'UnsupportedConfigurationException' after closing alg.layered. [message #1795075] |
Fri, 14 September 2018 02:44  |
I use the ELK to layout my diagram in sirius editor. In my odesign, I set the layout algorithm as "ELK Mr. Tree" and I uninstall the "ELK Layered" from my eclipse, when I perform arrange all in sirius editor, there is exception appears as follows:
Sirius version: 6.0.1
ELK version: 0.4.1
Test model: family sample
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:496)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:71)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:52)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.execute(DiagramAction.java:141)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.doRun(DiagramAction.java:103)
at org.eclipse.gmf.runtime.diagram.ui.actions.internal.ArrangeAction.doRun(ArrangeAction.java:278)
at org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.run(AbstractActionHandler.java:359)
at org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run(ActionManager.java:225)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:71)
at org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(ActionManager.java:223)
at org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.runWithEvent(AbstractActionHandler.java:377)
at org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetAction.java:226)
at org.eclipse.gmf.runtime.common.ui.action.ActionMenuManager$MenuCreatorAction.runWithEvent(ActionMenuManager.java:216)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$5(ActionContributionItem.java:436)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5686)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1370)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4940)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4518)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
at org.eclipse.equinox.launcher.Main.main(Main.java:1471)
Caused by: org.eclipse.elk.core.UnsupportedConfigurationException: No layout algorithm has been specified for Root Node > Node Paul
at org.eclipse.elk.core.data.LayoutAlgorithmResolver.resolveAlgorithm(LayoutAlgorithmResolver.java:45)
at org.eclipse.elk.core.data.LayoutAlgorithmResolver.visit(LayoutAlgorithmResolver.java:26)
at org.eclipse.elk.core.util.ElkUtil.applyVisitors(ElkUtil.java:860)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layout(RecursiveGraphLayoutEngine.java:72)
at org.eclipse.sirius.diagram.elk.ElkDiagramLayoutConnector.layout(ElkDiagramLayoutConnector.java:1167)
at org.eclipse.sirius.diagram.elk.ELKLayoutNodeProvider.layoutEditParts(ELKLayoutNodeProvider.java:37)
at org.eclipse.sirius.diagram.ui.tools.internal.layout.provider.ArrangeSelectionLayoutProvider.lauchPrimaryArrangeAll(ArrangeSelectionLayoutProvider.java:255)
at org.eclipse.sirius.diagram.ui.tools.internal.layout.provider.ArrangeSelectionLayoutProvider.layoutEditParts(ArrangeSelectionLayoutProvider.java:171)
at org.eclipse.sirius.diagram.ui.tools.api.layout.provider.AbstractLayoutProvider.getCommandFromDiagramLayoutProvider(AbstractLayoutProvider.java:168)
at org.eclipse.sirius.diagram.ui.tools.api.layout.provider.AbstractLayoutProvider.layoutEditParts(AbstractLayoutProvider.java:117)
at org.eclipse.gmf.runtime.diagram.ui.services.layout.AbstractLayoutEditPartProvider.layoutLayoutNodes(AbstractLayoutEditPartProvider.java:69)
at org.eclipse.gmf.runtime.diagram.ui.internal.services.layout.LayoutNodesOperation.execute(LayoutNodesOperation.java:74)
at org.eclipse.gmf.runtime.common.core.service.ExecutionStrategy$1.execute(ExecutionStrategy.java:70)
at org.eclipse.gmf.runtime.common.core.service.Service.execute(Service.java:651)
at org.eclipse.gmf.runtime.diagram.ui.services.layout.LayoutService.execute(LayoutService.java:66)
at org.eclipse.gmf.runtime.diagram.ui.services.layout.LayoutService.layoutLayoutNodes(LayoutService.java:299)
at org.eclipse.gmf.runtime.diagram.ui.commands.ArrangeCommand.getCommandForExecution(ArrangeCommand.java:124)
at org.eclipse.gmf.runtime.diagram.ui.commands.ArrangeCommand.doExecuteWithResult(ArrangeCommand.java:93)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.emf.workspace.CompositeEMFOperation.doExecute(CompositeEMFOperation.java:217)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:134)
at org.eclipse.sirius.diagram.ui.tools.internal.commands.WrappingCommandIgnoringAffectedFiles.execute(WrappingCommandIgnoringAffectedFiles.java:123)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:488)
... 41 more
Hope for your reply!!!
[Updated on: Fri, 14 September 2018 02:53] by Moderator
FUDForum. Page generated in 0.05312 seconds
