Home » Eclipse Projects » WindowBuilder » Oxygen (4.7.2) and WindowBuilder (1.9.1.201710100405)(Works in one workspace but not in other workspace)
Oxygen (4.7.2) and WindowBuilder (1.9.1.201710100405) [message #1795968] |
Wed, 03 October 2018 07:22  |
My environment:
Windows 7 Enterprise (Service Pack 1)
JDK 1.8.0_181
Eclipse Oxygen (4.7.2)
I have two workspaces - one where the JDK compliance is set to 1.5 and another one that uses 1.8.
I can successfully open java class files in the java 1.5 workspace in WindowBuilder but in the java 1.8 workspace, the "Source" tab shows the java code but when I switch to the "Design" tab, Eclipse displays the "Parsing" message but then displays an empty editor. The "Palette" panel appears but contains no icons or text. Similarly the "Structure" panel. Note that the java 1.8 workspace did initially work correctly. As far as I can tell, I did not change anything in that workspace prior to it ceasing to work. The log file for the workspace contains the following:
java.lang.IllegalArgumentException: Width (-1) and height (-1) cannot be <= 0
I tried looking through the WindowBuilder source code for the classes appearing in the stack trace. It looks to me that WindowBuilder cannot find an icon, but I couldn't figure out which icon or where it is meant to be located.
As I said, as far as I am aware, the only difference between the two workspaces is the JDK compliance.
Note that I also tried creating a fresh workspace as well as reinstalling Eclipse but got the same behaviour, i.e. WindowBuilder works in one workspace but not the other.
Any suggestions of where to look or what to try will be appreciated.
I have added a screen capture of WindowBuilder.
Here is the entire stack trace excerpted from the workspace log file...
!ENTRY org.eclipse.ui 4 0 2018-10-03 13:19:05.424
!MESSAGE Unhandled event loop exception
!STACK 0
at java.awt.image.DirectColorModel.createCompatibleWritableRaster(Unknown Source)
at java.awt.image.BufferedImage.<init>(Unknown Source)
at org.eclipse.wb.internal.core.utils.ui.ImageUtils.getBufferedImage(ImageUtils.java:81)
at org.eclipse.wb.internal.core.utils.ui.ImageUtils.access$0(ImageUtils.java:71)
at org.eclipse.wb.internal.core.utils.ui.ImageUtils$1.runObject(ImageUtils.java:60)
at org.eclipse.wb.internal.core.utils.ui.ImageUtils$1.runObject(ImageUtils.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runObject(ExecutionUtils.java:246)
at org.eclipse.wb.internal.core.utils.ui.ImageUtils.convertToSWT(ImageUtils.java:58)
at org.eclipse.wb.internal.swing.DescriptionProcessor.configureIconFromBeanInfo(DescriptionProcessor.java:59)
at org.eclipse.wb.internal.swing.DescriptionProcessor.process(DescriptionProcessor.java:46)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription0(ComponentDescriptionHelper.java:437)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription0(ComponentDescriptionHelper.java:289)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription(ComponentDescriptionHelper.java:258)
at org.eclipse.wb.core.model.WrapperMethodInfo.isWrapper(WrapperMethodInfo.java:154)
at org.eclipse.wb.internal.core.parser.AbstractParseFactory.createInstance(AbstractParseFactory.java:507)
at org.eclipse.wb.internal.core.parser.AbstractParseFactory.create(AbstractParseFactory.java:174)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$ExecutionFlowParseVisitor.endVisit(JavaInfoParser.java:693)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:399)
at org.eclipse.jdt.core.dom.ASTVisitor$$EnhancerByCGLIB$$daa17890.endVisit(<generated>)
at org.eclipse.jdt.core.dom.ClassInstanceCreation.accept0(ClassInstanceCreation.java:316)
at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2796)
at org.eclipse.jdt.core.dom.ASTNode.acceptChild(ASTNode.java:2844)
at org.eclipse.jdt.core.dom.Assignment.accept0(Assignment.java:313)
at org.eclipse.jdt.core.dom.ExpressionStatement.accept0(ExpressionStatement.java:145)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:354)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement(ExecutionFlowUtils.java:315)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:336)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:247)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.access$1(ExecutionFlowUtils.java:235)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.endVisit(ExecutionFlowUtils.java:442)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:391)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:241)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:228)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:191)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parseRootMethods(JavaInfoParser.java:312)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:268)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:238)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:159)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:534)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:522)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:449)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4889)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:446)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:483)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:465)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:415)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1088)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:802)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3187)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1870)
at org.eclipse.swt.custom.CTabFolder.lambda$0(CTabFolder.java:328)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
[Updated on: Wed, 03 October 2018 14:02] by Moderator
Re: Oxygen (4.7.2) and WindowBuilder (1.9.1.201710100405) [message #1796308 is a reply to message #1796077] |
Wed, 10 October 2018 04:08   |
Please excuse my late reply. I had work commitments that took precedence and was unable to attend to your request.
I installed Eclipse 2018-09 (4.9.0) as well as WindowBuilder from the URL you indicated. It has the qualifier you indicated, i.e. 1.10.0.201810041649
I then created a brand new workspace and copied (not imported) the code from my Java 1.8 workspace.
I then tried to open a java source code file in WindowBuilder and got the same behaviour as I have described above in my earlier posts.
Below is the relevant part of the workspace log file.
(Note that class 'QtPanel' is one of our proprietary classes that extends 'JPanel')
!ENTRY org.eclipse.wb.swing 4 0 2018-10-10 06:29:34.772
!MESSAGE Error processing component: org.eclipse.wb.internal.swing.model.component.JPanelInfo(qt.presentacion.QtSimplePanel, m=[setGridLines({java.lang.String}), setBorderColor({java.awt.Color}), setShowBorder({boolean}), setTitle({java.lang.String}), setProtected({boolean}), setUI({javax.swing.plaf.ComponentUI}), setUI({javax.swing.plaf.PanelUI}), setActionMap({javax.swing.ActionMap}), setAlignmentX({float}), setAlignmentY({float}), setAutoscrolls({boolean}), setBackground({java.awt.Color}), setBorder({javax.swing.border.Border}), setBounds({java.awt.Rectangle}), setComplete({boolean}), setComponentOrientation({java.awt.ComponentOrientation}), setComponentPopupMenu({javax.swing.JPopupMenu}), setCursor({java.awt.Cursor}), setDebugGraphicsOptions({int}), setDoubleBuffered({boolean}), setDropTarget({java.awt.dnd.DropTarget}), setEnabled({boolean}), setFocusCycleRoot({boolean}), setFocusTraversalKeysEnabled({boolean}), setFocusTraversalPolicy({java.awt.FocusTraversalPolicy}), setFocusTraversalPolicyProvider({boolean}), setFocusable({boolean}), setFont({java.awt.Font}), setForeground({java.awt.Color}), setIgnoreRepaint({boolean}), setInheritsPopupMenu({boolean}), setInputVerifier({javax.swing.InputVerifier}), setLayout({java.awt.LayoutManager,child}), setLocale({java.util.Locale}), setLocation({java.awt.Point}), setMaximumSize({java.awt.Dimension}), setMinimumSize({java.awt.Dimension}), setModified({boolean}), setName({java.lang.String}), setNextFocusableComponent({java.awt.Component}), setObserverCommand({java.lang.String}), setOpaque({boolean}), setPreferredSize({java.awt.Dimension}), setRequestFocusEnabled({boolean}), setSize({java.awt.Dimension}), setStringObservables({java.lang.String}), setToolTipText({java.lang.String}), setTransferHandler({javax.swing.TransferHandler}), setValid({boolean}), setVerifyInputWhenFocusTarget({boolean}), setDefaultLocale({java.util.Locale}), setLocation({int},{int}), setSize({int},{int}), setBounds({int},{int},{int},{int}), add({java.awt.Component,child}), add({java.awt.Component,child,parent2},{java.lang.Object,child2}), add({java.lang.String,child2},{java.awt.Component,child,parent2})], p={gridLayout.grabHorizontal=true, gridLayout.grabVertical=true, interceptOnlyDuringExecution=true, layout.has=true})
!STACK 0
at org.eclipse.wb.internal.swing.DescriptionProcessor.configureIconFromBeanInfo(DescriptionProcessor.java:69)
at org.eclipse.wb.internal.swing.DescriptionProcessor.process(DescriptionProcessor.java:49)
at org.eclipse.jdt.core.dom.ASTVisitor$$EnhancerByCGLIB$$a6c80ad6.endVisit(<generated>)
at org.eclipse.jdt.core.dom.ClassInstanceCreation.accept0(ClassInstanceCreation.java:307)
at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2800)
at org.eclipse.jdt.core.dom.ASTNode.acceptChild(ASTNode.java:2848)
at org.eclipse.jdt.core.dom.Assignment.accept0(Assignment.java:303)
at org.eclipse.jdt.core.dom.ExpressionStatement.accept0(ExpressionStatement.java:136)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:347)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:230)
at org.eclipse.jdt.core.dom.ASTNode.acceptChildren(ASTNode.java:2871)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:228)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:147)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4594)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:440)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:356)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:474)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4145)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:778)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3198)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1881)
at org.eclipse.swt.custom.CTabFolder.lambda$0(CTabFolder.java:331)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3958)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3561)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:628)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:199)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:391)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:246)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
!ENTRY org.eclipse.ui 4 0 2018-10-10 06:29:34.807
!STACK 0
!ENTRY org.eclipse.ui 4 0 2018-10-10 06:29:34.853
!STACK 0
at org.eclipse.wb.internal.core.editor.UndoManager.addSelectionListener(UndoManager.java:187)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:382)
[Updated on: Wed, 10 October 2018 04:17] by Moderator
Re: Oxygen (4.7.2) and WindowBuilder (1.9.1.201710100405) [message #1796339 is a reply to message #1796318] |
Thu, 11 October 2018 04:15  |
Please forgive me, my previous reply was incorrect. The method correctly locates the GIF file that contains the icon, however that file had zero size, hence it did not contain width or height details. Returning null is actually not a problem.
As you requested, below is the code I use to locate the relevant icon. Note that RELATIVE_PATH is a partial path to a directory. Also, class 'QtAppSettings' is also one of our proprietary classes and its 'getAppPath()' method returns a path to a directory. So basically the method below creates an icon image from a GIF file. And as already stated, the problem occurs if the GIF file has zero size.
public static java.awt.Image loadImage(String resourceName) {
Image img = null;
if (resourceName != null) {
String base = new QtAppSettings().getAppPath();
if (base == null || base.length() == 0) {
base = System.getProperty("user.dir");
java.nio.file.Path p = java.nio.file.Paths.get(base, RELATIVE_PATH, resourceName);
java.net.URI uri = p.toUri();
try {
java.net.URL url = uri.toURL();
java.awt.image.ImageProducer ip = (ImageProducer) url.getContent();
if (ip != null) {
img = java.awt.Toolkit.getDefaultToolkit().createImage(ip);
catch (IOException xIo) {
return img;
Current Time: Thu Sep 11 01:29:01 EDT 2025
Powered by FUDForum. Page generated in 0.04767 seconds
