Home » Modeling » TMF (Xtext) » Cloning/Copying Xtext Resource including node model
Cloning/Copying Xtext Resource including node model [message #1795612] Wed, 26 September 2018 04:28 Go to next message
I am looking for a way to clone the xtext Resource(deep copy).
I could copy the semantics using the EcoreUtil as shown below
void cloneResource (Resource original, Resource clone)
Collection<EObject> clonedContents = EcoreUtil.copyAll(original.getContents());
clone.getContents().addAll(clonedContents);
I would like to to do something similar for for the NodeModel as well.
Is there any way to do so?. Please help me.
I had a look into EcoreUtil2 as well and did not found anything which could help.
Thanks in advance.
Panisha
Re: Cloning/Copying Xtext Resource including node model [message #1795613 is a reply to message #1795612] Wed, 26 September 2018 04:37 Go to previous messageGo to next message
Why not just copy and reparse the file?
Re: Cloning/Copying Xtext Resource including node model [message #1795616 is a reply to message #1795613] Wed, 26 September 2018 04:52 Go to previous messageGo to next message
Hello Thomas,
Thanks for the reply.
I do not wanted to re-parse the same file.
Is it the only way to clone/copy xtext Resource?
Panisha
Re: Cloning/Copying Xtext Resource including node model [message #1795634 is a reply to message #1795616] Wed, 26 September 2018 06:23 Go to previous messageGo to next message
The simplest one, since you don't have to care about the NodeModel. It would be created by the parser. I'm not aware of a way to copy it and never needed to do so.
Re: Cloning/Copying Xtext Resource including node model [message #1795641 is a reply to message #1795634] Wed, 26 September 2018 07:18 Go to previous message
Hello Tomas,
Thanks for the hint.
Re-parsing the resource again worked for me.. I even tried to copy node model manually..had some difficulty.
May be in the long run, API to copy the node mode only is useful to copy something which is not part of the semantic model from one resource to another.
Panisha
Previous Topic:How to implement scoping and validation for an element at same time
Next Topic:How to control Indexing for Xtext Projects
Current Time: Wed Nov 05 04:06:08 EST 2025
Powered by FUDForum. Page generated in 0.07355 seconds
