Home » Eclipse Projects » EclipseLink » Performance control for dinamic weaving(Help for performance dinamic weaving )
Performance control for dinamic weaving [message #1793580] Fri, 10 August 2018 09:18
Hi folks,
we are experiencing many performance issues when our application starts.
we are using eclipselink 2.72.
We're using dinamic weaving and we want to control which entities load at startup.
We're created two persistence units one with a few class and another with the rest ones.
Our persistencefile:
<persistence version="2.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
  <persistence-unit name="JULISES">
    <provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
    <class>jar1.class1</class>
	<class>jar1.class2</class>
	<class>jar2.class3</class>
    <validation-mode>NONE</validation-mode>
    <properties>
      <property name="eclipselink.logging.level" value="FINE"/>
      <property name="eclipselink.logging.exceptions" value="true"/>
      <property name="eclipselink.logging.session" value="false"/>
      <property name="eclipselink.logging.timestamp" value="true"/>
      <property name="eclipselink.logging.parameters" value="true"/>
    </properties>
  </persistence-unit>
  <persistence-unit name="JULISESGESTION" transaction-type="RESOURCE_LOCAL">
    <exclude-unlisted-classes>true</exclude-unlisted-classes>
    <properties>
      <property name="eclipselink.weaving" value="false"/>
    </properties>
  </persistence-unit>
</persistence>
The problem is, whan applitacion starts , autoamticaly scans all entities for both persistence units.
We've detected before application start .We think could be java virtual machine when we put the agent option in VM(-javaagent:c:/eclipselink/eclipselink.jar ), scan occurs. After that, we create by code a new entitimanagerfactory changing properties at runtime passing the persistence unit we wnat to load, then obviously scan ocurs again because we create an entitymanagerfactory.
public static EntityManagerFactory emf;
public static EntityManager em;
public Map propiedades;
String CADENA_BD;
propiedades = new HashMap();
propiedades.put("eclipselink.logging.file", SYSTEMBASE.ObtenPathLogs() + "LOG_EM_GESTION_" + getNombrePc() + "_" + General.timestamphour2StringSinGuiones(General.Now2()) + ".log");
propiedades.put("eclipselink.logging.level", "FINE");
propiedades.put("eclipselink.weaving", "true");
propiedades.put("javax.persistence.jdbc.driver", driverOracle);
CADENA_BD = "jdbc:oracle:thin:@(DESCRIPTION =" + conexion + "(LOAD_BALANCE = yes) (CONNECT_DATA = (SERVICE_NAME = " + sid + ") (FAILOVER_MODE=(TYPE=SELECT) (METHOD=BASIC) (RETRIES=180) (DELAY=5))))";
propiedades.put("javax.persistence.jdbc.url", SYSTEMBASE.CADENA_BD);
persistenceUnit = "JULISESGESTION";
SYSTEMBASE.emf = Persistence.createEntityManagerFactory(persistenceUnit, propiedades);
SYSTEMBASE.setEm(emf.createEntityManager());
It is possible to avoid first scan? We have more than 300 entities and we don't need all to load the aplication.
Notice that we hace a splashscreen , and a cause of first scannig it takes many seconds to load ( seeing persistence log )
If not possible, can we select with persistenceunit scan and the second one , load it later?
Previous Topic:Eclipselink support
Next Topic:EclipseLink-Moxy Unable to load custom DomHandler in OSGI environment
Current Time: Mon Jul 21 09:57:32 EDT 2025
Powered by FUDForum. Page generated in 0.11846 seconds
