Home » Modeling » TMF (Xtext) » XText importing a specific file extension(Importing a specific file extension)
XText importing a specific file extension [message #1794744] Wed, 05 September 2018 19:31 Go to next message
Hello everyone, I'm new here and I'm new with Xtext!
I'm trying to make a grammar for importing Schemas, for example, XSD.
I'm trying to import using "importURI" attribute, but I'm not getting any success on this...
See my grammar code below:
Import:
	'import' importURI=STRING 'as' name=ID
And i also added a new extension for ResourceServiceProvider as XSD:
<extension
       point="org.eclipse.xtext.extension_resourceServiceProvider">
    	<resourceServiceProvider
          class="mygrammar.resource..XsdResourceServiceProvider"
          uriExtension="xsd">
    </resourceServiceProvider>
 </extension>
But when I test with, for example, the following syntax: import "test.xsd" as Idm
My ResourceServiceProvider is never called, I tried to overrides ImportUriGlobalScopeProvider, but the method "getScope" is never called with my resource...
And I also need to create a "free" URI, for example, I would like to use a URI like: "C:/test.xsd".
I tried to follow some topics here, but without success :/
Can anyone help me with this? ;)
Thanks a lot!
Re: XText importing a specific file extension [message #1794802 is a reply to message #1794744] Thu, 06 September 2018 13:28 Go to previous messageGo to next message
how do you call this code?
standalone / eclipse ? if eclipse is the xsd file in a project. if standalone how do you populate the resourceset. imports just make things visible. its not a follow the import and load the resource
here is an example on how to provide a resource service provider for uml
https://www.dietrich-it.de/xtext/uml/iresourceserviceprovider/2011/07/17/xtext-2-0-and-uml.html
Re: XText importing a specific file extension [message #1794807 is a reply to message #1794802] Thu, 06 September 2018 15:19 Go to previous messageGo to next message
Hello Christian, thank you for your reply.
I'm using Eclipse!
Since i created this topic i got a success when I put XSD file in the same project, but i would like to load a file outside the project, using my own strategy for reading..
And how can i get the "name" attribute for Import?
I will read your shared link
Thank you!
Re: XText importing a specific file extension [message #1794813 is a reply to message #1794807] Fri, 07 September 2018 00:03 Go to previous messageGo to next message
Can you please exüplain what you mean by
Get Name Attribute
E.g. with a code or pseudo code snippet
Re: XText importing a specific file extension [message #1794896 is a reply to message #1794813] Mon, 10 September 2018 09:48 Go to previous messageGo to next message
Hello Christian,
I mean "name" attribute in import definition (bold):
Import:
Re: XText importing a specific file extension [message #1794897 is a reply to message #1794896] Mon, 10 September 2018 10:39 Go to previous message
import.getName()? please give more context
Previous Topic:Need help to implement an ambiguous grammar (ACSL grammar)
Next Topic:Syntax for bitwise AND operator
Current Time: Fri Jul 25 00:03:55 EDT 2025
Powered by FUDForum. Page generated in 0.04340 seconds
