Xtext Generator making random mistakes while generating java classes [message #1796037] |
Thu, 04 October 2018 07:52  |
I have a quite large grammar.
When I generate the Xtext Artifacts, many many java classes are generated. Generators run successfully. However, almost always some of the classes which are generated have random mistakes in them, which makes them unable to compile.
It is usually only one or two .java classes among almost a hundred which have mistakes, and it is not the same classes, the mistakes seem to come randomly.
Bit it is usually inside the the package implementation class.
Here is an example mistake:
public EClass getActionDeclaration()
if (actionDeclarationEClass == null)
actionDeclarationEClass = (EClass)EPackage.Registry.INSTANCE.getEPackage(HmiPackage.eNS_URI).getEClassifiers().g(96);
return compositeActionEClass;
this code should actually look like this:
actionDeclarationEClass = (EClass)EPackage.Registry.INSTANCE.getEPackage(HmiPackage.eNS_URI).getEClassifiers().get(92);
return actionDeclarationEClass;
so the instead of "get" there is "g"
Here is my Workflow, if that helps:
module de.bmw.rhmi.GenerateHmi
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
import org.eclipse.emf.mwe.utils.*
var rootPath = ".."
var projectName = "de.bmw.rhmi"
var runtimeProject = "../${projectName}"
Workflow {
bean = StandaloneSetup {
scanClassPath = true
platformUri = "${rootPath}"
registerGenModelFile = "platform:/resource/de.bmw.rhmi.resource/model/generated/Strings.genmodel"
registerGenModelFile = "platform:/resource/de.bmw.rhmi.resource/model/Image.genmodel"
registerGenModelFile = "platform:/resource/de.bmw.rhmi/model/generated/App.genmodel"
registerGenModelFile = "platform:/resource/de.bmw.rhmi/model/generated/Hmi.genmodel"
registerGeneratedEPackage = "de.bmw.rhmi.resource.image.ImagePackage"
registerGeneratedEPackage = "de.bmw.rhmi.resource.strings.StringsPackage"
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "de.bmw.rhmi"
rootPath = rootPath
runtimeTest = {
enabled = true
genericIde = {
enabled = true
mavenLayout = true
code = {
encoding = "UTF-8"
lineDelimiter = "\n"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = XtextGeneratorLanguage {
name = "de.bmw.rhmi.App"
fileExtensions = "rapp"
referencedResource = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
fragment = grammarAccess.GrammarAccessFragment2 {}
fragment = ecore.EMFGeneratorFragment2 {}
fragment = serializer.SerializerFragment2 {}
fragment = resourceFactory.ResourceFactoryFragment2 {}
fragment = parser.antlr.XtextAntlrGeneratorFragment2 {}
fragment = validation.ValidatorFragment2 {}
fragment = scoping.ImportNamespacesScopingFragment2 {}
fragment = exporting.QualifiedNamesFragment2 {}
fragment = builder.BuilderIntegrationFragment2 {}
fragment = formatting.Formatter2Fragment2 {}
fragment = ui.labeling.LabelProviderFragment2 {}
fragment = ui.outline.QuickOutlineFragment2 {}
fragment = ui.outline.OutlineTreeProviderFragment2 {}
fragment = ui.quickfix.QuickfixProviderFragment2 {}
fragment = ui.contentAssist.ContentAssistFragment2 {}
fragment = junit.JUnitFragment {}
fragment = ui.refactoring.RefactorElementNameFragment2 {}
fragment = ui.templates.CodetemplatesGeneratorFragment2 {}
fragment = ui.compare.CompareFragment2 {}
fragment = idea.parser.antlr.XtextAntlrIDEAGeneratorFragment {}
fragment = ui.projectWizard.TemplateProjectWizardFragment {}
fragment = ui.fileWizard.TemplateFileWizardFragment {}
referencedResource = "platform:/resource/de.bmw.rhmi/src/main/java/de/bmw/rhmi/App.xtext"
name = "de.bmw.rhmi.Hmi"
fileExtensions = "hmi"
Why is this happening?
My Idea was to increase the timeout variable for the generator, but I am not sure if that has to do with it or how to do it.
Re: Xtext Generator making random mistakes while generating java classes [message #1796044 is a reply to message #1796043] |
Thu, 04 October 2018 08:24   |
also here is for reference:
Build.gradle of the parent project
buildscript {
repositories {
jcenter()
maven {
url "https://plugins.gradle.org/m2/"
dependencies {
classpath 'org.xtext:xtext-gradle-plugin:1.0.21'
classpath 'com.moowork.gradle:gradle-node-plugin:1.2.0'
classpath 'net.researchgate:gradle-release:2.6.0'
apply plugin: 'net.researchgate.release'
apply plugin: 'com.moowork.node'
node {
version = '8.11.1'
npmVersion = '5.6.0'
download = true
configure(subprojects.findAll { it.name.startsWith('de.bmw') }) {
ext.xtextVersion = '2.14.0'
repositories {
maven {
url 'https://oss.sonatype.org/content/repositories/snapshots'
jcenter()
apply plugin: 'java'
apply plugin: 'org.xtext.xtend'
apply from: "${rootDir}/gradle/source-layout.gradle"
apply from: "${rootDir}/gradle/maven-deployment.gradle"
apply plugin: 'eclipse'
apply plugin: 'idea'
group = 'de.bmw.rhmi'
version = '1.0.0-SNAPSHOT'
sourceCompatibility = '1.8'
targetCompatibility = '1.8'
configurations.all {
exclude group: 'asm'
task npmInstallVsce(type: NpmTask, dependsOn: npmSetup) {
ext.destPath = "$rootProject.projectDir/node_modules/vsce"
outputs.dir(destPath)
group 'Node'
description 'Installs the NodeJS package "Visual Studio Code Extension Manager"'
args = [ 'install', 'vsce' ]
// Configuration for vscode projects
configure(subprojects.findAll { it.name.startsWith('vscode') }) {
node {
version = '6.11.3'
npmVersion = '3.10.10'
download = true
def inputFiles = fileTree(
dir: projectDir,
excludes: [ 'out/**', '.gitignore', '.gradle/**', 'build/**', '*.gradle' ]
npmInstall {
inputs.files(inputFiles)
outputs.dir('out')
//this task creates the vscode-extension-self-contained-0.0.14.visx file
task vscodeExtension(dependsOn: [npmInstall, npmInstallVsce], type: NodeTask) {
//set the destination directory
ext.destDir = new File(buildDir, 'vscode')
//set the archive name
ext.archiveName = "$project.name-${project.version}.vsix"
//set the destination path
ext.destPath = "$destDir/$archiveName"
inputs.with {
files inputFiles
dir npmInstallVsce.destPath
outputs.dir destDir
doFirst {
destDir.mkdirs()
script = file("$npmInstallVsce.destPath/out/vsce")
args = [ 'package', '--out', destPath ]
execOverrides {
workingDir = projectDir
task clean {
doLast {
delete vscodeExtension.destDir
delete 'out' // output of npmInstall - don't want to delete node_modules
// Workaround for issue https://github.com/researchgate/gradle-release/issues/144
task build {
dependsOn subprojects.findResults { it.tasks.findByName('build') }
build.gradle of the sub project where the grammer is defined
dependencies {
testCompile "junit:junit:4.12"
testCompile "org.eclipse.xtext:org.eclipse.xtext.testing:${xtextVersion}"
testCompile "org.eclipse.xtext:org.eclipse.xtext.xbase.testing:${xtextVersion}"
compile "org.eclipse.xtext:org.eclipse.xtext:${xtextVersion}"
compile "org.eclipse.xtext:org.eclipse.xtext.xbase:${xtextVersion}"
compile group: 'org.eclipse.emf', name: 'org.eclipse.emf.mwe2.launch', version: '2.9.1.201705291010'
compile group: 'org.eclipse.core', name: 'org.eclipse.core.resources', version: '3.7.100'
compile group: 'xom', name: 'xom', version: '1.2.5'
compile group: 'javax.xml.bind', name: 'jaxb-api', version: '2.2.5'
compile group: 'com.sun.xml.bind', name: 'jaxb-impl', version: '2.2.5'
configurations {
mwe2 {
extendsFrom compile
dependencies {
compile project(':de.bmw.rhmi.resource')
mwe2 "org.eclipse.emf:org.eclipse.emf.mwe2.launch:2.9.1.201705291010"
mwe2 "org.eclipse.xtext:org.eclipse.xtext.common.types:${xtextVersion}"
mwe2 "org.eclipse.xtext:org.eclipse.xtext.xtext.generator:${xtextVersion}"
mwe2 "org.eclipse.xtext:xtext-antlr-generator:[2.1.1, 3)"
task generateXtextLanguage(type: JavaExec) {
main = 'org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher'
classpath = configurations.mwe2
inputs.file "src/main/java/de/bmw/rhmi/GenerateHmi.mwe2"
inputs.file "src/main/java/de/bmw/rhmi/Hmi.xtext"
outputs.dir "src/main/xtext-gen"
args += "src/main/java/de/bmw/rhmi/GenerateHmi.mwe2"
args += "-p"
args += "rootPath=/${projectDir}/.."
generateXtext.dependsOn(generateXtextLanguage)
clean.dependsOn(cleanGenerateXtextLanguage)
eclipse.classpath.plusConfigurations += [configurations.mwe2]
I am trying to build a VSCode extension
Re: Xtext Generator making random mistakes while generating java classes [message #1796060 is a reply to message #1796055] |
Thu, 04 October 2018 11:19   |
Ed Willink wrote on Thu, 04 October 2018 13:46Hi
Your original report suggested a regular problem, so it is unlikely to be associated with a manual activity. I suspect that for some reason multiple builds run from a single trigger. Possibly due to multiple registered (platform) builders/natures, possibly due to multiple EF Generators. Perhaps some EMF-based project that I am not familiar with auto-builds from genmodels.
In your position I would instrument XMIResourceImpl.save(*) to get some insight into the multiples.
Ed Willink
@Ed Willink
How do I do that exactly?
Here is the interesting parts of the console output when I run the builder.
1207 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator [b][/b]
1894 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
5283 [main] INFO text.xtext.generator.XtextGenerator - Generating de.bmw.rhmi.App
8578 [main] INFO nerator.ecore.EMFGeneratorFragment2 - Generating EMF model code
8635 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.bmw.de/rhmi/app' from 'platform:/resource/de.bmw.rhmi/model/generated/App.genmodel'
14550 [main] INFO text.xtext.generator.XtextGenerator - Generating de.bmw.rhmi.Hmi
32123 [main] INFO nerator.ecore.EMFGeneratorFragment2 - Generating EMF model code
32203 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.bmw.de/rhmi/hmi' from 'platform:/resource/de.bmw.rhmi/model/generated/Hmi.genmodel'
103360 [main] INFO text.xtext.generator.XtextGenerator - Generating common infrastructure
103362 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
Can I run the mwe2 workflow through the console and with a debug option so that I know what is going on exactly?
Something is definitely wrong.
For example here is part of the InternalHmiParser.java class which is also generated and which is a complete code mish mash:
try {
// InternalHmi.g:24073:2: ( ( ( (lv_value_0_0= ruleIntLiteral ) ) (otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) ) ) ) )
// InternalHmi.g:24074:2: ( ( (lv_value_0_0= ruleIntLiteral ) ) (otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) ) ) )
// InternalHmi.g:24075:3: ( (lv_value_0_0= ruleIntLiteral ) ) (otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) ) )
// InternalHmi.g:24076:4: (lv_value_0_0= ruleIntLiteral )
// InternalHmi.g:24077:5: lv_value_0_0= ruleIntLiteral
newCompositeNode(grammarAccess.getTableLayoutValueAccess().getValueIntLiteralParserRuleCall_0_0());
pushFollow(FollowSets000.FOLLOW_123);
lv_value_0_0=ruleIntLiteral();
state._fsp--;
if (current==null) {
current = createModelElementForParent(grammarAccess.getTableLayoutValueRule());
add(
current,
"value",
lv_value_0_0,
"de.bmw.rhmi.Hmi.IntLiteral");
afterParserOrEnumRuleCall();
// InternalHmi.g:24094:3: (otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) ) )
// InternalHmi.g:24095:4: otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) )
otherlv_1=(Token)match(input,71,FollowSets000.FOLLOW_25);
newLeafNode(otherlv_1, grammarAccess.getTableLayoutValueAccess().getCommaKeyword_1_0());
// InternalHmi.g:24099:4: ( (lv_value_2_0= ruleIntLiteral ) )
// InternalHmi.g:24100:5: (lv_value_2_0= ruleIntLiteral )
// InternalHmi.g:24101:6: lv_value_2_0= ruleIntLiteral
newCompositeNode(grammarAccess.getTableLayoutValueAccess().getValueIntLiteralParserRuleCall_1_1_0());
pushFollow(FollowSets000.FOLLOW_2);
lv_value_2_0=ruleIntLiteral();
state._fsp--;
add(
current,
"value",
lv_value_2_0,
leaveRule();
catch (RecognitionException re) {
recover(input,re);
appendSkippedTokens();
Re: Xtext Generator making random mistakes while generating java classes [message #1796080 is a reply to message #1796075] |
Thu, 04 October 2018 14:17  |
I would consider it unlikely that the console will give you a complete and true record of the problem.
If you have a known suspect component you might manage to guess your way to a solution.
But I think you have to debug. I often check out EMF modules into my workspace so that I can add println's to them. Then I run in a nested Eclipse and the log guides me to where to set more relevant breakpoints.
My suspicion of colliding writes turning "get()" into "g()" might be a wrong. In which case you will instead need to debug how a "g()" got emitted and what got corrupted to cause it ....
Ed Willink
FUDForum. Page generated in 0.10294 seconds
