Home » Eclipse Projects » Paho » PAHO SUBSCRIBE ERROR please help me
PAHO SUBSCRIBE ERROR please help me [message #1794267] Tue, 28 August 2018 06:54 Go to next message
Hello
I have a question.
My develop resource
->EMQTTD MQTT BROKER
-> spring boot 2.0.3
compile group: 'org.eclipse.paho', name: 'org.eclipse.paho.client.mqttv3', version: '1.2.0'
senario
#1. publish simulator (10000 (300byte String) publish, per 1sec) qos0
     / test / monitor / 1 <--- publish
#2. subscribe qos0 simulator / test / monitor / 1
I found an error in this situation as follows.
MQTT BROKER did not stop
PUBLISH # 1 simulator did not stop.
This error only appears in SUBSCRIBE # 2. Is this a problem?
please .. help me
-[error/subscribe simulartor #2]--------------------------
연결 유실 (32109) - java.io.EOFException
2018-08-28 19:31:05.781  INFO 18176 --- [ Rec: monitor_1] com.vitcon.consumer.VitconConsumer  : 여기냐!
2018-08-28 19:31:05.781  INFO 18176 --- [ Rec: monitor_1] com.vitcon.consumer.VitconConsumer  : 연결 유실
2018-08-28 19:31:05.781  INFO 18176 --- [ Rec: monitor_1] com.vitcon.consumer.VitconConsumer  : 접속 시도 :monitor_1
2018-08-28 19:31:05.782 ERROR 18176 --- [ Rec: monitor_1] com.vitcon.consumer.VitconConsumer  : connect failed:MqttException
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:181)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267)
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:92)
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:133)
... 7 more
my mqtt paho source
package com.vitcon.consumer;
import java.util.HashMap;
import java.util.Iterator;
import java.util.concurrent.ConcurrentHashMap;
import org.eclipse.paho.client.mqttv3.IMqttDeliveryToken;
import org.eclipse.paho.client.mqttv3.MqttCallback;
import org.eclipse.paho.client.mqttv3.MqttClient;
import org.eclipse.paho.client.mqttv3.MqttConnectOptions;
import org.eclipse.paho.client.mqttv3.MqttException;
import org.eclipse.paho.client.mqttv3.MqttMessage;
import org.eclipse.paho.client.mqttv3.MqttSecurityException;
import org.eclipse.paho.client.mqttv3.persist.MemoryPersistence;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import org.springframework.beans.factory.annotation.Autowired;
import com.vitcon.agent.config.VitconConfig;
public abstract class VitconConsumer implements Runnable, MqttCallback {
private static final Logger logger = LoggerFactory.getLogger(VitconConsumer.class);
@Autowired
private VitconConfig config;
private MqttClient mqttClient = null;
private MqttConnectOptions connOpts;
private HashMap<String, Boolean> mqttTopics = new HashMap<>();
public void disconnect() {
if (mqttClient == null && !mqttClient.isConnected())
return;
try {
mqttClient.disconnect();
} catch (MqttException e) {
logger.error(e.getMessage());
e.printStackTrace();
public boolean init() {
MemoryPersistence persistence = new MemoryPersistence();
connOpts = new MqttConnectOptions();
connOpts.setConnectionTimeout(60);
connOpts.setCleanSession(true);
connOpts.setMaxInflight(10000);
connOpts.setAutomaticReconnect(false);
//connOpts.setMqttVersion(MqttConnectOptions.MQTT_VERSION_3_1);
try {
// mqttClient = new MqttClient(config.getMqttUri(), config.getMqttClientId(), persistence);
logger.info("[mqtt]connect:" + config.getMqttUri() + " clientId:" + getMqttClientId());
mqttClient = new MqttClient(config.getMqttUri(), getMqttClientId(), persistence);
logger.error("mqtt connect failed:" + e.getMessage());
return false;
mqttClient.setCallback(this);
return true;
public boolean connect() {
if (mqttClient != null && mqttClient.isConnected())
return true;
try {
logger.info("접속 시도 :" + mqttClient.getClientId());
mqttClient.connect(connOpts);
logger.info("접속 완료 :" + mqttClient.getClientId());
Iterator<String> e = this.mqttTopics.keySet().iterator();
while (e.hasNext()) {
String topic = e.next();
logger.info("[mqtt topic]:" + topic + " qos:"+config.getMqttQos());
mqttClient.subscribe(topic, config.getMqttQos());
// logger.info("set topic:" + topic);
} catch (MqttSecurityException e) {
logger.error("connect failed:" + e.getMessage());
if (mqttClient.isConnected())
return true;
return false;
public abstract String getMqttClientId();
public boolean isRun() {
return config.isRun();
public void setTopic(String topic) {
this.mqttTopics.put(topic, null);
public void removeTopic(String topic) {
this.mqttTopics.remove(topic);
public void connectionLost(Throwable cause) {
logger.info("코넥션 로스트:" + mqttClient.isConnected());
cause.printStackTrace();
logger.info("여기냐!");
logger.info(cause.getMessage());
// TODO Auto-generated method stub
while (config.isRun()) {
if (connect())
return;
try {
Thread.sleep(3000);
} catch (InterruptedException e) {
logger.error("connectionLost:" + e.getMessage());
public void messageArrived(String topic, MqttMessage message) throws Exception {
try {
} catch (Exception e) {
logger.error("wontae" + e.getMessage());
// TODO: handle exception
public void deliveryComplete(IMqttDeliveryToken token) {
public void run() {
Re: PAHO SUBSCRIBE ERROR please help me [message #1794343 is a reply to message #1794267] Wed, 29 August 2018 05:35 Go to previous message
Hi, an EOFException implies that the server has closed the connection to the subscriber. I would suggest looking at the server logs to see why it is doing that. Do you get different results if you change the number of messages being published per second? That may also have an impact.
Previous Topic:MQTTClient_connect always gives -1
Next Topic:C Paho Api Threading Issue
Current Time: Mon Nov 03 12:47:57 EST 2025
Powered by FUDForum. Page generated in 0.03953 seconds
