Home » Modeling » TMF (Xtext) » Variable reference error(XText says me that I haven't of an existing variable)
Variable reference error [message #1796323] Wed, 10 October 2018 11:09 Go to next message
Please, see my grammar below. I have the following error for the mentioned text
operation test(){
i:integer=1;
j:integer=i;
Couldn't resolve reference to Variable 'i'.
Line 3
Where is the problem and how to fix it?
Vladimir
grammar org.blockchain.rell.Rell with org.eclipse.xtext.common.Terminals
generate rell "http://www.blockchain.org/rell/Rell"
Model:
	entities+=TheClass*
	operations+=Operation*;
TheClass:
	'class' name=ID ('extends' superType=[TheClass])? '{'
	attributes+=Attribute*
Operation:
	"operation" name=ID "(" parameters=RelAttrubutesList? ")" "{" statements+=Statement* "}";
Statement:
	(Relational | Variable) ';';
Variable:
	declaration=VariableDeclaration '=' expression=Expression;
Relational:
	Update | Delete | Create;
Update:
	'update' entity=ID '(' expressions=ExpressionsModel? ')' '{' variableList+=VariableInit
	(',' variableList+=VariableInit*)? '}';
Delete:
	'delete' entity=ID '(' expressions=ExpressionsModel? ')';
Create:
	'create' entity=ID '(' expressions=ExpressionsModel? ')';
ExpressionsModel:
	elements+=ConditionElements (',' elements+=ConditionElements*)?;
ConditionElements:
	compareName=ID ('==' | '!=' | '>' | '<' | '>=' | '<=') expr=Expression;
VariableInit:
	name=ID '=' expression=Expression;
Expression:
	Or;
Or returns Expression:
	And ({Or.left=current} "or" right=And)*;
And returns Expression:
	Equality ({And.left=current} "and" right=Equality)*;
Equality returns Expression:
	Comparison ({Equality.left=current} op=("==" | "!=")
	right=Comparison)*;
Comparison returns Expression:
	PlusOrMinus ({Comparison.left=current} op=(">=" | "<=" | ">" | "<")
	right=PlusOrMinus)*;
PlusOrMinus returns Expression:
	MulOrDiv (({Plus.left=current} '+' | {Minus.left=current} '-')
	right=MulOrDiv)*;
Atomic returns Expression:
	{IntConstant} value=INT |
	{StringConstant} value=STRING |
	{BoolConstant} value=('true' | 'false') |
	{VariableRef} variable=[Variable];
MulOrDiv returns Expression:
	Primary ({MulOrDiv.left=current} op=('*' | '/')
	right=Primary)*;
Primary returns Expression:
	'(' Expression ')' |
	{Not} "not" expression=Primary |
	Atomic;
RelAttrubutesList:
	value+=RelAttribute (',' value+=RelAttribute)*;
RelAttribute:
	name=ID ':' reference=TypeReference;
Attribute:
	modificator=Prefix? variable=VariableDeclaration ';';
VariableDeclaration:
	name=ID ':' type=TypeReference;
TypeReference:
	primitive=PrimitiveType | entity=EntityType;
PrimitiveType:
	Text | Integer | Json | ByteArray;
EntityType:
	entity=[TheClass];
Json:
	'json';
Integer:
	'integer' | 'timestamp';
Text:
	'text' | 'tuid' | 'name';
ByteArray:
	'byte_array' | 'signer' | 'guid' | 'pubkey';
Prefix:
	'key' | 'index';
Re: Variable reference error [message #1796324 is a reply to message #1796323] Wed, 10 October 2018 11:11 Go to previous messageGo to next message
Variable:
variable has no name (you could adapt IQualifiedNameProvider for that)
but you refer
could change this to
{VariableRef} variable=[VariableDeclaration];
too
Re: Variable reference error [message #1796347 is a reply to message #1796324] Thu, 11 October 2018 08:39 Go to previous message
Look like using of the IQualifiedNameProvider is what I need because I can't use Variable declarations in the expressions, but variables only
Previous Topic:IXTextBuilderParticipant for VS Code
Next Topic:Xtext 2.15.0 released!
Current Time: Fri Jul 18 09:10:00 EDT 2025
Powered by FUDForum. Page generated in 0.08575 seconds
