Issue With Arduino CDT & ESP8266 Program [message #1794972] |
Tue, 11 September 2018 19:05  |
Hello all,
I am trying to compile a Generic ESP8266 Module program using the Arduino CDT plugin. I installed a fresh instance of Eclipse Photon, downloaded the esp8266 board using the Arduino Downloads manager, and tried to compile a basic program and receive this error:
c:/users/kmahajan/.arduinocdt/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: cannot open linker script file ../ld/eagle.app.v6.common.ld: No such file or directory
collect2.exe: error: ld returned 1 exit status
make: *** [Tesst.elf] Error 1
makefile:101: recipe for target 'Tesst.elf' failed
This program does compile in the Arduino IDE, but when I bring it over to Eclipse, it does not compile. Does anyone have any suggestion on how I can get any program to compile for the ESP8266 module? Any good documentation for setting up the esp8266 in Arduino correctly? Thanks guys.
Re: Issue With Arduino CDT & ESP8266 Program [message #1816584 is a reply to message #1815873] |
Thu, 31 October 2019 16:15  |
I had the same experience and I was glad that I found this thread.
I followed the instructions carefully and with the last reply of Abhishek Mishra I was able to generate the .elf file.
However, in a next step where I tried to flash the EPS8266 it gave an error that the .bin file was missing. I was able to fix this with the following extensions:
## Combine gc-sections, archives, and objects
recipe.c.combine.pattern={recipe.hooks.linking.prelink.1.pattern} & "{compiler.path}{compiler.c.elf.cmd}" {build.exception_flags} -Wl,-Map "-Wl,{build.path}/{build.project_name}.map" {compiler.c.elf.flags} {compiler.c.elf.extra_flags} -o "{build.path}/{build.project_name}.elf" -Wl,--start-group {object_files} "{archive_file_path}" {compiler.c.elf.libs} -Wl,--end-group "-L{build.path}" & {recipe.objcopy.hex.1.pattern}
This is at line 105 of platform.txt file (version 2.5.2)
Best regards, Cor
FUDForum. Page generated in 0.05621 seconds
