Home » Modeling » ATL » ATL EMFTVM no entries available when trying to select module from workspace
ATL EMFTVM no entries available when trying to select module from workspace [message #1795676] Wed, 26 September 2018 12:31 Go to next message
Hi ,
I was trying to use ATL EMFTVM to launch a HOT transformation. But in the Run configuration dialog when I try to select the ATL module from workspace, it just shows "No entries available" , as seen in the attached picture.
index.php/fa/33955/0/
Thank you.
  • Attachment: runconfig.PNG
    (Size: 52.10KB, Downloaded 664 times)
Re: ATL EMFTVM no entries available when trying to select module from workspace [message #1795751 is a reply to message #1795676] Thu, 27 September 2018 16:11 Go to previous message
I figured out the problem. It was just because of a bad installation of ATL on my eclipse. I reinstalled ATL again and I'm able to see and select the EMFTVM modules from the workspace.
Thank you
Previous Topic:Main thread of debugging terminated immediately
Next Topic:BPMN to UPPAAL: problem with the target generated model
Current Time: Fri Nov 07 11:55:35 EST 2025
Powered by FUDForum. Page generated in 0.02801 seconds
