Home » Language IDEs » ServerTools (WTP) » Prompt for Starting and Stopping server
Prompt for Starting and Stopping server [message #179597] Thu, 21 September 2006 16:09 Go to next message
Originally posted by: tomh.a-t-g.com
We are getting a prompt that our Tomcat(5.0.30) server didn't start in 45
seconds from Web Tools (1.0.3) in Eclipse 3.1.2. Our application uses
iBatis to setup some configuration when its starts so it may take one minute
sometimes. Is there a way to change the warning time or suspend these?
Thanks in advance,
Tom
Re: Prompt for Starting and Stopping server [message #179615 is a reply to message #179597] Thu, 21 September 2006 16:30 Go to previous messageGo to next message
There is a setting on the Window -> Preferences -> Server page called
"Server timeout delay". As documented in Bug 151993 [1], following
table shows what delays are available:
Preference Old New
Shorter 9s 11s
Short 27s 22s
Normal 45s 45s
Long 61s 90s
Longer 81s 180s
Unlimited n/a unlimited
Old = WTP 1.0.x and WTP 1.5
New = current WTP 1.5.1
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=151993
> Thanks in advance,
> Tom
Re: Prompt for Starting and Stopping server [message #179981 is a reply to message #179615] Tue, 26 September 2006 11:47 Go to previous messageGo to next message
I have tried adjusting the this 'Server timeout delay'. And I set it to
Longer (I am on WTP 1.0.3) and I still get the message when it takes more
than 45 seconds. I did click apply too.
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:eeusq0$i8j$1@utils.eclipse.org...
> "Server timeout delay". As documented in Bug 151993 [1], following table
> Preference Old New
> Shorter 9s 11s
> Short 27s 22s
> Normal 45s 45s
> Long 61s 90s
> Longer 81s 180s
> Cheers,
> Larry
>> minute sometimes. Is there a way to change the warning time or suspend
>> these?
>> Thanks in advance,
>> Tom
Re: Prompt for Starting and Stopping server [message #179986 is a reply to message #179981] Tue, 26 September 2006 13:22 Go to previous messageGo to next message
There appears to be a bug in WTP 1.0.3 with respect to this setting if
you don't click Apply before clicking OK in the Preferences dialog.
Always clicking Apply after changing the setting seemed to get it to
work consistently for me.
To brute force this setting, you can modify the
"org.eclipse.wst.server.core.prefs" file in the
"<workspace>/.metadata/.plugins/org.eclipse.core.runtime/.settings "
folder to ensure there is a property defined as "machine-speed=1", which
corresponds to the Longer selection.
Larry
>> Preference Old New
>> Shorter 9s 11s
>> Short 27s 22s
>> Normal 45s 45s
>> Long 61s 90s
>> Longer 81s 180s
>> Cheers,
>> Larry
>>> these?
>>> Thanks in advance,
>>> Tom
Re: Prompt for Starting and Stopping server [message #180075 is a reply to message #179986] Wed, 27 September 2006 15:28 Go to previous messageGo to next message
I have changed my to setting to Longer and checked the file it was 1. And
still get the prompt at 45 seconds. Then to try something I changed it to
Shorter and the file said
machine-speed=9 but I still get the warning at 45 seconds. So I don't think
it is working
in 1.0.3 correctly. A co-worker with the same setup is having the same
problem.
Is this prompt supposed to stop the prompt on shutdowns as well? We still
get a prompt for
shutdowns.
Tom
news:efbnkj$b8m$1@utils.eclipse.org...
> There appears to be a bug in WTP 1.0.3 with respect to this setting if you
> don't click Apply before clicking OK in the Preferences dialog. Always
> clicking Apply after changing the setting seemed to get it to work
> "<workspace>/.metadata/.plugins/org.eclipse.core.runtime/.settings " folder
> Cheers,
> Larry
>>> Preference Old New
>>> Shorter 9s 11s
>>> Short 27s 22s
>>> Normal 45s 45s
>>> Long 61s 90s
>>> Longer 81s 180s
>>> Cheers,
>>> Larry
>>>> 45 seconds from Web Tools (1.0.3) in Eclipse 3.1.2. Our application
>>>> uses iBatis to setup some configuration when its starts so it may take
>>>> one minute sometimes. Is there a way to change the warning time or
>>>> suspend these?
>>>> Thanks in advance,
>>>> Tom
Re: Prompt for Starting and Stopping server [message #180127 is a reply to message #180075] Thu, 28 September 2006 08:36 Go to previous message
I found Bug 150090, which indicates the setting isn't being used in WTP
1.0.x and 1.5. This is fixed in WTP 1.5.1.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=150090
> it is working
> problem.
> get a prompt for
> shutdowns.
> Tom
>> Cheers,
>> Larry
>>>> Preference Old New
>>>> Shorter 9s 11s
>>>> Short 27s 22s
>>>> Normal 45s 45s
>>>> Long 61s 90s
>>>> Longer 81s 180s
>>>> Cheers,
>>>> Larry
>>>>> suspend these?
>>>>> Thanks in advance,
>>>>> Tom
Previous Topic:Automatic Server Restart / reloadable="false"
Next Topic:Error executing JSP page from Eclipse 3.2 WTP
Current Time: Wed Jul 23 12:38:09 EDT 2025
Powered by FUDForum. Page generated in 0.28175 seconds
