018 14:05 Go to previous message
test that shows your problem
import org.junit.Assert
@RunWith(XtextRunner)
	@Inject
	@Test
		val input = '''1'''
		var rs = rsp.get()
		var r = rs.createResource(URI.createURI("test.mydsl2"));
		var errors = r.errors
		Assert.assertTrue('''Unexpected errors: «errors.join(", ")»''', errors.isEmpty)
test that shows solution (1)
	@Inject
	@Test
		val input = '''1'''
		val completeInput = '''operation myOp() {
			x : integer = «input»;
		var rs = rsp.get()
		r.load(new StringInputStream(completeInput.toString()),null)
test that shows solution (2)
import org.eclipse.xtext.resource.XtextResource
import org.xtext.example.mydsl2.services.MyDslGrammarAccess
	@Inject
	@Inject
	MyDslGrammarAccess ga;
	@Test
		val input = '''1'''
		var rs = rsp.get()
		(r as XtextResource).entryPoint = ga.expressionRule
Previous Topic:Language Server Protocol Syntax Highlighting
Next Topic:Update site down
Current Time: Fri Jul 18 13:29:54 EDT 2025
Powered by FUDForum. Page generated in 0.55005 seconds
