Home » Language IDEs » Java Development Tools (JDT) » Stepping through code in Photon is slow, but clicking on trace speeds it up
Stepping through code in Photon is slow, but clicking on trace speeds it up [message #1793677] Mon, 13 August 2018 19:27 Go to next message
After upgrading to Photon, I've been noticing that stepping through code is seemingly much slower than it used to be. I particularly notice when I do a "Step Over" on a simple line of code. It takes several seconds before the green highlight appears on the next line.
What I discovered, however, is that after doing "Step Over", if I then just click on the stacktrace, at the top of the stack, it immediately updates the green highlight in the code. I can step through the code quite a bit faster by pressing F6 (step over), then immediately clicking on the stack entry, and then F6, and so on.
This is is a workaround, but it's still an annoyance.
There's nothing significant in the error log.
Is this enough information for a bug report?
Re: Stepping through code in Photon is slow, but clicking on trace speeds it up [message #1793697 is a reply to message #1793677] Tue, 14 August 2018 04:31 Go to previous message
Interesting. Very close to a can-I-report-it problem I've observed. Sometimes the Variables View does not refresh to display the prevailing state; very deceitful; need to trick it with another 'step'.
Seems like a thread synchronization problem.
Ed Willink
Previous Topic:Photon installation failed
Next Topic:No Display view
Current Time: Sun Jul 27 11:54:30 EDT 2025
Powered by FUDForum. Page generated in 0.03444 seconds
