Home » Modeling » TMF (Xtext) » Why does my test is not working
Why does my test is not working [message #1796168] Sun, 07 October 2018 17:54 Go to next message
Hi all, I have following grammar, validator, and the test. Unfortunately, my test is not passed with the following error message
Expected ERROR 'org.blockchain.rell.entities.HierarchyCycle' on TheClass at [-1:-1] but got
ERROR (null) 'cycle in hierarchy of entity 'Test'' on TheClass, offset 19, length 4
But why and how to fix it?
Vladimir
grammar org.blockchain.rell.Rell with org.eclipse.xtext.common.Terminals
generate rell "http://www.blockchain.org/rell/Rell"
Model:
	entities+=TheClass*
	operations+=Operation*;
TheClass:
	'class' name=ID ('extends' superType=[TheClass])? '{'
	attributes+=Attribute*
Operation:
	"operation" name=ID "(" parameters=RelAttrubutesList? ")" "{" statements+=Statement* "}";
Statement:
	(Relational | Variable) ';';
Variable:
	declaration=VariableDeclaration '=' expression=Expression;
Relational:
	Update | Delete | Create;
Update:
	'update' entity=ID '(' expressions=ExpressionsModel? ')' '{' variableList+=VariableInit
	(',' variableList+=VariableInit*)? '}';
Delete:
	'delete' entity=ID '(' expressions=ExpressionsModel? ')';
Create:
	'create' entity=ID '(' expressions=ExpressionsModel? ')';
ExpressionsModel:
	elements+=ConditionElements (',' elements+=ConditionElements*)?;
ConditionElements:
	compareName=ID ('==' | '!=' | '>' | '<' | '>=' | '<=') expr=Expression;
	//AbstractElement:
//	Variable | Expression;
VariableInit:
	name=ID '=' expression=Expression;
Expression:
	Or;
Or returns Expression:
	And ({Or.left=current} "or" right=And)*;
And returns Expression:
	Equality ({And.left=current} "and" right=Equality)*;
Equality returns Expression:
	Comparison ({Equality.left=current} op=("==" | "!=")
	right=Comparison)*;
Comparison returns Expression:
	PlusOrMinus ({Comparison.left=current} op=(">=" | "<=" | ">" | "<")
	right=PlusOrMinus)*;
PlusOrMinus returns Expression:
	MulOrDiv (({Plus.left=current} '+' | {Minus.left=current} '-')
	right=MulOrDiv)*;
Atomic returns Expression:
	{IntConstant} value=INT |
	{StringConstant} value=STRING |
	{BoolConstant} value=('true' | 'false') |
	{VariableRef} variable=[Variable];
MulOrDiv returns Expression:
	Primary ({MulOrDiv.left=current} op=('*' | '/')
	right=Primary)*;
Primary returns Expression:
	'(' Expression ')' |
	{Not} "not" expression=Primary |
	Atomic;
RelAttrubutesList:
	value+=RelAttribute (',' value+=RelAttribute)*;
RelAttribute:
	name=ID ':' reference=TypeReference;
Attribute:
	modificator=Prefix? variable=VariableDeclaration ';';
VariableDeclaration:
	name=ID ':' type=TypeReference;
TypeReference:
	primitive=PrimitiveType | entity=EntityType;
PrimitiveType:
	Text | Integer | Json | ByteArray;
EntityType:
	entity=[TheClass];
Json:
	'json';
Integer:
	'integer' | 'timestamp';
Text:
	'text' | 'tuid' | 'name';
ByteArray:
	'byte_array' | 'signer' | 'guid' | 'pubkey';
Prefix:
	'key' | 'index';
 * generated by Xtext 2.14.0
package org.blockchain.rell.validation
import org.blockchain.rell.rell.RellPackage
import org.blockchain.rell.rell.TheClass
import org.eclipse.xtext.validation.Check
 * Custom validation rules.
 * see http://www.eclipse.org/Xtext/documentation.html#validation
class RellValidator extends AbstractRellValidator {
	public static val FORWARD_REFERENCE = "org.example.expressions.ForwardReference";
	public static val WRONG_TYPE = "org.example.expressions.WrongType";
	public static val HIERARCHY_CYCLE = "org.blockchain.rell.entities.HierarchyCycle";
	@Check
	def checkNoCycleClassHierarhy(TheClass theClass) {
		if (theClass.superType === null) {
			return;
		val visitedClasses = <TheClass>newHashSet();
		visitedClasses.add(theClass);
		var current = theClass.superType
		while (current !== null) {
			if (visitedClasses.contains(current)) {
				error("cycle in hierarchy of entity '" + current.name + "'", RellPackage::eINSTANCE.theClass_SuperType)
				return
			visitedClasses.add(current)
			current = current.superType
package org.blockchain.rell.tests
import com.google.inject.Inject
import org.blockchain.rell.rell.Model
import org.blockchain.rell.validation.RellValidator
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.XtextRunner
import org.eclipse.xtext.testing.util.ParseHelper
import org.eclipse.xtext.testing.validation.ValidationTestHelper
import org.junit.Test
import org.junit.runner.RunWith
@RunWith(typeof(XtextRunner))
@InjectWith(typeof(RellInjectorProvider))
class RellValidatorTest {
	@Inject extension ParseHelper<Model>
	@Inject extension ValidationTestHelper
	@Test
	def void testEntityExtendsItself() {
		'''class Test extends Test{
		}'''.parse.assertError(RellPackage.eINSTANCE.theClass, RellValidator::HIERARCHY_CYCLE,
			"cycle in hierarchy of entity 'Test'")
Re: Why does my test is not working [message #1796182 is a reply to message #1796168] Mon, 08 October 2018 00:39 Go to previous message
Hi, you test for a error code you dont use during creation
error("cycle in hierarchy of entity '" + current.name + "'", theClass, MyDslPackage::eINSTANCE.theClass_SuperType, HIERARCHY_CYCLE)
Previous Topic:XText Generator making random mistakes while generating java classes
Next Topic:Class missing while executing xtext-maven:generate
Current Time: Thu Jul 17 23:45:33 EDT 2025
Powered by FUDForum. Page generated in 0.49496 seconds
