Home » Modeling » TMF (Xtext) » XText Binding Generators from another Project
XText Binding Generators from another Project [message #1796265] Tue, 09 October 2018 07:56 Go to next message
When I start a new XText Project, and then generate the XText Artifacts from my XText File, A RunTimeModule is automatically created in the core logic Project where the xtext File defined, so that I can bind my own generators and validators.
Depending on my workflow, XText also automatically creates packages for generators and validation, also within this core Project.
Let's say I have another Project, where additional generators are defined, and this Project is dependent on the core Project where my RunTimeModule is.
But the core Project itself of course has no access to this second Project.
How can I bind these generators in this second Project, since in my RunTimeModule I have no access to these other generators?
To make it clearer
org.xtext.myDsl (Core Xtext Project)
    ---- org.xtext.myDsl
             ----MyDsl.xtext
            ----MyDslRuntimeModule.xtend
    ---- org.xtext.myDsl.Generator
    ----- org.xtext.myDsl.validation
org.xtext.second.myDsl (second Project dependent on org.xtext.msDsl)
      --- org.xtext.second.myDsl.generator (I want to bind the generators here)
[Updated on: Tue, 09 October 2018 08:01] by Moderator
Re: XText Binding Generators from another Project [message #1796266 is a reply to message #1796265] Tue, 09 October 2018 07:59 Go to previous messageGo to next message
the generators are "found" via the
<extension point="org.eclipse.xtext.builder.participant">
<participant
class="org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.eclipse.xtext.builder.IXtextBuilderParticipant"
fileExtensions="mydsl"/>
</extension>
extension point.
so you could do this with a custom MyDslGeneratorExecutableExtensionFactory (+ Activator + Bindings etc)
Re: XText Binding Generators from another Project [message #1796267 is a reply to message #1796266] Tue, 09 October 2018 07:59 Go to previous messageGo to next message
For standalone:
it depends on how you want to call the generators
Re: XText Binding Generators from another Project [message #1796268 is a reply to message #1796267] Tue, 09 October 2018 08:03 Go to previous messageGo to next message
thanks again, let's see how I can do that=)
Re: XText Binding Generators from another Project [message #1796269 is a reply to message #1796267] Tue, 09 October 2018 08:03 Go to previous messageGo to next message
For standalone: I want to call the generators on every save
Re: XText Binding Generators from another Project [message #1796270 is a reply to message #1796268] Tue, 09 October 2018 08:03 Go to previous messageGo to next message
which usecase do you target: eclipse or standalone?
Re: XText Binding Generators from another Project [message #1796271 is a reply to message #1796270] Tue, 09 October 2018 08:05 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 09 October 2018 12:03
Standalone
I am building an VS-Code Plugin
Re: XText Binding Generators from another Project [message #1796273 is a reply to message #1796271] Tue, 09 October 2018 08:13 Go to previous messageGo to next message
then this wont work.
do you call the generator automatically or via command?
in both cases you need to make sure you call a composite generator in the end
(IGenerator2 that delegates to all generators you have)
Re: XText Binding Generators from another Project [message #1796274 is a reply to message #1796273] Tue, 09 October 2018 08:19 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 09 October 2018 12:13
I want the generators to be called every time I save the file Visual Studio Code
so I guess then the only way is to bind the generator like this
	// contributed by org.eclipse.xtext.xtext.generator.generator.GeneratorFragment2
	public Class<? extends IGenerator2> bindIGenerator2() {
		return MyDslGenerator.class;
So I need a main IGenerator2 delegate that delegates to all my generators within the doGenerate method right?
Re: XText Binding Generators from another Project [message #1796275 is a reply to message #1796274] Tue, 09 October 2018 08:24 Go to previous messageGo to next message
so
allows me to process resources that are built by an Eclipse Project Builder.
But I cannot use this with VS-Code right?
Do you perhaps know if something similar exists for VS-Code?
Re: XText Binding Generators from another Project [message #1796280 is a reply to message #1796275] Tue, 09 October 2018 08:56 Go to previous message
no in viscode you have to have a single IGenerator2
(you have create a delegating one in yourdsl.ide though)
Previous Topic:Serialization of Xtext model
Next Topic:IXTextBuilderParticipant for VS Code
Current Time: Fri Jul 18 22:00:15 EDT 2025
Powered by FUDForum. Page generated in 0.04738 seconds
