Home » Language IDEs » C / C++ IDE (CDT) » Eclipse & lldb-mi (macOSX) breakpoint in dynamically loaded library at runtime
Eclipse & lldb-mi (macOSX) breakpoint in dynamically loaded library at runtime [message #1794030] Wed, 22 August 2018 12:59 Go to next message
My scenario is as follows:
I am developing a C++ dynamically loaded library for PHP which is loaded at run-time. I need to set a breakpoint at a line inside the library. I am working w/ MacOSX and the lldb-mi interface.
Unfortunately, I have not figured out a way to get lldb-mi to load the symbols before the breakpoint is set, and lldb-mi is refusing to add the pending breakpoint.
I have not found the equivalent of .lldbinit to auto-execute target modules add CDT.so.
I have not found a way to have the Eclipse/CDT lldb-mi interface to either set target modules add CDT.so before setting the breakpoint (which will work).
I have not found a way to have the Eclipse/CDT lldb-mi interface to use the -f flag (future/pending flag), which I have confirmed to work when running lldb-mi from the console.
eg: -break-insert -f /Library/WebServer/Documents/cdtweb/ro/ComponentManager.cpp:90
Here is the lldb/gdb trace log from Eclipse:
cdt-dev@eclipse.org215,497 24-break-insert /Library/WebServer/Documents/cdtweb/ro/ComponentManager.cpp:90
215,498 24^error,msg="Command 'break-insert'. Breakpoint location '/Library/WebServer/Documents/cdtweb/ro/ComponentManager.cpp:90' not found"
Is there a correct way to debug this issue with Eclipse/CDT/lldb-mi that I'm simply overlooking, or do I need to start hacking on the CDT/lldb-mi integration to add a -f / pending breakpoint option?
As for gdb, I haven't yet figured out how to even get gdb to break inside the dynamically loaded library from the command line/console, so I don't think I can go that route with Eclipse.
Marius
Re: Eclipse & lldb-mi (macOSX) breakpoint in dynamically loaded library at runtime [message #1795140 is a reply to message #1794030] Sun, 16 September 2018 15:38 Go to previous message
Hi Marius, could you file a bug for this? https://bugs.eclipse.org/bugs/enter_bug.cgi?product=CDT
I should be able to address this soon (at least adding the -f in CDT). Basically, we'll need a LLDB-specific command factory so be able to tweak the -break-insert command (I have another patch that adds the factory). I think on the LLDB side, it's probably because "-gdb-set breakpoint pending on" is not implemented. We can file an issue for that too and works towards fixing it upstream.
Previous Topic:How to filter C static functions prototypes from Eclipse quick outline popup Ask Question
Next Topic:Error :com.spotify.docker.client.DockerConfigReader - No appenders could be found for logger
Current Time: Sun Jul 27 14:11:17 EDT 2025
Powered by FUDForum. Page generated in 0.04722 seconds
