Home » Newcomers » Newcomers » Start up error(error)
Start up error [message #1795887] Mon, 01 October 2018 20:55 Go to next message
Downloaded Eclipse yesterday and it worked fine all day. I restart my computer today and try to open eclipse but I get an error. can anyone help me?index.php/fa/33985/0/
  • Attachment: E error.png
    (Size: 128.28KB, Downloaded 5419 times)
  • Attachment: Untitled.png
    (Size: 1.12MB, Downloaded 277 times)
Re: Start up error [message #1795891 is a reply to message #1795887] Mon, 01 October 2018 23:07 Go to previous messageGo to next message
Do you have any technical details you can share, like how you installed Eclipse, which version it is,
where it was installed, or what version of Java you're running? Right now this looks like
an old version of Eclipse with a very new version of Java, but that's a total guess.
[Updated on: Mon, 01 October 2018 23:08] by Moderator
Re: Start up error [message #1795953 is a reply to message #1795891] Tue, 02 October 2018 18:29 Go to previous messageGo to next message
I went to the main site press the download button and downloaded the 64 bit Eclipse SIMREL 2018-19. Its saved on my C:. The version of java I am using is 1.8.0_192-ea, Java SE runtime environment build 1.8.0_192-ea-b04 & java hotspot 64 bit server VM build 25.192-b04 mixed mode. that was my CMD tells me. The book I am reading said to use oxygen but I wanted me to use outdated java 9 but that's not supported anymore. so idk if I should try Photon or a newer build but I don't know which is the latest and would work with what I have right now.
Re: Start up error [message #1795954 is a reply to message #1795953] Tue, 02 October 2018 21:04 Go to previous messageGo to next message
Can you post the .log file itself? Posting log files
as an image is very limiting.
Re: Start up error [message #1796087 is a reply to message #1795954] Thu, 04 October 2018 23:28 Go to previous messageGo to next message
Yes I can ill have it up shortly, ill try to boot the program and post a new log.
Re: Start up error [message #1796088 is a reply to message #1796087] Thu, 04 October 2018 23:34 Go to previous messageGo to next message
!SESSION 2018-09-30 12:08:08.194 -----------------------------------------------
eclipse.buildId=4.9.0.I20180906-0745
java.version=1.8.0_192-ea
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.ui 2 0 2018-09-30 12:10:38.059
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\pc'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!SESSION 2018-09-30 12:31:18.357 -----------------------------------------------
Framework arguments: -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product -data file:/C:/Users/pc/eclipse-workspace/ -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.ui 2 0 2018-09-30 12:31:53.391
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-10-01 13:21:28.970
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.util.concurrent.TimeoutException: Timed out waiting for org.eclipse.epp.logging.aeri.ide.server ServerConnection [STOPPING] to reach a terminal state. Current state: STOPPING
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:462)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:159)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:81)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:77)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:187)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:102)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:144)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:911)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:233)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:140)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:132)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:194)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:479)
at org.eclipse.osgi.container.Module.doStop(Module.java:637)
at org.eclipse.osgi.container.Module.stop(Module.java:501)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:205)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:213)
Caused by: java.util.concurrent.TimeoutException: Timed out waiting for org.eclipse.epp.logging.aeri.ide.server ServerConnection [STOPPING] to reach a terminal state. Current state: STOPPING
at com.google.common.util.concurrent.AbstractService.awaitTerminated(AbstractService.java:317)
at com.google.common.util.concurrent.AbstractIdleService.awaitTerminated(AbstractIdleService.java:199)
at org.eclipse.epp.internal.logging.aeri.ide.server.mars.ServerConnection.diStop(ServerConnection.java:392)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
... 25 more
!SESSION 2018-10-01 16:54:22.278 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:55:12.194
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (98).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:803)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:732)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1005)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:357)
at org.eclipse.osgi.container.Module.doStart(Module.java:584)
at org.eclipse.osgi.container.Module.start(Module.java:452)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:471)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:557)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:331)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:39)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:414)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:153)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:156)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:199)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:391)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:246)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
Caused by: org.eclipse.core.internal.resources.ResourceException: Incompatible file format. Workspace was saved with an incompatible version: 0.
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:62)
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:70)
at org.eclipse.core.internal.resources.SaveManager.restoreTree(SaveManager.java:1042)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:705)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1561)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2451)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2208)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:489)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:782)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:775)
... 29 more
Caused by: java.lang.Exception: Incompatible file format. Workspace was saved with an incompatible version: 0.
at org.eclipse.core.internal.resources.ResourceException.provideStackTrace(ResourceException.java:42)
at org.eclipse.core.internal.resources.ResourceException.<init>(ResourceException.java:38)
... 41 more
Root exception:
org.eclipse.core.internal.resources.ResourceException(null)[567]: java.lang.Exception: Incompatible file format. Workspace was saved with an incompatible version: 0.
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:55:12.503
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (98).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:126)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 22 more
... 29 more
... 41 more
!SESSION 2018-10-01 16:56:37.168 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:56:44.728
!STACK 0
... 29 more
... 41 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:56:44.856
!STACK 1
... 13 more
... 22 more
... 29 more
... 41 more
!SESSION 2018-10-01 16:58:14.976 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:58:22.385
!STACK 0
... 29 more
... 41 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:58:22.465
!STACK 1
... 13 more
... 22 more
... 29 more
... 41 more
!SESSION 2018-10-01 16:58:34.407 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:58:43.397
!STACK 0
... 29 more
... 41 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:58:43.493
!STACK 1
... 13 more
... 22 more
... 29 more
... 41 more
!SESSION 2018-10-01 17:03:13.868 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 17:04:11.040
!STACK 0
Re: Start up error [message #1796090 is a reply to message #1796088] Thu, 04 October 2018 23:45 Go to previous messageGo to next message
I also cannot uninstall at all. the program isn't even on the list of programs.
Re: Start up error [message #1796099 is a reply to message #1796090] Fri, 05 October 2018 02:19 Go to previous messageGo to next message
It looks like there is something wrong with the workspace that you're trying to open. Use the initial workspace dialog to point at a fresh new workspace location instead of an apparently corrupt/bad existing workspace location.
Re: Start up error [message #1796104 is a reply to message #1796099] Fri, 05 October 2018 03:44 Go to previous message
Omg Thank You so much its working now, I appreciate your assistance.
Previous Topic:How do I download Plugins outside of the Eclipse IDE?
Next Topic:Using the same workspace for two different versions of Eclipse
Current Time: Sat Jul 26 20:58:13 EDT 2025
Powered by FUDForum. Page generated in 0.08899 seconds
