Home » Eclipse Projects » Oomph » Specified default installation path
Specified default installation path [message #1794908] Mon, 10 September 2018 14:45 Go to next message
I see that oomph have some configuration options for installer inside .ini file, ie.: -Doomph.setup.product.filter
I would like to specified default product installation location inside .ini file, for example:
-Doomph.setup.product.installation.location="some path"
It is possible?
[Updated on: Mon, 10 September 2018 18:54] by Moderator
Re: Specified default installation path [message #1794919 is a reply to message #1794908] Tue, 11 September 2018 02:43 Go to previous messageGo to next message
You can influenced the default used by the simple mode of the installer using -Doomph.setup.install.root. The advanced mode uses install.root. In all cases, the product name is determined by the catalog, and can be influenced by defining a variable "installation.id.default" in the product.
Re: Specified default installation path [message #1795018 is a reply to message #1794919] Wed, 12 September 2018 15:35 Go to previous messageGo to next message
-Doomph.setup.install.root seems to work.
I added into my product setup:
<setupTask
xsi:type="setup:VariableTask"
id=""
filter=""
name="installation.id.default"
value="testname"
defaultValue=""
label="">
<description></description>
</setupTask>
but this is not affecting simple installer.
Simple installer field: "Installation Folder" have content: <path from -Doomph.setup.install.root>/<product name>-<eclipseversion>
example:
lets assume: -Doomph.setup.install.root=/home/pawel/test
I get:
/home/pawel/test/microide-oxygen
but I expected:
/home/pawel/test/testname
Tested on: Installer version: 1.9.0 Build 3649
I am doing something wrong or I misunderstand purpose of variable "installation.id.default".
Re: Specified default installation path [message #1795027 is a reply to message #1795018] Thu, 13 September 2018 02:11 Go to previous message
Sorry, I was wrong. Only advanced mode does variable evaluation.
In simple mode, org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.getDefaultInstallationFolder() builds the folder's name, and that's all hard coded. Perhaps it could be changed so that if there is only one product version, it doesn't append the "-<version.name>" but I don't know if that would actually achieve your goal.
Previous Topic:Upgrading Oomph on Ubuntu 18.04
Next Topic:Target URI is not well formed
Current Time: Sat Jul 26 21:12:40 EDT 2025
Powered by FUDForum. Page generated in 0.03171 seconds
