Home » Eclipse Projects » Remote Application Platform (RAP) » RWT-OSGI and security
RWT-OSGI and security [message #894692] |
Tue, 10 July 2012 03:37  |
I have integrated RWT-OSGI with Apache Karaf and every thing is working
fine. Now I am trying to secure the application using JAAS.
I have looked around and found preferred way to secure RAP applications
is Equinox security integration [1]. Equinox security need extension
registry and I do not want to use the Extension registry Workbench.
I cant use the standard container managed security as RWT-OSGI does not
have a web.xml to configure container managed security.
Apache Karaf provides JAAS security modules and I could use them to
authenticate. However, I see a problem with this method as I see it only
a client side authentication. This security can be easily bypassed by
accessing the server URLs directly using browser or any other web
client/user agent.
Is there is a better way to integrate JAAS security with RWT-OSGI
applications without using extension registry and Workbench?
[1]http://wiki.eclipse.org/RAP/Equinox_Security_Integration
Rajbir Saini
Re: RWT-OSGI and security [message #894778 is a reply to message #894774] |
Tue, 10 July 2012 09:39   |
Rüdiger,
Thanks for your quick response.
If I use Equinox security, is there a role based authorization (without
using Eclipse Activities)?
Raj
On Tuesday 10 July 2012 06:48 PM, Rüdiger Herrmann wrote:
> Raj,
> I can only comment on the Equinox security issue. The extension registry
> and the workbench are independent from each other. If you use Equinox
> security, you'll depend on the extension registry (core.runtime) but
> *not* on the workbench (i.e. org.eclipse.ui).
> Thus you should be able to use Equinox security with RWT/OSGi without
> the workbench. I would assume however, that Equinox security only works
> with the Equinox OSGi implementation. Hence you'd be bound to the
> Regards,
> Rüdiger
> On 10.07.2012 09:37, Raj Saini wrote:
>> Hi,
>> client/user agent.
>> Regards,
>> Rajbir Saini
Re: RWT-OSGI and security [message #894783 is a reply to message #894692] |
Tue, 10 July 2012 10:05   |
Equinox security is just one possible way to secure RAP applications,
but I wouldn't say that this is generally the preferred way. I fully
agree that in an Apache Karaf environment, there should be a solution
that does not involve dependencies to Equinox.
Unfortunately, I have hardly any experience with this setup yet, so I
can't point you to a solution. But I'm interested in learning about JAAS
and Karaf.
> authenticate.
Using the security modules provided by the container sounds like the
ways to go, doesn't it? Does this already include a login web UI?
I don't fully understand this. If you define your users, roles, and
login modules in Karaf, can't you access the security context in your
application and enforce that the user has sufficient permissions? I'm
thinking about something like this:
LoginContext context = new LoginContext("karaf", handler);
Subject subject = context.getSubject();
subject.getPrincipals()
The Karaf security framework documentation [1] has some more detailed
examples.
Ralf
[1]
http://karaf.apache.org/manual/2.2.8/developers-guide/security-framework.html
Ralf Sternberg
Twitter: @EclipseRAP
Re: RWT-OSGI and security [message #894953 is a reply to message #894783] |
Wed, 11 July 2012 04:40   |
Hi Ralf,
Please see inline:
On Tuesday 10 July 2012 07:35 PM, Ralf Sternberg wrote:
> and Karaf.
Karaf realms are created using custom blueprint artefacts. As Karaf
realms are available system wide, multiple applications can make use of
same Realms. For example, in my application, ActiveMQ and Jetty utilises
same realm.
> > authenticate.
Karaf Login modules do not provide any login web UI. Like any other Jaas
Login module, Karaf uses Callback handler to get the login credentials.
I think my confusion is due to lack of knowledge about RAP. I was
thinking RAP generated different URLs for each request. I debugged the
http request/response communication and it looks all the requests go to
the single URL. Therefore, I do not see a need to protect multiple URLs
as we generally do with standard Java EE applications.
Thanks again for your help.
Raj
> examples.
> Best regards,
> Ralf
> [1]
Re: RWT-OSGI and security [message #895094 is a reply to message #895048] |
Wed, 11 July 2012 12:40   |
Hi Ralf,
I have attached the code of my implementation. I am doing every thing in
RAP using the JAAS API and in fact there is no reference to Karaf APIs.
JAAS Realm is defined and deployed in a separate bundle using OSGi
blueprint. Authentication UI and JAAS related code is within the Dialog
box.
Kindly, let me know if this looks good.
Raj
On Wednesday 11 July 2012 07:45 PM, Ralf Sternberg wrote:
> Hi Raj,
> I think it shouldn't be too hard to come up with a login dialog built
> with RWT that does the login with JAAS. The equinox security UI might
> serve as an example.
> There's only one single URL per entrypoint. So it seems there are two
> ways to combine RAP and JAAS: either you create a standard HTML-based
> login UI and protect the URL to your entrypoint, or you do everything in
> directly RAP using the APIs described in the Karaf docs. Let us know how
> you solved it, or if you need further help.
> Best regards, Ralf
Re: RWT-OSGI and security [message #1794965 is a reply to message #895094] |
Tue, 11 September 2018 13:58  |
Many thanks for this example. I only needed the part that describes how to show a login dialog and then the application but I needed that badly.
I have updated the code to work with Eclipse 4 and posted it back here in case anyone else needs it. I have include a third file that RAP seems to need now, commented out the parts I did not need and changed the package.
Current Time: Tue Sep 09 02:35:36 EDT 2025
Powered by FUDForum. Page generated in 0.04842 seconds
